Old 11-14-2009, 02:40 PM   #1
general23cmp
Drives: 2010 RS SS
changing injectors, how does my dash display calculate fuel economy
I'm going to be changing fuel injectors soon (and the computer's parameters accordingly). I was just wondering how the fuel economy display on my dash calculates its value. Will it be forever wrong after the swap, or will it use the new injector parameters in the ECU?
general23cmp is offline   Reply With Quote
Old 11-15-2009, 12:26 PM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
not sure if just the inj size/scaling tables will effect the cluster mileage calculation,, i do know that after i tuned my VE table the fuel mileage is no longer even close in the cluster
Old 11-15-2009, 01:10 PM   #3
general23cmp
Drives: 2010 RS SS
Yep....some folks are reporting huge MPG gains when doing forced induction and such, but I fear they are relying on their cluster.
Old 11-15-2009, 01:18 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
It's impossible to get HUGE MPG increases, especially when going FI. The best you can hope for is the same or maybe a tad more from a better tune. Obviously, this is footpedal dependent as your MPG will DROP MASSIVELY when you spool it up. I could damn near watch my gas gauge drop when I was racing my 500whp turbo talon, yet got 26mpg cruising down the highway. That's about what they get in stock form.
Old 11-21-2009, 03:07 PM   #5
Matt TuneTime
Drives: 2008 G8 gt / 2010 Camaro L99
This is all base on all of the injector flow data . Make sure it's correct .
Matt TuneTime is offline   Reply With Quote
Old 11-23-2009, 09:49 AM   #6
Steve@Vectormotorsports
Drives: Firehawk
X2
Steve@Vectormotorsports is offline   Reply With Quote
Old 11-26-2009, 08:51 PM   #7
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
I've driven over 2000 miles after the Vortech install and 66# injectors.
I reset the mpg in the DIC before my trip to AZ and kept my gas receipts
for the 1300 mile trip. My actual mpg's were within .2 mpg of the DIC display.
So I'd say that the DIC is not effected by the change.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 11-27-2009, 12:16 PM   #8
camaro1
camaro1's Avatar
if you adj your virtual VE table your dic will not read correct
Old 12-03-2009, 03:35 AM   #9
DallasPerformance
Drives: 911
Not sure how it works on these things. However it doesn't work that way on the vettes. It uses IPW or IDC to calculate mileage depending on year model. No way to alter that to reflect correct values in the display.
DallasPerformance is offline   Reply With Quote
Old 12-03-2009, 09:24 AM   #10
Matt TuneTime
If your Injector Data is off , not just the flow rate. Then your DIC will not read right [ your IPW or IDC will be off also ]. If all of the injector tables are correct for your Injectors [ The company would have had to publish the data AKA ford motorsports ] Then your DIC will be very close, even with a 79 lb injector ...
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
Bob Lutz, and Scott Settlemire on fuel economy. Mr. Wyndham Off-topic Discussions 19 11-18-2007 03:01 PM
Fuel Economy Estimates? LSxcellent Off-topic Discussions 21 07-05-2007 09:33 PM
New Job Openings at GM (Fuel Economy Research) TAG UR IT General Automotive + Other Cars Discussion 3 04-14-2007 12:18 PM
