Cold Air Inductions
Old 11-07-2009, 07:48 PM   #1
kingsnakes2LT
Kingsnakes2LT
kingsnakes2LT's Avatar
Drives: 2010 2LT CAMARO, ABM, White Stripes
Send a message via Skype™ to kingsnakes2LT
Winter Storage
I have a v6 2LT that I want to put away for the winter.
I only have a car port with no electricity, so a trickle charger is not possible.
I plan to put her on plywood squares under the tires, inflate the tires to 50 psi, top off the tank, add stabalizer, fresh oil -Mobil1 5w30, wash and wax, put charcoal in buckets in front floor board, then cover with a Covercraft Evolution Block-it custom car cover. I plan on using the cover cable lock and additional cover tie downs to ensure the cover does not blow off. I live in N. E. Indiana and can get pretty hard cold winters. I plan to start her up once every two weeks and let her idle for about 1 hour to keep the battery up. I think running the engine at idle for an hour should get her up to operating temps.
What do you think?
Is there something more I should do?
Serious advise from others without a garage is appreciated.
Thanks!
Kingsnake Ordered: Order # NKNMSX, 6-15-09 - 2LT, RS, with Auto6, Aqua Blue Metalic, Factory Installed White Rally Stripes, Sun Roof, & 20x8/20x9 Polished Alum. Wheels :cool
1100 Order Placed- 6/15/09
2000 Order Accepted by GM - 8/14/09
3000 Order accepted by Prod. Control - 8/19/09 - TPW 9/14/09
3800 Vehicle Produced - 9-15-09 - 2G1FC1EV1A9146788
4B00 Bayed - 9-16-09
4200 Available to Ship - 9-19-09
In Transit - 9-22-09
5000 Vehicle at Dealer - 9-25-09
6000 Delivered to Customer - 9-28-09
My Car, #1406 of 1592 ABM LTs built = PRICELESS
kingsnakes2LT is offline   Reply With Quote
Old 11-07-2009, 08:24 PM   #2
Merc
In The Circle
Merc's Avatar
Plastic tank no need to top off tank.
Old 11-07-2009, 09:08 PM   #3
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Leave the tires alone and put it on jack stands (and it slows down theft)
Do not start it until you can drive it. Use a solar trickle charger.
Oil like molasses is not kind to cylinder walls and the condensation is not good from all the starts.
I have been storing collector cars for 30 years but this one will us a lot of juice and I do not want to reset everything next spring .
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 11-07-2009, 09:32 PM   #4
Merc
In The Circle
Merc's Avatar
Are you saying your better off not to start it monthy and bring it to operating tempature.As well as moving it a few feet back and forth to lubricate diff and tranny.
Old 11-07-2009, 10:20 PM   #5
ProstZ28
ProstZ28's Avatar
Drives: 79 Pro Street Z28,2010 2SS RS
i would look for a cheap set of tires and rims if possible or put the car on stands ,do not start car untill ready to drive , try to get a long enough outdoor extenstion cord and get a deltron battery tender not a trickle charger , if you start the car all you are doing is building up condensation in the engine and exhaust system that is not good, if you cannot get power at all to the car i woulld remove the battery as a last resort and make sure you store battery off the ground !! i would also look hard for a garage to rent lots of people have more junk in garage and with a little help from you , you could make enoughroom to fit a car!!!
2010 BLK 2SS RS M6
GM PAINTED GFX PACKAGE
ROTOFAB CAI, MUFFLERS DELETE,
CARBON FIBER LOOK EMBLEM OVERLAYS,
SIDE MARKER & REVERSE LAMP BLACK-OUT
20% TINT ON ALL GLASS EXCEPT W/SHIELD
NL PERFORMANCE DOVETAIL SPOILER,
GM HERITAGE PAINTED GRILLE'
MORE TO COME!!!!
ProstZ28 is offline   Reply With Quote
Old 11-07-2009, 10:24 PM   #6
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
do not start it till you can drive it, just leaving it idle will not get the oil up to operating temp, and will cause more condensation inside the engine. plus cold winter starts are hard on the engine
Old 11-07-2009, 10:30 PM   #7
OUR72GTO
OUR72GTO's Avatar
I am ........and so would our 100 VINTAGE members here. Some own cars worth a lot more than ours. Dont dust it either........ Just deal with it once next spring.
Old 11-07-2009, 11:25 PM   #8
Merc
In The Circle
Merc's Avatar
K How does the weather look for you on the 11th
Old 11-08-2009, 02:45 AM   #9
OUR72GTO
OUR72GTO's Avatar
We are coming down but the Coq is iffy for the 2010 on the 20's.
Had hoped to have 18's/19 by now.
How many are going? Convoy?
Old 11-08-2009, 09:12 AM   #10
Merc
In The Circle
Merc's Avatar
Not sure. Iam taking my Caviler. I don't see a break in the weather. Thinking about crossing Sumas border around 11.
Old 11-08-2009, 03:17 PM   #11
OUR72GTO
OUR72GTO's Avatar
Is it a for sure Scott will be there?
Old 11-09-2009, 03:32 AM   #12
OUR72GTO
OUR72GTO's Avatar
We can be at Sumas by 11. I Have to pick up at Package Express.
Will turn it into a casino run and stop for a night on the way back.
Any more going? Lets get a BC group picture with an Auto bot.
Old 11-09-2009, 04:26 AM   #13
Merc
In The Circle
Merc's Avatar
There is a Auto Show thread in the Canada section, maybe we should move this conversation there. Gone there.
Old 11-13-2009, 06:22 PM   #14
dan3511
Drives: 10 camaro 2SS & 07 Silverado LTZ
So I am going to put my girl away for the winter...in a climate controlled garage and covered. What are the recommendations......new oil, wash and wax, and what else?? Is it best to put it away and leave it for 4 months without starting it?? I need some advice from someone in the know??
dan3511 is offline   Reply With Quote
Winter Storage??? Help? Camo81 5th Gen Camaro SS LS LT General Discussions 3 10-12-2009 10:29 AM
Winter Storage November 1st BLAKMGIC Canada 17 10-07-2009 12:20 AM
Winter Car Storage jseese USA - Great Lakes 0 09-23-2009 03:45 PM
Moist garage floor - how to get it dry for winter storage tcd Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 11 08-18-2009 07:31 PM
Winter Storage 69Firebird USA - New England 0 05-18-2009 12:01 PM
