Gen5DIY
Old 11-17-2009, 11:11 PM   #15
Jeanius
Jeanius's Avatar
Drives: Blk/Blk LS3 SS
Originally Posted by dms View Post
There are several issues on alignments that need to to be considered when dropping the Camaro:
1. There is no camber alignment bolt in the front end. Therefore it becomes more of a challenge just to put it back into the same location.
2. When dropping the rear, we have found the rear camber adjustment becomes very limited and does not have enough throw to be able to put the rear cambers where we like to to promote best reduction in understeer.
Pedders makes 3 alignment kits for the Camaro:
1. A front kit that includes the camber adjuster bolt, and a set of eccentrics that will allow you to adjust front caster, which is not adjustable in OE configuration
2. A rear kit that includes new hardware to adjust the rear cambers and toes.
3. A kit that includes both front and rear.
The Pedders kits use lazer cut eccentrics that relocate the center hole to allow a far greater throw than OE and come with a life time warranty.
They are also cad plated for corrosion protection. Here is a picture of the full kit:
thanks
mike
dms
So are you saying that without these you will not be able to get a TRUE alignment from a local shop due to the OE parts?
Jeanius is offline   Reply With Quote
Old 11-17-2009, 11:15 PM   #16
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Wonder how the dealer does the alignments then...
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 11-17-2009, 11:18 PM   #17
Jeanius
Jeanius's Avatar
Id like to know $ as well
Old 11-17-2009, 11:45 PM   #18
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
I am about 90% done with a complete install procedure for them. Not hard to do.
The question is, how are poeple aligning the cars now? They are setting them to with the end of tolerances. BUT, there are alignments, and then there are alignments!! You can get them within numbers, and then you can get them within numbers that take total advantage of improving handling, and and reducing understeer.
Traditionally, with a drop coil, you are maxed in reduced camber to around the -1.- to -1.3 negative camber. With just coils only, rear camber should be in the 0 to -.5. We have tested this!!!!! and it works very well. With a more complete system, this is not where you should go.
For the rear kit: PDUSA5420 costs $150.99
https://secure.merlinsoftware.com.au...Code=PDUSA5420
For the front only kit: PDUSACAMFNT and costs $89.95
https://secure.merlinsoftware.com.au...de=PDUSACAMFNT
For the full kit front and rear: PDUSACAMFULL and costs $210
https://secure.merlinsoftware.com.au...e=PDUSACAMFULL
The bolts are high grade, and hand machined. The eccentrics are laser cut, and we double nut all of them so you do not have to replace nuts, and will be gaurenteed for as long as you own your Camaro.
Complete alignment specs for drop coils that we have testes that max out on reducing understeer, and overall performances will be given to our Pedders customers.
thanks
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 11-18-2009, 07:49 AM   #19
BLACK10
BLACK10's Avatar
Originally Posted by O-10maro View Post
did you do the alignment right away, or as one of the other posts says let the car settle a little first ?
right away, if you ride too long with it out of alignment, you get poor handling and may have some tire wear.
with the H&R springs, all THREE cars i've done were aligned perfect back to factory spec without any other add-ons. thats up to you if you want to spend money on the bolt kit., it would'nt hurt though, i 'm just saying the springs i used, it was'nt needed.
here is a pic of the torx bit.
Old 11-18-2009, 09:32 AM   #20
Info@PeddersUSA.com
Not t be argumentative, but the alignment cannot be perfect, but can get to the upper ends of spec. Perfect would reference taking advantage of specs to maximize on handling and good tire wear. Getting it just into spec can do neither.
mike
dms
Old 11-18-2009, 10:00 AM   #21
BLACK10
BLACK10's Avatar
mike
dms
i hear ya
Old 11-18-2009, 11:28 AM   #22
Jeanius
Jeanius's Avatar
So if my car will absolutely never see a track, then getting those bolts is not necessary right?
Old 11-18-2009, 12:05 PM   #23
Aaron Pfadt
Pfadt Race Engineering
Aaron Pfadt's Avatar
Drives: 7.0 Liters of Fury
Originally Posted by jeffny09 View Post
should i not? im not sure if i could do it but i dont want to pay some crazy price to have it done
so what do i need to know?
Jeff,
Lots of info and mis-info in this thread. You can certainly install the drop springs if you have experience with such things. The install is not trivial, but it does not require any special knowledge. The list of tools that Black10 makes is a good one.
This 'sales talk' about camber bolt kits is pretty overblown. The factory and dealer will both do the alignment the same way in the front. There is no eccentric bolt in the slotted location in the front, but there is a threaded hole in the strut that you put a bolt in and adjust until you achieve the correct camber.
The eccentric bolt is unnecessary for infrequent alignments. In fact, I just put a bolt in the adjuster hole and leave it there when I am switching out struts to make sure I get everything back in the same place.
