12-08-2017, 07:09 AM | #1 |
Drives: 2013 ZL1 Join Date: Dec 2015
Torque Converter
I see phastek has a *new* torque converter out for the ZL!, 2600-2800. I have a BTR Stage 3 cam, headers...which the TC supposedly will wake up. I just run the streets so the question is am I going to notice a difference. Don't imagine the install is cheap plus I'll probably have to run some cooling lines? Appreciate any thoughts
12-08-2017, 08:28 AM | #2 |
Drives: 2015 Camaro 1SS L99 Join Date: Apr 2016
Just from the research ive done, if your car is an auto the 2600-2800 is too low for a stage 3 cam. You will likely need to look in the 3200-3600 range. Everyone says that its one of the best mods to do on your car and really wakes it up. However, I just elected to go with a GPI SS1 cam kit as I do not wish to replace the stall. This install at a shop would likely be a little more than a couple hundred bucks, and youre also supposed to run an additional transmission cooler as soon as you add a stall
12-08-2017, 04:46 PM | #3 | |
12-18-2017, 05:25 PM | #4 |
Drives: 2013 Camaro ZL1 Join Date: Nov 2012
$550 for a 2700ish stall converter with a billet stator!!!! that has my vote for street use all day long! Bargain! I'm going to look into this for my car. I still have the stock converter and trans in my car with 0 issues and I'm at 30,000 miles to date. Thanks for posting OP! Btw, I also run the street 99% of the time and this would be perfect. I've had every imaginable combo in this car and a slightly higher stall like this would get me right where I want to be.
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance 1000rwhp |
12-19-2017, 10:12 AM | #5 |
Would a stall converter affect a tuned car?
12-19-2017, 04:59 PM | #6 |
My tuner recommends some adjustments after the install of a converter so yes I guess so.
13 ZL1 A6
12-29-2017, 07:44 PM | #7 |
Drives: ZL1 Join Date: Mar 2016
I have a precision 2800 stall converter with the BTR3 cam. Not a single issue with driveability. The BTR3 blower cam is not as agressive as most seem to believe.
