BeckyD @ James Martin Chevy
Old 03-26-2012, 01:49 PM   #141
JoeyB
JoeyB's Avatar
Drives: 2010 Camaro SS
new best
Vortech V-3 Super Charger
American Racing Headers
Borla Cat Backs
GT-9 Cam
Torque Converter / Yank SS 2800
17" Bogart Drag Wheels
Hoosier slicks / MH skinnys
60'- 1.699 1/4- 11.086 @ 126.28
JoeyB is offline
Old 03-27-2012, 06:46 PM   #142
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Originally Posted by TBone View Post
Ok, so I punched my numbers into Dragtimes DA calculator and came up with the following numbers. So with a mildly modified NA car the correction should be 12.365 @ 117.291. That should move me up the Unofficial list, right? Assuming I did this right.
27. TBone - 12.401 @ 116.85 mph, (LT, Exhaust, CAI, PTB, Tune, DRs), (LS3, M6)
Correct your ET and MPH using the DA (Beta Testing)
Density Altitude: -9 feet above sea level
1/4 mile ET: 12.401 seconds
1/4 mile trap speed:116.85 MPH
Stock and Mildly Modified Naturally Aspirated Engines
12.365 @ 117.291 MPH
Extensively Modified Naturally Aspirated Engines
12.365 @ 117.294 MPH
Extensively Modified Supercharged and Turbocharged Engines
12.364 @ 117.299 MPH
T.
I'll go with it because Dragtimes comes up with it. But with a negative DA your time should correct to a slower time than you actually ran. But for some reason Dragtimes has problems correcting times around 0 DA. But that's what were using I'll give it to you.
SGOS252382 is offline
Old 05-06-2012, 07:33 PM   #143
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
New Personal Best DA Corrected
DA Corrected run at +3578 DA = 12.10 @ 116.3 (Mildly Modified N/A)
M6 Trans
Tires used on the pass: 315/35/20 Invos
Performance Mods (if any):Cam, LT, Exhaust, CAI, PTB, Gears, Tune
Category submitted for: Internal Engine Mods plus Bolt-Ons
R/T..........
.5126
60'............. 1.90
330'........... 5.3798
660'........... 8.1932
660’ mph... 88.06
1000'.......... 10.6188
1320'.......... 12.6592
1320’ mph… 111.17
Name of the track: Kansas International Dragway (KID) Wichita, KS
Date of pass: 5-5-12
Weather conditions: (include Density Altitude, if known): Track Elevation 1305 ft, Air Temp 80.1, Barometric Pressure 29.68, Humidity 76%, DA 3578, Relative Density 89.94%
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline
Old 05-10-2012, 07:35 PM   #144
Invictus24
Drives: 2010 Camaro 2SS/RS LS3
New Best DA Stock 1/4 Mile Time as of 5/9/2012
Hello everyone,
I had the best run in my 2010 Camaro 2SS at Bandimere Speedway on 5/9/2012. I believe I beat the current DA Stock record according to this thread. I ran a 13.862 at 102.38 MPH. According to the DA calculator link above, that makes my run 12.415 @ 113.82 MPH. I have attached the slip and other proof of the run. Thanks and I hope it is worthy.
Invictus24 is offline
Old 05-10-2012, 07:43 PM   #145
Invictus24
Invictus24 DA Calculations
These did not post for some reason on my last post. Here they are.
Old 05-11-2012, 05:57 PM   #146
SGOS252382
SGOS252382's Avatar
That sure is some DA. I got you up on the list.
Old 05-12-2012, 11:35 AM   #147
Invictus24
Awesome thanks! It was an awesome run for my stock LS3 for sure.
Old 05-13-2012, 09:42 AM   #148
rforbes
rforbes's Avatar
Drives: IOM SS/RS
Track: Texas Motorplex 5/12/12
Temp 76F Humidity 86%
Car: (L99/A6)
RT:.162
60 Ft 1.59
330 4.634
1/8 7.157
1/4 11.186
123.01 MPH
rforbes is offline
Old 05-13-2012, 09:48 AM   #149
SGOS252382
SGOS252382's Avatar
Car: (L99/A6)
RT:.162
60 Ft 1.59
330 4.634
1/8 7.157
1/4 11.186
123.01 MPH
I need a complete list of mods (peformance mods, tires, wheels, etc) so I can add you to the appropriate 1/4 mile list.
This is also the "unofficial list." You probably wanted to add your slip to the "official" 1/4 mile list.
http://www.camaro5.com/forums/showthread.php?t=21013
Old 05-14-2012, 08:58 PM   #150
sschevybear11
sschevybear11's Avatar
Drives: 2011 Black 1SS
New bolt on run. LT's, no cats, pulley, Roto-fab, Jannety mail order tune with stock tires.
Cordova dragway park may 11 at 5:34
60' 1.915 best I've ever done
330' 5.385
1/8 8.232
1/8 MPH 86.88
1000' 10.633
1/4 12.626
1/4 MPH 113.3
dragtimes calculates at that time the DA was 2244' and converts to a
12.29@116.4
I did get a stock time of 12.75@110.9 in 42* and right at sealevel DA
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir
1989 Silver 5.0 Mustang LX Coupe
1999 Pewter Tahoe LT
2011 Blue Camry SE
sschevybear11 is offline
Old 05-18-2012, 11:17 AM   #151
Chris@Livernois
Chris@Livernois's Avatar
Drives: 2010 Camaro
Midgard/Livernois - 10.05 @ 138.92 mph, (419 cid, Supercharger, Cam, LT, Exhaust, 3.45 gears, Slicks/Skinnies, (L99, A6)
Track: Milan Dragway 5/17/12 1:26 PM
Temp 64F Humidity 36%
RT:.3651
60 Ft 1.508
330 4.212
1/8 6.481
1/8 MPH 108.47
1/4 10.052
138.92 MPH
-Rick
Chris@Livernois is offline
Old 05-19-2012, 06:40 PM   #152
silverfox
silverfox's Avatar
Drives: 2010 camaro ss
427ci procharger f1r,cam,heads,6l80e
[SIGPIC][/SIGPIC]Va.Speed built 427 stroker
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles.
Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump.
907rwhp.
silverfox is offline
Old 05-20-2012, 01:57 AM   #153
Merc
In The Circle
Merc's Avatar
This pass should move Pumpkin a few spots up the bolt on list. DA 818' as per Performaire weather station.
ARH LT's, Vararam, ACT/Stillen, BMR, DSS, JRE/LPE diff, Bogarts, Hoosier slicks anf skinnies.
Merc is offline
Old 05-21-2012, 05:28 PM   #154
SGOS252382
SGOS252382's Avatar
Based on Dragtimes.com (which we use for the unofficial list) the DA was a negative -237 ft. Air temps were in the 50s (excellent for racing). I'm not sure why Performaire weather station would have +818 ft.
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3453 Yesterday 02:39 PM
Camaro Laws ChevyNut Off-topic Discussions 107 11-09-2016 06:40 PM
An interesting Camaro (and GM) story! I just bought my 2010 Camaro! Camarodriver Camaro Price | Ordering | Tracking | Dealers Discussions 12 11-28-2010 04:52 PM