In the rear, you can get back to factory specs with the stock eccentrics. I will certainly agree with Mike that there are alignments and there are good alignments, but that has to do only with the shop/tech that is doing the alignment, not the color of the eccentric bolts. The factory eccentrics will achieve a stock alignment with drop springs. Period. If you are racing the car, then you need something completely different than an eccentric anyhow. Just like on Corvettes, the eccentrics can slip under high cornering loads. We make a kit for the Corvette that eliminates the eccentrics. All of you folks that are going to be running race tires, we'll make one for the Camaro also. Look for that in the future.
-Aaron
Aaron Pfadt is offline   Reply With Quote
Old 11-18-2009, 03:06 PM   #24
Info@PeddersUSA.com
I have seen 3 Camaro that were dropped in the 1.5inch, and one at 2 inches. could not get less that -1.5 on one, -1.2 on the other, and -1.0 on the third. Now maybe this is just fine for the guy who is just looking to make a nominal improvement, and maybe that is OK for you as well. But when we are asked to make the maximum change and influence with different kits, then as you are aware, changing the rear cambers with just drop coils or coil overs only, and changing the rear cambers from a -1.5 to the -.5 range, will do an outstanding job of reducing the understeer issues, without having the benefit of sway bars and such. Also, those wanting to set up their vehicles for a drag race option, have no other options to reduce negative cambers. You can, in fact if properly set up, get your cambers to the +.5 range, so when you launch, you have a .00 camber in the rear.
Fortunately, there has not been much of a drift or pull concerns with the Camaro, as we have seen in the G8. But there are Camaros that do not track perfectly due to road crowning. In OE format, the only way to generate bias for road crown is to mess with front cambers. We prefer, for handling sake, to keep our cambers equal side to side. You cannot do this with the Camaro and make road crown bias adjustments on a OE Camaro setup
If someone is only interested again in a minor drop with the performance enhancement that will give, then it is fine. But if you can get a drop, and add an additional degree of caster, I am sure you will agree, an additional degree of caster is a great steering feel, and handling improvement. There are not detriments of adding 1 degree caster, only positives. It is again, just another process for making additional improvements, and maximizing on understeer, and body role reduction.
We started making this kit for the G8, because on the G8, the eccentrics are really bad, and strip out easily. The Camaro, however, uses a larger bolt and I do not think it will have the durability issues G8 has.
You should try one of these kits. They are much more HD than the OE units, and will give you more flexibility and durability in adjustments. We also resolve the concern about following GMs recommendation to replace the nut after every use.
The recommendations of rear alignments for limited upgrades has been tested by us in a significant way. In fact, we just did a OE SS2, changed the front and rear alignment to our system, which required the use of our bolt kit, and the handling was substantially improved.
As already stated, the kit is not in fact required in all cases to get the Camaro within GM's wide tolerances. But is very helpful, for those that want to maximize a minimal approach setup, to improve handling to the best that can be without wasting tires, and also to assist in road bias adjustment, while not using camber to do it. Now for the color, we cad plate the bolts for corrosion protection. Plus they look great as a sedondary effect.
As always, it is great having a good interchange with you.
take care
P.S.
Say hi to Dan Long for me.
mike
dms
Old 11-18-2009, 03:52 PM   #25
BlownSS
BlownSS's Avatar
so...back to his initial question. Are there online instructions or video? Im familiar with lots of spring changes on jeeps and have done lifts on front ends with struts/springs. Is this easier or more difficult?
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
BlownSS is offline   Reply With Quote
Old 11-18-2009, 04:02 PM   #26
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
hey billy doesnt seem to hard just need a coulple wrenches and a spring compressor which ill rent
hopefuly i can do it lol
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 11-18-2009, 04:08 PM   #27
BlownSS
BlownSS's Avatar
if u rent the compressor, we can do it at my place and ill help ya. U can be the guinea pig!
Old 11-18-2009, 04:10 PM   #28
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
lol ill rent it
whats it called?
they should be shipping out the latest monday i beleave
another friend of mine said hed help to
ill bring ther beers =)
Bad news for anyone thinking of installing an aftermarket head unit fastball Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 26 05-26-2009 10:18 PM
New to the board and thinking about ordering mine GMan Camaro Price | Ordering | Tracking | Dealers Discussions 14 03-09-2009 12:21 PM
Thinking of Painting my Camaro. Scott@Bjorn3D Cosmetics and Lighting Modification Discussions 24 12-26-2008 04:59 PM
Crazy for thinking of selling my '68 and getting a 2010 ls6camaro 5th Gen Camaro SS LS LT General Discussions 54 11-06-2008 03:56 PM
Am I crazy for thinking this??? fastfret7 5th Gen Camaro SS LS LT General Discussions 9 10-25-2008 10:28 PM
