Old 11-15-2009, 08:56 PM   #1
mousemotor
Drives: 2010 camaro ss,pontiac G6
what tool to remove manual tranny plug
didnt get a good look at it but what do you use to remove the drain plug on the manual v8 tranny
mousemotor is offline   Reply With Quote
Old 11-15-2009, 09:05 PM   #2
rodimus prime
Drives: Cargo van.
Im just guessing because I havent seen it, but I would say a 3/8ths ratchet like most tranny plugs.
rodimus prime is offline   Reply With Quote
Old 11-16-2009, 07:06 PM   #3
2SSjack
2SSjack's Avatar
Drives: 2010 2SS Camaro;
Correct! Any 3/8ths ratchet will do, the plugs are pipe thread (1/2" NPT I believe) and there is some form of sealant on them. just clean them and re-seal with thread compound; NOT TOO MUCH! Trans case is aluminium so don't go crazy tightening them. I would up using a plastic funnel with a flexible spout that I added a piece of 3/8" fuel hose to and snaked the hose down between the master cyl. and firewall, then between the exhaust and transmission case and finally into the fill hole! As long as it is downhill all the way it will fill. Also the owner's manual says 4.2 quarts, but I drained about 3.5 or 3.6.
2SSjack is offline   Reply With Quote
6 Speed Manual Tranny zzz28zzz 5th Gen Camaro SS LS LT General Discussions 29 12-30-2008 01:54 PM
Remote Start Available for the Manual Tranny? Rodrunner 5th Gen Camaro SS LS LT General Discussions 36 12-30-2008 11:35 AM
6-speed Manual Specifications (SS) Tran Wiki 0 10-19-2008 02:01 PM
Automatic faster than the manual??? 2sharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 319 09-30-2008 10:20 AM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 06:11 AM
