Old 11-17-2009, 02:21 AM   #1
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
thinking bout installing springs my self
should i not? im not sure if i could do it but i dont want to pay some crazy price to have it done
so what do i need to know?
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 11-17-2009, 02:31 AM   #2
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
Look 'dis
http://www.ls1howto.com/index.php?article=23
edit: nevermind, you meant suspension. This link is for valve springs.
brandotron is offline   Reply With Quote
Old 11-17-2009, 02:58 PM   #3
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
It's a job that can be completed in a driveway in roughly 3-4 hours. You'll need a good Jack, jack stands, strut spring compressor and basic hand tools.
Kind regards,
JDP Motorsports is offline   Reply With Quote
Old 11-17-2009, 03:07 PM   #4
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
thanks- my friends and i will attempt to do this
Old 11-17-2009, 03:36 PM   #5
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Is there anything other than alignment that needs to be done after a spring install?
Jeanius is offline   Reply With Quote
Old 11-17-2009, 03:38 PM   #6
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
That's all for my car Alignment this Friday...I was told to let the car settle in a bit before the alignment. So I waited...200-300 miles or so.
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 11-17-2009, 03:53 PM   #7
Jeanius
Jeanius's Avatar
Cool, ive seen some people post about Camber/Caster/Toe, i have no idea what those are, or who would be able to adjust them
Old 11-17-2009, 03:57 PM   #8
Michael_Js
Michael_Js's Avatar
Yes, those are alignment terms. See this FAQ: http://www.discounttire.com/dtcs/infoAlignment.dos
Discount Tire does not do alignments though...Your local Chevy dealer does and I was quoted around $108.
Old 11-17-2009, 08:00 PM   #9
BLACK10
BLACK10's Avatar
i've lowered 3 camaro's so far, let me know if i can help you.
right off my head, youll need:
15/16 or 21mm wrench
24mm socket
7mm socket(to undo front swaybar,hold backup with 15mm wrench)
21mm socket
40,45 torx drive bits
15mm socket
18mm socket
15mm wrench
18mm wrench
10"-12" extension
Old 11-17-2009, 08:26 PM   #10
Chris-10
Chris-10's Avatar
Drives: 2ss/rs vr 6m
24mm socket
21mm socket
15mm socket
18mm socket
15mm wrench
18mm wrench
10"-12" extension
did you do the alignment right away, or as one of the other posts says let the car settle a little first ?
Old 11-17-2009, 10:53 PM   #11
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
There are several issues on alignments that need to to be considered when dropping the Camaro:
1. There is no camber alignment bolt in the front end. Therefore it becomes more of a challenge just to put it back into the same location.
2. When dropping the rear, we have found the rear camber adjustment becomes very limited and does not have enough throw to be able to put the rear cambers where we like to to promote best reduction in understeer.
Pedders makes 3 alignment kits for the Camaro:
1. A front kit that includes the camber adjuster bolt, and a set of eccentrics that will allow you to adjust front caster, which is not adjustable in OE configuration
2. A rear kit that includes new hardware to adjust the rear cambers and toes.
3. A kit that includes both front and rear.
The Pedders kits use lazer cut eccentrics that relocate the center hole to allow a far greater throw than OE and come with a life time warranty.
They are also cad plated for corrosion protection. Here is a picture of the full kit:
thanks
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 11-17-2009, 11:00 PM   #12
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
I have been doing alignments for along time .I would put 200-300 miles on the car before the alignment to let them set because they all do.If you don't want to wait, ask the alignment shop if they will recheck it after a few miles or after about 30 days.They may have to touch it up a bit but you will be happier with it, not mention not ruining a set of tires.
Bruce@raymondsperformance is offline   Reply With Quote
Old 11-17-2009, 11:30 PM   #13
Mark-HD
Mark-HD's Avatar
Drives: 2010 Inferno Orange SS
How much is the whole kit?
thanks
mike
dms
2010 Camaro SS, M6, MTI shifter and sway bars, GM quarter flares, Corsa catback, Roto-Fab CAI, 30% tinted windows, Lloyd's custom mats, Hawk ceramic pads, Pedders lower coils, Magnuson supercharger with 3.6 pulley, BMR trailing arms & toe rods, Kook's LT's1 7/8 w/cats, Lingenfelter/SLP billet pedals, KW V'3 Coilovers, RevExtreme catch can, ---Ordered--- IconZ LS7 9 & 11" polished wheels!. Dyno'd 563.05 HP, 543.86 Torq.
Mark-HD is offline   Reply With Quote
Old 11-18-2009, 12:11 AM   #14
Michael_Js
Michael_Js's Avatar
Yes, +1 on the price. Then, will an alignment shop know what to do with these? The camber alignment bolts in the front end are obvious as I've seen the empty bolt hole.
thanks,
Michael J.
Bad news for anyone thinking of installing an aftermarket head unit fastball Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 26 05-26-2009 11:18 PM
New to the board and thinking about ordering mine GMan Camaro Price | Ordering | Tracking | Dealers Discussions 14 03-09-2009 01:21 PM
Thinking of Painting my Camaro. Scott@Bjorn3D Cosmetics and Lighting Modification Discussions 24 12-26-2008 05:59 PM
Crazy for thinking of selling my '68 and getting a 2010 ls6camaro 5th Gen Camaro SS LS LT General Discussions 54 11-06-2008 04:56 PM
Am I crazy for thinking this??? fastfret7 5th Gen Camaro SS LS LT General Discussions 9 10-25-2008 11:28 PM
