Old 11-11-2009, 12:55 PM   #1
gghg
Drives: 68 RS, 2010 2LT
Spongy Brakes
Has anyone had spongy brakes on their Camaro? I have a 2lt auto with about 4400 kms, and under braking light or hard the pedal fells spongy. If I pump the pedal, even once it feels much firmer. To me it seems that there is a lot of pedal travel before the brakes become effective. Iím going to take it to the dealer but I want to see if anyone out there has had this problem and what was the issue.
gghg is offline   Reply With Quote
Old 11-11-2009, 12:59 PM   #2
zen
Drives: 2011 CTS CPE & 2010 2LT/RS CGM
I have the same problem that came about after my first hard brake application. haven't done anything about it yet. (2LT RS)
zen is offline   Reply With Quote
Old 11-11-2009, 05:58 PM   #3
CGM DIVA
CGM DIVA's Avatar
Drives: 2010 CGM 2SS/RS Camaro
Sorry to hear that.. I have had no problems... If anything, my brakes take VERY LITTLE pressure in order to stop the car... have to be careful of people behind me cause she'll come to a dead stop in a heartbeat! (2SS/RS M6)
2010 CGM 2SS/RS Ordered
"Silly imports, speed is for f-bodies"
CGM DIVA is offline   Reply With Quote
Old 01-02-2010, 10:54 PM   #4
Maclain
Drives: 2LT
Same Problem...
I drive a 2LT, have 3200 miles on it now, and I have felt the same "mushiness" in the brake pedal from the first mile I drove it.
Feels like the first several inches of brake pedal travel are just mush, and the brakes don't start grabbing until the pedal is about one-third or half-way down.
What is causing this?
Air in the brake lines?
--Mac
Maclain is offline   Reply With Quote
Old 01-03-2010, 01:13 PM   #5
flyby
Drives: 2010 Silver SS
I'd take it in to have it looked at. sounds like either bad pads or air in lines. could be some kind of defect or another.
flyby is offline   Reply With Quote
Old 01-03-2010, 01:19 PM   #6
Orange5thGen
Orange5thGen's Avatar
Drives: 2011 Convert
Send a message via Yahoo to Orange5thGen
I have the same issue! Going to get it checked out.
Orange5thGen is offline   Reply With Quote
Old 01-03-2010, 01:52 PM   #7
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Hmm I'd take it to dealer and have them make sure the brakes aren't bleeding out by chance.
On another note, you may just not have properly bed-in your brakes (or burnishing) since it is a new vehicle.. yes brakes even need a proper brake in.
For more info check here on how to Bed-in brakes: http://www.essexparts.com/learning-c...rs/post/Bed-in
This should solve the problem about 90% of the time.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 01-03-2010, 01:53 PM   #8
Orange5thGen
I even reported this issue on the survey, Dealer has said and done nothing about this as of yet.
Old 01-03-2010, 01:56 PM   #9
Ject
aka Patrick
Ject's Avatar
Refer to my previous post... I would doubt anything is wrong with the brake boost system or brake lines since the car is so new. There very possibly could be something wrong such as air in lines.. but it's highly unlikely. My bets are on the fact that the compound on the rotors has worn off due to braking and never having a proper bed-in of the brakes.
Hope info above helps
Old 01-09-2010, 10:25 AM   #10
Maclain
Drives: 2LT
Thanks for the info Ject. I looked at the link, and I will do that soon, but the brakes grab well once the brake pedal is about 1/3rd to 1/2 way down, and it is just the "travel" of the brake pedal up until the point of engagement that I do not like.
Do people put steel/kevlar braided brake lines on cars like we did years ago with racing motorcycles?
-- Mac
Old 01-09-2010, 04:04 PM   #11
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
-- Mac
They do sell SS lines for the Camaro. Typically the OEM rubber lines won't flex a whole lot when new. If they are that spongy new, I'd doubt SS line would help a lot. It should help a little though.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-11-2010, 12:27 AM   #12
Chris_B
Chris_B's Avatar
Drives: Several
I'm not sure if your car has a specific issue beyond normal sponginess, but stainless steel braided brake lines are a noticeable improvement. A quality set (like Goodridge) will reduce line swell by about 99% per the lab test data I've seen (regardless of the OE rubber lines' age). They also improve ABS performance by reducing bounce-back. They also eliminate the moisture that is slowly pulled in through the rubber lines.
Kevlar is not necessary as brake lines pressures aren't high enough to justify the extra expense. Those are best for applications with big spikes in pressure, like air jack lines on a race car.
All that said, if you are getting too much pedal travel before the brakes start to actuate, I would suggest having the system bled again. Just a small air bubble can cause trouble. Don't bet just because the car is new that there can't be one little air bubble in the system. If you've been on a car assembly line, you know what I'm talking about. It happens.
Chris
Chris_B is offline   Reply With Quote
Old 01-13-2010, 04:18 AM   #13
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
my car has also felt like this from day one. I test drove an SS and the brembos felt NICE. Instant grab, the V6 brakes me feel unconfident about the braking power of the car even though its great.
This is one of the things that has bothered me about the V6 Camaro since day one
The exact words i used was mushy as well when i described it to friends.
Hope we can get a fix for the mushy feeling. Its obviously no defect since it seems like a v6 thing only.
Hopefully theirs a solution to it
Drum brakes hard to beat KILLER74Z28 General Automotive + Other Cars Discussion 17 02-16-2012 01:40 PM
Spongy Brakes gghg Camaro Price | Ordering | Tracking | Dealers Discussions 1 11-11-2009 12:46 PM
question about brakes Fotowns Finest 4th Generation Camaros 12 11-05-2009 05:09 AM
Brembo Brakes ChevyBoiSS Wheels and Tires Talk Sponsored by The Tire Rack 15 02-03-2009 08:23 PM
EWB Electronic Wedge Brakes KILLER74Z28 General Automotive + Other Cars Discussion 10 11-13-2006 01:12 AM
