Solo Performance
Old 11-14-2009, 01:24 PM   #1
Dentyneice
Drives: 2010 Camaro 2ss
rear differential fluid drain/fill plug location
Anyone know where the drain and fill spots are for changing out the rear differential fluid? I see 2 additional plugs by the oil drain plug but don't know what those are
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal
Dentyneice is offline   Reply With Quote
Old 11-15-2009, 07:58 AM   #2
FirstLSK
Dude, I love my car !!!!
FirstLSK's Avatar
Drives: 2010 Black 2SS/RS white rally
View on the picture is from the drivers side rear wheel...
Just use your 3/8 ratchet.
FirstLSK is offline   Reply With Quote
Old 11-15-2009, 12:23 PM   #3
2SSjack
2SSjack's Avatar
Drives: 2010 2SS Camaro;
The plugs do not use sealant but do have a rubber gasket. Be carefull they don't slip off when you clean the muck off of them.
2SSjack is offline   Reply With Quote
Old 11-20-2009, 11:36 AM   #4
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Hi, I am trying to change my differential fluid and don't seem to have the correct Allen or Torx heads. Can you please let me know what size they are and if the drain size is the same as the fill plug?
Thanks!
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 11-20-2009, 12:34 PM   #5
Michael_Js
Michael_Js's Avatar
Ok, got it! Thanks guys! it was the end of the 3/8" ratchet (didn't understand the answer was already in this thread!)! Torque: 24 lbs. My service guy had also gotten back to me. Easy change to do, even with the Zoomer's exhaust!
Thanks again!
Michael J.
Old 12-14-2009, 12:25 PM   #6
amphi
Drives: 2SS Imperial Blue
How much needs to go into the differential? exactly one quart? or one quart plus 2.5oz of friction modifier. I don't understand the manual very well. Seems they want you to add 2.5oz to the specified capacity, but would it then overfill? Thanks.
amphi is offline   Reply With Quote
Old 12-14-2009, 01:27 PM   #7
Michael_Js
Michael_Js's Avatar
Just the 1 qt. total. You can't overfill it as it will just run out the fill hole. If you use Royal Purple, it already has the friction modifier in it. If you use something else, I suggest putting the friction modifier in first (since it comes in a very small container) then adding your Diff oil last.
Old 11-27-2010, 10:54 AM   #8
midnighter
Drives: nothing
Hmm, is there any special instrument neccessary for getting the axle fluid into that fill plug?
Old 11-27-2010, 11:02 AM   #9
camaro52010
Camaro4ever
camaro52010's Avatar
Drives: 2010 Camaro SS/RS, 1978 Z28 Camaro
The 1 qt bottle will fit into the space horizontally as you squeeze the bottle, no pump needed, use the whole qt fluid will just start to run out the fill hole if car is level, reinstall plug, don't over tighten, you are done. 45 minutes.
camaro52010 is offline   Reply With Quote
Old 11-27-2010, 11:54 PM   #10
midnighter
Drives: nothing
Ok, thanks a million.
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 380 11-06-2017 05:38 PM
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
How many have changed the rear end fluid? fieldgoal00 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 5 08-21-2009 11:44 PM
Urgent - How to drain/fill rear-end fluid RickyTheStorm Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 27 07-12-2009 04:30 PM
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 02:11 PM
