Jason 98 TA
Old 11-17-2009, 12:23 PM   #1
Ukd73
Drives: 2010 1ss/rs Ls3
Where is the port to plug in a diablo turner
Call me dumb but I haven't run across it yet.
Ukd73 is offline   Reply With Quote
Old 11-17-2009, 01:13 PM   #2
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
I would think it's the OBD port. Should be under dash on drivers side.
9/26/09 Took delivery!
Old 11-17-2009, 01:33 PM   #3
Ukd73
Thanks
Old 11-17-2009, 01:45 PM   #4
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
NP
Old 11-17-2009, 09:45 PM   #5
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
lol, call me dumb, but what the heck is a diablo turner?
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 11-18-2009, 12:53 AM   #6
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
It's a programmer you can buy to tune the cars computer for more performance and to adjust different parameters. Shift points, rev limiter, speed limiter, etc.
Old 11-18-2009, 08:18 AM   #7
myblackcamaros
myblackcamaros's Avatar
Drives: #156 ZL575, 97 SS, 87 IROC-Z
You can turn off the Active Fuel Management with that tuner, what a huge difference in the car. I love my A6 even more now.
myblackcamaros is offline   Reply With Quote
Old 11-18-2009, 06:22 PM   #8
Midnight Shadow
Midnight Shadow
Midnight Shadow's Avatar
Drives: '10 Camaro AA/RS '09 Vette '96 S10
What's the difference when the active fuel management is turned off...
Midnight Shadow is offline   Reply With Quote
Old 11-18-2009, 07:08 PM   #9
magnum21
Drives: turboed tiburon
It stops the car from running on 4 cyl when cruising pretty much a must with an aftermarket exhaust
magnum21 is offline   Reply With Quote
Old 11-19-2009, 03:16 PM   #10
Midnight Shadow
Midnight Shadow
magnum what if any effect does it have on the VVT
Old 11-20-2009, 08:49 AM   #11
06MonteSS
Drives: 2006 Monte Carlo SS
with the diablo predator - or even their new Trinity that is available for the new camaro's now too, you will gain 15-20 hp and 20 ft-lbs torque....
you'll get better throttle response, better acceleration, and as was mentioned, you can disable the AFM so that you're always in V8 mode...
things you can adjust with it include:
COT time delay
DoD disable
Idle RPM Drive/Neutral
Injector Slope adjustment
WOT Fuel 2k-3.8k / 4k-4.9k / 5k-7k
Rev Limit
WOT Spark (in degrees) 1k-3.8k / 4k-5k / 5.2k-7k
Fan adjustment, individual adjustment per temp dependent cell
Tire Size
Speed limit(truck/SUV only)
Read/Write time is approx 60 seconds
Clear codes supported
Live data and log supported
Holds up to 5 custom tunes & Dat viewer is supported.
and you can get custom tunes created for you/your car via email from Diablosport CMR dealers/tuners (like me)....
06MonteSS is offline   Reply With Quote
Old 11-20-2009, 11:36 AM   #12
Mzodarg
Remembering those in Blue
Drives: 2010 Camaro 2SS Blk w/IOM Int
I recently got mine and disabled the DoD or AFM as we know it. Can't wait to begin the loggin process. Car runs amazing- laid a 20' of rubber down my drive way with traction controlled active. Now all I need is my CIA.
Mzodarg is offline   Reply With Quote
Old 11-24-2009, 08:09 PM   #13
tom692010
Drives: 4 wheels
so with all the change ability would someone who isn't a tuner,but mechanically inclined,be able to use it and not screw up the engine? Is there say pre existing tunes I could put in so I wasn't just putting in a setting that would throw me way off? How much more is the custom setting as opposed to getting the tuner and doing it myself
tom692010 is offline   Reply With Quote
Old 11-25-2009, 08:04 AM   #14
06MonteSS
yes, it comes with preloaded tunes that you can just install and go!
it has a "Diablo Tune" - which is made for 93 octane fuel, and it has a "91 Octane Tune" as well...
as for a custom tune, it all depends on if you do it via email, or if you go to a dyno shop... and everyone charges something a little different than the next guy...
if you get a predator or trinity and are interested in a custom tune to get even more giddy-up out of your car, you can PM me for info about my tunes...
We need help with Electronics wiring diagrams 2SSRS@Gen5diy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 12-13-2009 06:58 PM
USB port stopped working philthy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 85 11-11-2009 07:14 PM
Magnitic Drain Plug Fix halo8hkk Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 10-04-2009 04:28 PM
USB Port location/relocation 2ssJB Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 15 05-01-2009 05:28 AM
Nitrous oxide and Challengers Superman09 General Automotive + Other Cars Discussion 16 01-29-2009 09:14 PM
