| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
Retired, Cancer Survivor
Drives: 08 Vue, 12 CAMARO 1LT Join Date: Dec 2007
Warping brake rotors
I found out last week that the biggest reason for warped brake rotors today is improper tightening of the lug nuts.
The wheels on my HHR started vibrating evey time I put on the brakes just after I had new tires put on it, I took it back to the tire store and they checked and said everythig was fine.. well the more I drove it the worse it got. I talked to a friend of mine and he said that he read that in most cases if your wheels vibrate when you put on your brakes your rotors are either warped or have hot spots., well since it never did this before I got new tires he said that I needed to check the wheel torque. I got a torque wrench and started checking at the 100 Ft LB setting the Owners manual said. I found 3 lugs were less than 100Ft. lbs, and 2 were over 100 by at least 20 ft lbs. that was on one wheel, the other I foune one lug nut was hardly over finger tight, and the other 4 were all different.. I loosened them all up and retightened them correctly the way you are supposed to , the vibration was still there, so I assumed the rotors were already warped too badly. I bought me a new set of high performance cross drilled and slotted rotors and new Ceramic pads and installed them Saturday.. Man what a difference... I followed the manufacturers of the rotors and pads break in procedure and now my HHR stops better than ever.. So you need to insist that your wheels always be torqued to the proper level and NEVER let them use an air impact wrench to tighten them.
Live for today, yesterday is gone and tomorrow may never come. Drive and enjoy your Camaro
The BIRD is the WORD! 323HP Worth of ANGRY BUY FROM BECKY D@ Rodgers Chevrolet |
I am the internets.
I use an impact wrench every time I take my wheels off and every time I put them back on. No problems here.
what year is your car? most cars nowadays use a separate rotor that is held on by the wheel/lug nuts. easily removed by taking the wheel off and the caliper, they will just slide off the wheel studs..
#4 | |
Just went to this website http://newcarbuyingguide.com/index.p...318/event=view and they say this:
#5 | |
Drives: Several Join Date: Nov 2009
Chris |
#6 |
![]() Drives: 1969 Corvette Join Date: Dec 2009
the key points are to torque the lug nuts in a star/cris-cross pattern and to have them at consistent torque. What torque they're at matters less than whether or not they are torqued evenly.
#7 | |
![]() Drives: 09 Vette GT1, 06 350Z, 82 MSE Join Date: Jul 2009
You CAN use an impact IF you have torque sticks to use with the impact gun. They work and they are consistent. Using an impact without a torque stick is asking for warped rotors and installing lug nuts without using a torque wrench by hand is also asking for warped rotors. It isn't a matter of what you use to put on the lug nuts...it is how the tool is used. |
#8 | |
#9 |
#10 |
SoCal C5 Family Member
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M Join Date: Jul 2009
Mine were last done at a shop - impact wrench. I just went through them this morning with my torque wrench and about half were below 140 ft lbs. Had to get her ready for the track tomorrow so now, she's ready!
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; Subthump; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers; |
#11 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
I am never in that much of a hurry that I have to use an impact wrench to install my wheels. I always use a torque wrench and tighten in a criss-cross patern not getting to full torque until three or four rounds of tightening at increasing torque measurements.
Heritage Grill, Cold Air Inductions Intake, Elite Engineering Catch Can, BMR 1" Lowering Springs, Sway Bars and End Links, Clear Image Jet Hot Ceramic Coated headers and High Flow Cats, Hurst Billet 2 Shifter, LSR Billet Strut Washers, DynoMax Axle Back Exhaust, JANNETTY MAGIC! |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Accord Join Date: Oct 2009
I've let Gateway tire know how I feel about their toruge stick usage after finding my lug nuts at varying amounts of torque that were much higher than spec. The salesman told me that they stopped using them and only use torque wrenches now.
#13 |
I'm real anal about this one. I had a "competent" shop install new tires on a custom car I built up about 25 years ago. Got on the freeway and up to 65 or so and the right rear wheel started to come off. I nearly wiped out a highway patrol car as well as mine as I fought to keep her under control. Only one loose lug nut was still holding it on. Two lug nuts were missing and two studs had snapped off. I'm the only one that has torqued my wheels since -- by hand, in a progressive star pattern and with a well-maintained and occasionally calibrated Snap-On torque wrench. Call me crazy, but I've never had a repeat occurrence on the street or at the track.
#14 | |
| Thread Tools | |
| DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 49 | 11-13-2010 03:57 PM |
| Hawk Performance Brake Pad "Updated" | KILLER74Z28 | Suspension / Brakes / Chassis | 33 | 03-06-2010 04:32 PM |
| Racing Brake List of us that want rear 2 piece rotors | 2SSRS | Suspension / Chassis / Brakes | 24 | 11-26-2009 11:06 AM |
| cerramic brake rotors | aaronheintz123 | Wheels and Tires Talk Sponsored by The Tire Rack | 13 | 09-20-2009 05:54 PM |
| Racing Brake two piece rotors | mtcwby | Wheels and Tires Talk Sponsored by The Tire Rack | 0 | 09-19-2009 12:22 AM |
