Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 11-12-2009, 10:59 PM   #1
Drives: 2SS
General engine/transmission noise?
What's everyone's general sense of how "noisy" the engine should be? I'm not talking about general engine rumble, wind noise or dash squeak or rattle. More like a rattling that seems to orginate down under shifter when at low idle in lower gears. It also clunks fairly heavily when pushing the clutch in/shifting into neutral. Just wondering how much is "intentional" on the part of the designers, trying to make it sound rough, vs. whether there is a mechanical problem. I hate the thought of taking it in for service already.
Zaphod is offline   Reply With Quote
Old 11-13-2009, 12:20 PM   #2
Drives: Future ZL1 Owner
I'm going on the assumption you have a manual trans in your car. I don't own a Camaro yet, but I can say that from owning V8-powered GM and Ford products over the years that I've seen more forum posts on noises and problems problems from manual cars than autos. I believe this is the nature of the trans and hearing syncro/bearing noises are part of it along with clunks from driveline slack. I doubt any of it is designed intentionally into the car and I'm sure the designers actually would make it quieter if they could.
DangerZL1 is offline   Reply With Quote
Old 11-20-2009, 06:04 PM   #3
Drives: 2010 SS/RS
Mine is also very noisy. I went to the dealer and drove another manual car and it was the same exact way. I guess its normal. BUT, I do not like it. I have driven stick vettes and they do not do this. Probably a first year thing. Maybe I should have waited, other than that I am happy for the most part.
Mrhavasu is offline   Reply With Quote
Old 11-20-2009, 06:31 PM   #4
some Camaro MN6 transmissions have more slop in the tranny linkage than most and more slop results in detectable noise from vibration.
Old 11-22-2009, 09:16 AM   #5
deadlyarcher72's Avatar
Is this a problem to be concerned with? I was planning on replacing my clutch with a hurst. Would replacing the clutch make the noise better or worse?
deadlyarcher72 is offline   Reply With Quote
Old 12-02-2009, 09:37 PM   #6
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
mine is a bit noisy!
car runs like a champ. Ive done one single pass at the track (didnt even do a burnout) to see what the car would run and have not done one single full out pass since. I dont drive the car hard but ive always noticed its that its a little noisy. Its not the engine. I sounds like its the release bearing. I can live with it for now i guess.
sixty9fordkiller is offline   Reply With Quote
Harmonic noise inside at 60 - 70 mph camdaddy 5th Gen Camaro SS LS LT General Discussions 30 06-16-2010 09:23 AM
ticking noise and high pitched hum strshp5 5th Gen Camaro SS LS LT General Discussions 13 10-21-2009 04:04 PM
QC missed something-- AC Compressor making a whining noise under engine load Kyle.Gilmour Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 10-09-2009 10:42 PM
Weird Air-Leaking noise... a_Username Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 09-03-2009 09:25 AM
