Rick@Livernois
Old 11-17-2009, 05:47 PM   #1
xBlackout_Camaro
xBlackout_Camaro's Avatar
Drives: 2011 Camaro SS/RS Cyber Grey
Unhappy Foot well LED HELP please!!
Ordered these and i'm not to sure how to install them. Anyone know how to help me out?
xBlackout_Camaro is offline   Reply With Quote
Old 11-17-2009, 05:57 PM   #2
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
have you contacted the manufacturer or just not seen the instructions in the bottom of the box?
i know those are obvious questions, but it's worth asking...
Old 11-17-2009, 06:00 PM   #3
xBlackout_Camaro
They were ordered offline and didn't come with instructions, I'm searching for the instructions online but not coming up with any luck.
Old 11-17-2009, 06:10 PM   #4
zebra
zebra's Avatar
have you tried tapping the leads into the existing footwell lighting?
Old 11-17-2009, 06:37 PM   #5
xBlackout_Camaro
if only i new how to do that :0...I'm good at custom stuff but when it comes to that im SOL...
Old 11-17-2009, 07:00 PM   #6
Camaro21
Drives: SOLD - 2013 M6 ZL1
The 2 wires are hooked to a Power Source and a Ground. It ususally doesn't matter which wires go where when it comes to this. You can search your owners manual for a fuse that is powered when the door is open (Dome light Circuit) is probably the best for your instance. You can purchase terminal ends or just strip the end of the wire to hook to power wrap it around the dome light fuse (not the best method). Strip the other wire (Ground wire) and install a terminal end so that you can bolt to an existing ground under your dash somewhere.
Hope this helps.
Camaro21 is offline   Reply With Quote
Old 11-17-2009, 08:18 PM   #7
xBlackout_Camaro
I'll keep workin at it, If anyone has any picture directions that would be helpful!
Old 11-18-2009, 07:52 AM   #8
ThunderSS
ThunderSS's Avatar
Drives: 2010 CGM 2SS/RS
Use the red coated wire as your 12V power source, hook it up to a power source that will turn on with the inside light or one of the ignition sources( I dont know if you want it on all the time, or just when you open the doors... you could always just wire it up to a 12V constant power, like the battery, and have a switch installed in line with the 12V power.)
take the Clear coated wire to a grounded point on the body of the car..( a bolt that bolts to the metal structure of the vehicle will work), and then wal'la ...
2010 Camaro SS/RS HKE Forged 416 CID
http://www.fquick.com/ThunderZ28
510 HP/485 Ft. Lbs
ThunderSS is offline   Reply With Quote
Old 11-18-2009, 09:23 AM   #9
xBlackout_Camaro
Could you describe to me what " power source that will turn on with the inside light" looks like so i can easily find it. I just want them to turn on when the door is open
Old 11-18-2009, 09:38 AM   #10
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
here is a link to the ambient lighting thread should show where to hook it up http://www.camaro5.com/forums/showth...bient+lighting
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 11-18-2009, 09:46 AM   #11
ThunderSS
ThunderSS's Avatar
get you one of these
You can pick up one of those piggback connectors at most auto parts stores.
what you want to do is locate the fuse for your Interior lighting. ( the fuse panel is located on the left hand side of the dash. you will need to pull the cover off.. refer to your users manual)
once you find that fuse pull it out.. insert the fuse link adapter. install your original fuse for the adapter, and one for the added circuit..
then butt splice this onto the red wire that is coming off of your LED light.. you may need to add more wire to make it reach. JUST BE SURE TO NOT CROSS POLARITY!! hook one wire up at a time.. keep the red wire hook up to the power source, and take the clear wire to your Ground point(Body Frame)
510 HP/485 Ft. Lbs
Old 11-18-2009, 09:49 AM   #12
ThunderSS
ThunderSS's Avatar
not sure he wants the LED foot well lighting to be on with the ambient lighting.. he mentioned he wanted it on when the doors are open, with the dome light.
510 HP/485 Ft. Lbs
Old 11-18-2009, 05:18 PM   #13
xBlackout_Camaro
Thunders right...just when my door opens.
Old 11-18-2009, 09:18 PM   #14
klatterblast
your right, dont know what i was thinking.
ORACLE 5202 LED 18SMD Cool White Fog Light Bulbs for Camaro!> 20% OFF! AACstyle Exterior Parts & Accessories 137 04-01-2011 02:49 PM
LED Interior Replacement Lights For Your 2010 Camaro Vizualize Interior Parts & Accessories 36 02-24-2010 06:57 PM
UT Camaro's LED underbody kit chrisgalles Camaro Photos | Spyshots | Video | Media Gallery 32 09-11-2009 07:26 AM
How smart is your right foot? tjbusa Off-topic Discussions 13 03-25-2009 10:29 PM
