Solo Performance
Old 12-31-2017, 11:52 AM   #1
03worthy4link
Drives: Nil
Oil pressure at WOT?
So I noticed that my ZL doesn’t ever seem to eclipse low 50’s in oil pressure, even at WOT. I’ve always practiced the standard that 10psi per 1k rpm is minimum but have seen pressures regulated to less by design. Just wondering if this is one of those applications or if I should start snooping around. What are you guys seeing at WOT?
03worthy4link is offline   Reply With Quote
Old 12-31-2017, 02:36 PM   #2
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
I see about the same, a couple of lbs less since installing an external oil cooler. I would guess, though the general rule of 10 lbs per 1000 rpm is considered normal, our stock pumps can only create so much pressure. Guess they top out at just over 50+lbs....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is online now   Reply With Quote
