Old 07-17-2008, 01:27 PM   #1
ernie22golf
Drives: Looking
Looking at 2002 Z28 - What to check
I'm going to look at a 2002 Z28 this evening - It has 76K in miles - white in color with tan interior - has ground effects - no modifications - has sunshades for t-tops. I know this is not the original owner. Any problems common I should be on the lookout for? Any help appreciated. Price asking 9500.
ernie22golf is offline   Reply With Quote
Old 07-17-2008, 04:13 PM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Hmm... auto' or stick? If an auto', check that the smell of the tranny fluid is not burnt-like (like the smell of burning breaks.) Check the water pump. My brother replaced three water pumps on his car before 75K miles. I haven't read this is a common occurance anywhere so maybe his dealer is just crappy. Check for H20 leaks around the T-tops. Check for warped brakes. The rear pinion seal will probably be at least a little sweaty from leaking. I'd say check to see that the TSB on the knock sensors were squared away, but there's no easy way to check with the intake manifold on... Find out, if you're planning on keeping the cats' and manifolds, that the cat' TSB has been fulfilled. This is a pretty new TSB and I guess there were some problems in the past with them.
The price just sounds pretty low to me...
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 07-18-2008, 03:44 AM   #3
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Run the vin through carfax to see if it's been in any major accidents. Take it to a trusted mechanic or shop to look it over to check for the small stuff. If you don't know, let someone else do the looking for a couple bucks. It could save you a major headache in the long run.
Old 07-27-2008, 11:42 PM   #4
jm5877
jm5877's Avatar
Drives: 2002 Chevrolet Camaro (Black)
I can attest to checking on the first three points. I too just recently had a problem with tranny fluid leak on my '02 V6. Replaced water pump at 55,000 miles, and had all rotors turned because of warping a few months after purchasing the vehicle in Dec. 2005. If the car is equipped with factory Monsoon audio system, check that ALL speakers are working. I have had to replace every front and mid-range speaker in both my '99 Camaro and '02 Camaro. I suggest bringing along a disc that will properly test the sound system's abilities (bass). Ask the owner if he/she knows whether or not any of the window motors have been replaced, as this is another problem I have run into with two of my three 4th gen Camaros, as well as my Dad's '95 Camaro. It's usually the drivers side that goes out as it gets more use. If the motor is showing wear, it will be much slower than the passenger side while traveling back upward. A fresh alternator in the vehicle is also a good thing, most of the factory units were junk, I've replaced a couple in my 4th gens. Oh, the price seems pretty decent, there's an '01 Z28 for sale on a lot down the street from me with similar mileage in mint condition for $9,000.
Current Camaro:
2002 Coupe - V6 (Black/Ebony)
Previous Camaros:
1984 Sport Coupe - 4cyl (White/Blue)
1993 Coupe - V6 (Black/Charcoal)
1999 Coupe - V6 (Black/Charcoal)
Future Camaro:
2010 LT/RS Coupe - V6 (Black/Neutral)
jm5877 is offline   Reply With Quote
Old 07-28-2008, 04:51 PM   #5
-RO- Upgrade
-RO- Upgrade's Avatar
Drives: 3.4 v6, black CamaRO
Send a message via Yahoo to -RO- Upgrade
Ok question about that STS cause its turbo right & in the back can u see from under the hood? If not say I twin turbo it, then could I make it look like their is only 1 turbo? Oh & bout that LT1 from that man, forget that I just said Im going to get a new one. Yea its more money but I work hard for it...lol not really but Im going to spend it well So I found this site www.hotrodlane.cc where I can get a LT1 for 1700 but steel have to buy the harness & mount plate's & computer with some programs....lol but money is made to be spent...lol So I need halp with finding a transmission for this engine but I want something that can handel what im about to do to this block. If anyone has any site hit me up please. Oh i would have picture's of my car but I just got a new labtop & im not in my home state right now, away for work. Money Money Money!!!! Got to have it for all my baby, yes my CamaRO!!!
HELP
-RO- Upgrade is offline   Reply With Quote
Why do you think the Z28 is the higher tier? The_Blur Camaro ZL1 Forum - ZL1 Specific Topics 181 10-14-2009 09:08 PM
2009 LS3 Vette vs Top Dog Z28? Mblock66 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 07-14-2008 11:26 AM
Pricing/optioning guesstimate KILLER74Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 156 02-24-2008 05:33 PM
