BORLA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Mid-Atlantic
Old 11-09-2009, 03:11 PM   #1
Infern0
Bring It
Infern0's Avatar
Drives: '17 Camaro ZL1 (M6)
Muffler Delete in NOVA Area?
Just looking for a good place to get this done. Anyone else do it around the NOVA area yet? I'm particularly in Woodbridge, but, shop doesn't have to be. The closer the better.
I went to one place and he wanted $200+ to simply cut the mufflers out and extend the pipe to the current muffler tips. Get outta here. This is simple.
Thanks in advance!
Infern0 is online now   Reply With Quote
Old 11-09-2009, 06:13 PM   #2
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
I did mine at Roberts custom exhaust in stafford. He did mine and rallyfever's back in May. A very nice shop. Let him know you were referred by Ernie. The iom car.
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 11-09-2009, 06:16 PM   #3
Infern0
Bring It
Infern0's Avatar
How much?
Old 11-09-2009, 06:22 PM   #4
edog
edog's Avatar
250
Old 11-09-2009, 06:59 PM   #5
Infern0
Bring It
Infern0's Avatar
Hmmm, that's about 23% of a full after market exhaust isn't it? Not sure if it would be worth it in this case...unless I want to wait a while but want good sound now. Thanks for the recommendation. I'll keep it in mind.
Old 11-09-2009, 11:09 PM   #6
RoyalKev
Drives: 2010 Camaro SS
Just do it your self, cut you muffler, clamp on some pipes have some one weld the tips on for you.
RoyalKev is offline   Reply With Quote
Old 11-10-2009, 06:26 AM   #7
FFPM73
Firefighter/Paramedic
FFPM73's Avatar
Drives: RJT 2SS/RS M6 LS-3
If you try too do it yourself it will look like it. I have a muffler delete and the guys who did it bent pipe upward and used the factory tips. They also replaced the "H" pipe with a Magnaflow Tru "X" pipe. Everything was welded, sounds awesome and you can not see any of the new exhaust from the rear of the car underneath.......The cost was $81.00 for "X" pipe and $65.00 for muffler delete with weld and another $20.00 to weld in "X" pipe. Total cost $166.00.......Easier than spending up to $1500.00 for a cat-back for the same sound. It is very deep and throaty, sounds like a 1st gen Camaro......
FFPM73
FFPM73 is offline   Reply With Quote
Old 11-10-2009, 08:32 AM   #8
Infern0
Bring It
Infern0's Avatar
Yeah I know doing it myself is out simply because of the need for bent pipe. That's why my favorite Corvette dealer (not a Chevy dealer) can't do it. $166 for all work AND an X-Pipe, now that's more like it. That would be awesome if I could find a shop to do that around here.
Are all X-Pipes the same or is there a specific diameter that you used? Same diameter as the rest of the pipes? Did you have to provide it or did they have one?
That's what I've heard, it is the same sound, if not better than most cat-backs out today, and what's more based on other threads here, there have been virtually no gains at all with cat-back systems on the Camaro. Camaro simply doesn't respond to them because the piping in place is already so good, only a few restrictions (H-Pipe and Mufflers). So with that said, you'd only be paying $1,500 for sound.
Old 11-10-2009, 08:47 AM   #9
FFPM73
FFPM73's Avatar
You are exactly right.....$1500.00 for sound. The shop that I used could order the pipe from another vendor but they wouldn't get for a few days. I ordered from Summit Racing and had it in a day. I had them do the muffler delete first just to see what the sound was like. I figured it was a lot cheaper than spending all the money for a cat back or even an axle back if I didn't like the sound. Anyway after the muffler delete was done, I went home and ordered the "X" pipe and had it installed the next day.......AWESOME. The "X" pipe gives the exhaust a more throaty sound especially at idle. If you go with what I did, I promise you will not be disappointed. :happy anim:
Magnaflow TruPipe, X-Pipe, Stainless Steel, Natural, 2.5 in. Diameter, Universal, Each
Part Number: MPE-10791
FFPM73
Old 11-10-2009, 12:03 PM   #10
Infern0
Bring It
Infern0's Avatar
Did you get a discount on the x-pipe? Shows $83 before tax and shipping...$93.90 in the end.
Old 03-15-2010, 04:15 PM   #11
Infern0
Bring It
Infern0's Avatar
Bump.
Anyone else get this done since I opened the thread? I got another quote from the guys across the street from Coopers Corvettes on Rt 1 and they wanted $300. Eff!
I met a guy with a red Camaro at a meet late last year who said he got his done on Rt 28, but the name of the shop he gave me (High Flow Customs) doesn't come up in any area searches. He said his ran about $200.
Edit: It was "Hi-Flow" customs, and of course it showed up right after I posted. I'll give them a call and see what's up. Anyone else?
Old 03-17-2010, 03:43 PM   #12
Infern0
Bring It
Infern0's Avatar
Quick Update: It looks like Hi-Flow Customs will do the muffler delete plus xpipe install for $275. Seems like it may be the way to go.
Old 03-17-2010, 06:13 PM   #13
thesnoopster
thesnoopster's Avatar
Drives: '10 SIM SS/A6 - '12 SIM Equinox LT
Where are they located???
2010 SIM Camaro 1SS/A6
Mods: "93 Octane and a baby seat..." TunedByFrost/EFI Performance,LLC @ PAS "You gotta love me ... or leave me alone"
Old 03-18-2010, 03:27 PM   #14
Infern0
Bring It
Infern0's Avatar
9043 Jerrys Circle, Manassas, VA‎ - (703) 392-6016‎ - his name is Scott.
He's having a hard time finding the pipe he needs though (mandrell bent 45 degrees). Seems kinda odd to me. Another odd thing was when I stopped by today to see if he'd had any luck, I saw him clamping together an exhaust for another customer.....I've got to make sure he didn't intend on that for my car too. I don't think he planned on it because this was a recommendation from another guy at our CiCi's meet a few months back who had his done there and his wasn't clamped. Guess we'll see if he can ever get the piping he needs.
Let me know if anyone has any other recommendations.
Anyone know a trusted muffler place to do a muffler delete in OKC area? KWinOKC USA - Southcentral 29 03-20-2010 12:10 PM
Muffler Delete or Aftermarket? JohnForeman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 11-01-2009 11:46 AM
DIY at home Muffler Delete for $20 CDBiker220 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 10-12-2009 06:32 PM
Considering a Muffler Delete, Straight Pipes or NOS in Ontario? Matster Canada 18 08-29-2009 03:41 PM
Muffler Delete with Dyno clips and pictures KK2010SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 07-26-2009 02:09 PM
