ADM PERFORMANCE
Old 11-19-2009, 10:14 AM   #1
ottobody
Drives: 2010 trans am/camaro
Full HID Xenon headlight set 2SS/RS headlights
Stock HID Xenon Headlights with Halos, left and right side, can be tinted if asked for
MSRP Headlight housing: $830 each
MSRP HID Bulbs: $293
Asking: $1200 full set with tinted marker lights
ottobody is offline   Reply With Quote
Old 11-19-2009, 10:17 AM   #2
ottobody
they are brand new no bugs or anything we bought the car and pulled them directly out and replaced them with completely differetn headlights
Old 11-24-2009, 12:28 PM   #3
Denvercamaro
Drives: camaro
Looking for HID for LS model - they say they are interchangable as long as RS or SS has a production date after 8/20/09?
does this fit your description?
and doyou still have the lights?
Denvercamaro is offline   Reply With Quote
Old 11-24-2009, 05:50 PM   #4
BFxenon.com
Drives: Camaro
what are you switching them out?
BFxenon.com is offline   Reply With Quote
Old 11-24-2009, 07:37 PM   #5
Chaos Machine
Drives: 2010 Camaro 1SS
who is they? the prospect of being able to retrofit my 1ss with those groovy hids with projectors has me salivating.
Chaos Machine is offline   Reply With Quote
Old 11-24-2009, 09:03 PM   #6
Anwro
Red 2SS
Drives: Camaros
am intrested , but are they plug and play ? i have 2ss no - rs
2010 Camaro 2ss L99 Red - Kooks+Corsa+VR+Ebiach LowerKit-
2002 Camaro SS LS1 Black - Kooks+SLP+Hurst-
2009 Escalade Pearl White - Corsa -
Anwro is offline   Reply With Quote
Old 11-24-2009, 10:56 PM   #7
jrpxxii
jrpxxii's Avatar
If you do not have an RS these are not plug and play. It takes a huge amount of time and money to convert over to HID. You must have complete HID housings with bulbs, Entire new wiring harness all the way to the switch, new switch and a new PCM and BCM as you must have a RS VIN put in the new PCM and BCM to have the correct codes for the HID to work. Just to let anyone know what it takes, I learned the hard way.
Old 11-25-2009, 08:48 AM   #8
Anwro
Red 2SS
Drives: Camaros
ah too bad .. i was about yo buy them , but it seems like to much cutting and ripping .. and which means i might spend more than $1500 +
Old 11-29-2009, 04:12 PM   #9
ottobody
im not sure if they aree plug and play or not but its the full headlight assemblies with bulbs im sure you can buy a repairable end for the headlight connection and hard wire them in with out all the pcm and bcm wiring bull
Old 11-29-2009, 11:23 PM   #10
BFxenon.com
Drives: Camaro
do you have any pictures? I would like to see the connections and what all they come with.
Old 01-03-2010, 09:26 PM   #11
runt69421
runt69421's Avatar
Drives: 2010 chevy black camaro 2ss
Send a message via Yahoo to runt69421
hey i installed the halos on my 2ss without the wiring harness and i did some wiring of myself and i got everything to work right but i dnmt have highbeams, do u know of a code for the bcm
runt69421 is offline   Reply With Quote
Old 01-03-2010, 10:13 PM   #12
jrpxxii
jrpxxii's Avatar
how did you wire them to work?
Old 01-08-2010, 08:00 PM   #13
runt69421
runt69421's Avatar
i wired them threw the marker lights and i changed the light connecters and spiced and wired threw the marker lights, the only prob i have is no high beams but the lows are bright enough
Headlight Armor Lighting Protection and Smoked Taillight Kits Available HeadlightArmor Exterior Parts & Accessories 1355 01-12-2018 02:22 PM
