sjm autoprod
Old 09-08-2010, 05:12 PM   #71
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Originally Posted by Silver2SSRS6spd View Post
My best run on stock engine and sways and trailing arms. Should improve next time with new drag radials. I'm the car on the left. DA corrected to 13.171 @110mph.
Your sig show rotfab CAI. Where you using an aftermarket intake?
Stock list needs to be 100% factory stock (just like the car came from the factory).
Any weight removal (lighter weight parts or removal) or mods to increase performance put the car in the Bolt Ons list.
SGOS252382 is offline
Old 09-18-2010, 02:59 AM   #72
Heliwrench
Heliwrench's Avatar
Drives: 2010 Black 1SS
LS3 M6 - CAI, LT's, Exhaust, Tune
12.82 @ 112.3 at 1780' should equal 12.562 @ 114.66 corrected according to dragtimes.
2010 Black 1SS LS3 M6
Power: Kook's 1 7/8" Long Tubes and 3" Exhaust, Injen Full Length CAI, Jannetty Tune
Drivetrain: MGW Short Shifter, Street Slayer Twin Clutch, DSS 1 Piece Aluminum Driveshaft, DSS 1000HP Axles, BMR Pro and Delrin Diff Bushings
Suspension: BMR Trailing Arms and Bushings, FE6 Swaybar Conversion With Pedders 27mm Front and 32mm Rear ZL1 Swaybars and Links
Chassis: Hotchkis Chassis Max Brace, BMR Pro Cradle Bushings
Exterior:: Shine by Adam's.
...and plenty more
Heliwrench is offline
Old 09-18-2010, 12:50 PM   #73
Speed74SS
Speed74SS's Avatar
Drives: 2010 LPE 650+ CTS-V
Car is a LS3 / M6
Tires used on the pass: 20" DR
Performance Mods: (TVS2300,CAI, TUNE, DR, 3.70 gears)
Category submitted for:Forced Induction
R/T.......... .2068
60'............. 1.957
330'........... 5.245
660'........... 7.939
660’ mph... 90.56
1000'..........
1320'.......... 12.143
1320’ mph… 117.00
Name of the track: Thunder Valley Dragways
Date of pass: 9/17/2010
Weather conditions: (include Density Altitude, if known): DA 1920
Corrected to: 12.051 @ 117.903 MPH
Name:  Camaro Wheels.jpg
'10 CTS-V : LPE 650+ Package 587hp / 582tq
2.55 Upper / 8.6 Lower / ID850's / Kooks Longtubes / New Era CAI
Speed74SS is offline
Old 10-10-2010, 02:58 PM   #74
Monte
Drives: '88 Monte Carlo SS, '10 Camaro SS
Just a note on my stock time....i went 110mph, not 119
-Chris
'10 Camaro SS
'88 Monte Carlo SS
Monte is offline
Old 10-10-2010, 04:05 PM   #75
SGOS252382
SGOS252382's Avatar
Thanks, I fixed it.
Old 10-26-2010, 02:31 PM   #76
KP MOVN
"Keep Movin With Kellie"
KP MOVN's Avatar
Drives: 2010 VR 2SS/RS
Originally Posted by PnCRedJwl2SS View Post
Here's my best time as of 14 Jul 10. It was on my eighth run that night (I know...crappy RT--I'm working on it!).
I've been to the track twice now. Both times, the temps started out in the mid 90's, then dropped to about 87 degrees or so when I got my best times. My previous best time (last week), was as 13.55 seconds. This time, I squeaked out 13.52 seconds. I've only added a Roto-Fab CAI. No other performance mods or tune.
I used the dragtimes site to correct the times. My time corrects to a 13.12 seconds @ 107.91 mph with a DA = 2553. Not bad, eh?
Just looking at different times on C5 and I recently ran 13.4 in the 1/4 mile with a .006 Reaction time. I was mainly working on my reaction time and I was proud of that. My car only has a CAI and flowmasters. I am going to the Camaro Nationals in Sealy this weekend to see if I can get better times.
"I love Monday's!"
KP MOVN is offline
Old 11-09-2010, 11:31 PM   #77
assasinator
1 n the head,2 n da chest
assasinator's Avatar
Drives: 2002 cadillac deville
deleted.
