Caryle Racing
Old 11-17-2009, 07:36 PM   #1
BMBLB
BMBLB's Avatar
Drives: Yellow Camaro 2LT, 186th car made
Camaro v6 performance calculations
Found some calculated performance tables on the net but had a few issues with parts. Started my own. Still developing. Shows calculated speed by gear and max grade (resistance) by gear. Adjustable car weight and tires. Digital engine curves. This can be used to compare performance of Camaros or other cars. Already accounted for power train efficiencies in figures.
BMBLB is offline   Reply With Quote
Old 11-17-2009, 08:06 PM   #2
nachocheese
nachocheese's Avatar
Drives: 1LT RS, SIM
Link??
nachocheese is offline   Reply With Quote
Old 11-18-2009, 09:35 AM   #3
bi11ymc
"Silver Street"
bi11ymc's Avatar
Drives: 2010 2SS/RS L99
Try using the free service from Google for your spread sheet:
https://www.google.com/accounts/Serv...rm=spreadsheet
Silver Street - 2010 Camaro 2SS/RS, SIM, Gray, Cyber Gray Rally Stripes, Polished Wheels, Automatic (L99) - 553 RWHP/510 RWTQ
CAI Inc., ARH LT Headers with Cats, Borla Touring Cat-Back; Pfadt Coil Overs, Sway Bars, End Links, and Trailing Arms; Comp Cams Blower Cam, Dual Springs, Push-Rods, and Lifters; GM LS2 Lifter Trays, 6.2 MLS Head Gaskets, Crank Bolt, and LS2 Front Cover; 3-Bolt Conversion Timing Gear, Katech C5R Timing Chain, ARP LS2/LS3 Head Bolt Kit, Melling Hi Volume Oil Pump, TVS 2300 Supercharger (Black); Build by Vengeance Racing; Custom Tune by Vengeance Racing
bi11ymc is offline   Reply With Quote
Old 11-20-2009, 05:22 PM   #4
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Originally Posted by BMBLB View Post
Found some work on the net but they had an error in their rolling radius calculations. Interesting that the Pirelli tire data provides a RR value not the same as what is calculated using their data. The calculated RR of 705 results in actual measured speeds in each gear for a given RMP. This file can be used to see the impact of weight on performance, tire changes and to understand the sweet spots for gear changes. The engine curve graphs did not stay using the googel posting but the data is still on the right.
or you can just go to the track!
scrming is offline   Reply With Quote
Old 11-21-2009, 06:22 AM   #5
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
Yelp, agree, and much more fun too. Still, I like using the calcs to estimate HP as a result of modifications.
They have this new device out now that will do that very same thing......
Beauwulf is offline   Reply With Quote
Old 11-21-2009, 06:53 AM   #6
scrming
scrming's Avatar
I buy my dyno time in bulk! LOL!
Old 11-21-2009, 06:54 AM   #7
scrming
scrming's Avatar
Yep... cool stuff... I keep the Drag Times DA calculator up so I can keep estimating my 1/4 mile times!
2lt, engine curves, performance, v6 engine
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Exterior Parts & Accessories 30 02-20-2013 04:23 PM
Camaro (concept) Press Release!! Pencil.Fight 5th Gen Camaro SS LS LT General Discussions 4 07-21-2008 04:33 PM
