Old 11-16-2009, 09:44 PM   #1
DkknightX
Drives: 2006 Chevrolet Cobalt SS/SC Stage 2
Bad Tire Pressure Monitor System
I was informed by On-Star to fill my tires with air because they were too low. I finally did get around to it tonight and carefully tried to fill them. I was filling them up and removing air as necessary very carefully. My car started beeping after I serviced each tire. Then I started my car up and gave me these messages. I took pictures of the DAC with my cell phone but ultimately I cannot get PSI readings on any tire anymore. I purchased a digital monitor as well tonight to make sure that dispite the system malfunctioning, I could ensure I have the right tire pressure. On-Star was useless, but I'm wondering instead of bringing my car in for service, is there any way of resetting the tire monitoring system back to default again? I saw something on the DAC about relearning but it didn't do anything. Any thoughts? Thanks in advance!
DkknightX is offline   Reply With Quote
Old 11-17-2009, 12:47 AM   #2
navmaxlp
navmaxlp's Avatar
Drives: Not a Camaro :(
Might want to pick up an OBD II scanner or borrow one and take a look at it, You may be able to reset the sensor. I highly doubt all the sensors went bad at the same time. The reset may clear things up. If it's more than that, it may be covered under waranty.
navmaxlp is offline   Reply With Quote
Old 11-17-2009, 12:54 AM   #3
chevyss
SS/RS
chevyss's Avatar
Drives: 2010 SS/RS IOM w/blk stripes A6
DIC has a program to re-learn for the sensors?? I thought I read something about it.
chevyss is offline   Reply With Quote
Old 11-17-2009, 12:56 AM   #4
HashimAzzouz
Drives: 2011 2SS/RS IOM ~ 2009 Traverse LT
I think you have to take it to the dealer and let them solve it themselves! I did not order my Camaro yet! but I have a Chevrolet Traverse LT and everytime I check the tire pressure monitor it reads different all the time!! I think there is something wrong with their monitors/sensors in these new cars, not just the Camaro!!
HashimAzzouz is offline   Reply With Quote
Old 11-17-2009, 12:57 AM   #5
latinoslife
Drives: silver ice 2010 camaro 2lt RS
mines did that i took it to dealer they said i needed some sort of update that was a week ago no problems but lets c how it goes when i get my tires replaced
[IMG][CENTER][/IMG]
latinoslife is offline   Reply With Quote
Old 11-17-2009, 01:24 AM   #6
shockandawe
shockandawe's Avatar
Drives: 2014 Z51 Corvette
No,no if the sensors are bad, you need to replace them, not the tires!
shockandawe is offline   Reply With Quote
Old 11-17-2009, 02:32 AM   #7
brAnd7onX
brAnd7onX's Avatar
Drives: 2012 1SS IOM
In most cars with the tire pressure monitoring system the reset button is in the glove box. Is there one??
brAnd7onX is online now   Reply With Quote
Old 11-17-2009, 03:06 AM   #8
DkknightX
Good thinking! I'll have to check. Let you guys know. It was weird, as I was filling each tire, the horn would sound I guess to let me know whether the tires had too much or too little air. If I can't find it, I'll have to call my dealer. Going to suck wasting time resetting these tire pressure sensors. The wheels themselves are at the correct pressure. That handheld electronic tire pressure reader is awesome. No guessing. Reads in increments of .5 PSI Pretty accurate if you ask me.
Old 11-17-2009, 04:06 AM   #9
Mzodarg
Remembering those in Blue
Drives: 2010 Camaro 2SS Blk w/IOM Int
I had issues with mine until I
Just saying,
Mike
Mzodarg is offline   Reply With Quote
Old 11-17-2009, 04:18 AM   #10
DkknightX
But did you actually get that message about "Service Tire Pressure Monitor System?"
Old 11-17-2009, 04:20 AM   #11
Mzodarg
If I recall correctly, I did get that message (my memory ain't for sh!t these days). Then I read the book and all was well.
Mike
Old 11-17-2009, 04:23 AM   #12
BruceJames
Drives: 2010 SS2 RS Inferno Orange
READ the MANUAL! It tells you how to reset the stuff.. The beeping is indicating a reset..
You have to go to the DIC.. set it to reprogram the Pressure Monitor..then add or subtract air in EACH tire starting with the front drivers side..and then front passenger.. rear passenger then rear driver side tires till the horn beeps for EACH tire.. READ UP ...It's in there
BruceJames is offline   Reply With Quote
Old 11-17-2009, 04:37 AM   #13
Lumina SS
Corvette Z51
Lumina SS's Avatar
Drives: Corvette Z51 476rwhp & camaro
the monitor change every time because when the tire is cold the pressure became low but when you drive the car and the tire move the tire become hot and the pressure become high that why it's keep changing every time.
Lumina SS is offline   Reply With Quote
Old 11-17-2009, 04:42 AM   #14
Lumina SS
Corvette Z51
Lumina SS's Avatar
i did get it in my corvette because one of my rim is not good because i hit something in the road sometimes it read the tire is flat but sometimes it's read it fine
Tire Sealant Kit - Warranty Issues jbreed Wheels and Tires Talk Sponsored by The Tire Rack 38 09-14-2011 03:18 PM
Oil pressure drops bad wetodd 4th Generation Camaros 26 11-25-2009 08:38 AM
Another Issue. Tire Monitor System!!! JewelZ Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 11-11-2009 10:07 AM
500.00 per perelli tire not a myth! AVman Wheels and Tires Talk Sponsored by The Tire Rack 51 10-20-2009 04:45 PM
Tire Pressure Monitoring Dentyneice Wheels and Tires Talk Sponsored by The Tire Rack 8 08-14-2009 07:42 AM
