Old 11-19-2009, 10:21 AM   #1
lre107
lre107's Avatar
Drives: 2008 Chevrolet Malibu
Need help, weird vibration, very frustrated
Its not a Camaro, but I have a question. I am very frustrated, and need some ideas. I have a 2008 Malibu 2LT with a 4-cylinder. It has all of sudden developed a weird vibration that comes and goes, and it isn't there all the time. I have a 25 minute commute and it starts about 15 to minutes into the commute on the highway. It starts midly and then gets progressivly worse. I feel it int he front of the car, through the stering wheel, and as it get worse, when I step on the brake pedal. But after I have used my brakes a few times, or the car sets for a few hours it is gone, sometimes it comes back, and sometimes it dosen't. I have had it to the dealership here on two different occassions, and the second time it was there for 3 days, and it never accted up for them when they drove it. It feels to me liek it is coming from the left front, and after it acts up and I stop, it feels like the left front wheel area is much hotter then the right front. So I thought maybe a sticking caliper, but they said they checked it it everything is fine. But everthing is not fine, and I am begining to get very frustrated. I have never had a single issue with this car till now, and I am more frustrated with the dealership, I am not sure they are doing enough, anybody work in service have any ideas? Like I said it comes after about 15 to minutes of highway driving, and I feel it in the sterring wheel and the brake pedal when I step on the pedal, and it always goes away after I use the brakes a few times or he car sits for a while. And the left front feels hotter then the right front after it acts up, I havent noticed any excessive brake dust or burn marks on the rotors. HELP!
lre107 is offline   Reply With Quote
Old 11-19-2009, 10:24 AM   #2
coolman
Guest
does the car pull to the side the wheel is hotter on?
coolman is offline   Reply With Quote
Old 11-19-2009, 11:58 AM   #3
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
It almost sounds like a CV (constant velocity) joint going bad. Does it make a clunking/chattering sound or a slight vibration when you turn a corner?
Edit; I forgot this, look at the inside of your car`s tire and see if it is coated with grease or if the CV boot is torn or pulled away. It`s uselly the left front that goes bad.
mickss is offline   Reply With Quote
Old 11-19-2009, 01:24 PM   #4
lre107
lre107's Avatar
It dosen't pull, and the CV joint is fine, I checked everything myself, and the dealer checked it out, it seems liek something brake related to me, cause It goes away after I use my brakes a few times. There is no noise other then the vibration itself. Its not a hub, cause it dosn't change when I turn the wheel. The rotor center hub area is warmer not the whole wheel.
Old 11-19-2009, 01:36 PM   #5
strshp5
2G1FK1EJ9A9129110
strshp5's Avatar
Drives: 00 impala,02 blazer
sounds like you have a warped rotor have you had the rotors machined and the brake slides cleaned and lubed they have a problem of freezing up on the bracket slide area and not releasing totally
john
0000: 06/17/09-(gary lang Chevrolet)
1100: 06/17/09-(preliminary order accepted) NKPQ3N
2000: 06/22/09-(accepted by gm)
3000: 06/24/09-(accepted by production control)
3300: 07/14/09-(order scheduled for production)
3400: 07/18/09-(order broadcast)
3800 07/24/09-(2G1FK1EJ9A9129110)
4000: 07/24/09-(available to ship)
4200: 07/28/09-(shipped)
5000: 08/05/09-(delivered to dealership)
6000: 08/06/09-(delivered to customer)
strshp5 is offline   Reply With Quote
weird noise from the tranny .... Khrono Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 16 04-12-2011 07:43 PM
Annoying Vibration with After Market Exhaust cshaw2049 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 33 09-12-2010 03:14 AM
Wheel Vibration tmc Wheels and Tires Talk Sponsored by The Tire Rack 39 08-20-2009 09:14 PM
weird noise jeffny09 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 08-02-2009 11:15 AM
Normal Transmission Vibration??? ravensjeff V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 06-08-2009 02:16 PM
