SDTW Custom Wheels & Tires
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 11-09-2009, 08:23 PM   #1
GQ4Life
Drives: 2010 Camaro SS LS3
interchangable
friend said he got a 305 and wants to use that tranny to mount to a LS1..
someone told him it would mount to a LT1.
inst LT1 and LS1 tranny mount the same?
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 11-11-2009, 07:47 AM   #2
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Most people who do LS1 swaps just use the tremec 6-speed thats already behind the LS1 (they pull them from wrecked cars) - I'm relatively certain that the t-5 from the third gens will NOT mount to a stock LS1. At least not without a different bellhousing/clutch/etc.
I could be wrong though - somebody else should weigh in on this.
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 11-11-2009, 07:49 AM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
what kind of transmission?
T5, T56, 700r4?
I piss excellence
and fart awesomeness
Old 11-12-2009, 08:25 AM   #4
Iroc-z86
Drives: 86' Iroc-z; 11' 2lt rs; 98' Jimmy
no thirdgen tranny (700r4, t5) will bolt up to an ls1. I THINK the lt1 because they left the block pattern the same... that is why people who want a t56 use 93-97 trans to put into a 3rd gen. For an ls1 you need an adapter plate, imo its easier to just get one from an lt1
Iroc-z86 is offline   Reply With Quote
Old 11-12-2009, 11:12 AM   #5
BlueZee28
BlueZee28's Avatar
Drives: 1991 Z28 convertible
There's a crank spacer (or block spacer, however you want to call it) that will allow you to use an older SBC style trans with an LS1. I'm not sure what would need to be done with the bellhousing though, I'd imagine you would have to swap it out with a T56 housing?
<>< Nick <><
LSX Powered
For More Pics Click:
http://www.omnipotent-goku.com/iroc/gallery/album140
BlueZee28 is offline   Reply With Quote
Old 11-13-2009, 12:31 PM   #6
Iroc-z86
not to mention... the t5 will never hold up with a ls1 in front of it. The 700r4 might take the abuse for a little while but i doubt it, well without some work.