2011GT E85, Kooks 1-7/8", 3" offroad X, 2-7/8" overaxles, Roush mufflers, CobraJet intake, SCJ monoblade throttle body, drew 4.5" CAI, Boss302S exhaust valve springs, Baby CobraJet exhaust cams. 3.73 gears, lightweight 300A. 455rwhp @7800/410rwtq SAE 5000lb roller dynojet
assasinator is offline
Old 01-11-2011, 03:35 PM   #78
Camaro21
Drives: SOLD - 2013 M6 ZL1
LS3/M6, Cam, Headers, CAI, TVS2300, Gears, DR's, Tune
Category submitted for Power Adders:
R/T............365
60'.............1.816
330'...........4.866
1/8...........7.356
1/8 mph...99.41
1000'..........9.484
1/4..........11.267
1/4 mph…126.46
Name of the track: Dallas Raceway, Crandall, TX
Date of pass: 1/08/2011
Corrected to: 11.245 @ 125.817 MPH
Camaro21 is offline
Old 01-11-2011, 05:27 PM   #79
SGOS252382
SGOS252382's Avatar
R/T............365
1/8...........7.356
1/8 mph...99.41
1/4..........11.267
1/4 mph…126.46
What was the DA for your run? I like to add that information to the list. Your DA must have been pretty good, because your time didn't change much.
Thanks
Old 01-11-2011, 05:32 PM   #80
Camaro21
Thanks
According to Dragtimes.com it was -176
http://www.dragtimes.com/da-density-...e=Calculate+DA
01/08/2011 at Dallas Raceway at around 6:08PM
Camaro21 is offline
Old 02-20-2011, 10:36 PM   #81
jasycz28
J.Sick
jasycz28's Avatar
Drives: 2010 Camaro SS
I have a 2010 2SS LS3 lowered with a short shifter and stock tires. So I am not sure which section I will end up in. I would think stock. DA in Tucson sucks. Corrected it puts me at 12.41 @ 117.41. For the DA calculator, do you go off the info on your time slip for temp, baro, and humidity or do you get it off of what he website says? I used the data from the time slip. Let me know if you have any questions.
"J.Sick"
2010 Camaro 2SS
jasycz28 is offline
Old 02-22-2011, 09:36 AM   #82
SGOS252382
SGOS252382's Avatar
I think the tracks air pressure is off and that might be why the time is so fast with a crazy trap speed.
When I use dragtimes to look up the track SIR for Feb. 5, 2011 (9.55 am - closest reading time to your run) your Denistiy Altitude was 2788 ft. That corrects your 13.39 @ 108.98 mph to 12.945 @ 112.809 mph.
I went a head and added your time based on the information provided by drag times track locator look up. That's what I use for "unofficial" times.
Also, after careful thought I'm going to have to count your car as a bolt on car. The short throw shifter can definately shave some time off a car. And for the 1/4 mile list stock needs to be stock (the way the car came from the factory).
Old 02-22-2011, 10:26 AM   #83
jasycz28
J.Sick
jasycz28's Avatar
That's also a lot more realistic and still a real fast run for stock.
Ok sounds good.
"J.Sick"
2010 Camaro 2SS
jasycz28 is offline
Old 04-06-2011, 12:06 PM   #84
MAD600SS
Bayou City Muscle Cars
MAD600SS's Avatar
Drives: 2010 Camaro SS/RS 427LSX w/ 2 Kits
Drag Time - Unoffical
L99-A6- Magnacharger S/C, Nitrous, Cam, CAI, LT, Exhaust, Converter, DR's, ARD Heads, ARD Tune, Converted to LS3
CCW Classic - 5" x 17" front, 12" x 18" rear, P185/55R17 M&H Racemaster, P345/35R18 Mickey Thompson ET Street
REACTION -0.1738
60 FT 1.7138
330 FT 4.6234
1/8TH ET 7.0121
1/8TH MPH 102.83
1000 FT ET 9.0558
1000 FT MPH n/a
1/4 ET 10.7866
1/4 MPH 129.91
Blower & N2O
MAD600SS is offline
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3448 01-15-2018 12:30 AM
Camaro Laws ChevyNut Off-topic Discussions 107 11-09-2016 06:40 PM
An interesting Camaro (and GM) story! I just bought my 2010 Camaro! Camarodriver Camaro Price | Ordering | Tracking | Dealers Discussions 12 11-28-2010 04:52 PM
