HeadlightArmor
Old 11-19-2009, 01:45 PM   #1
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Black soot in exhaust pipes?
I've noticed with my car that the exhaust tips always seem to get coated quickly with black soot after washing them. Usually that is a sign that the car is running rich. I've had cars in the past do this but never to this extent.
Even my brand new SOLO kit only took about a day or two for the tips to get coated and lose their shine on the inside. When I picked up my stock exhaust from the shop this morning, I noticed that the inside was absolutely coated from front to back with this crap. Even the drain holes in the mufflers were leaving black streaks on the undersides as moisture seeped out.
On the upside, all that soot makes identifying poor welds easier. My stock exhaust had a small leak on the connection for the H-pipe on the passenger side. It's got a nice black line where the soot is escaping and coating the outside of the pipe.
Is everyone else seeing this problem with their V6's? Anyone asked their dealer to check into it yet?
rolnslo is offline   Reply With Quote
Old 11-19-2009, 01:49 PM   #2
pinkcamaro10
2G1FC1EV1A9110079
pinkcamaro10's Avatar
Drives: 2010 2LT/RS, 2013 2SS/RS 1LE
Send a message via MSN to pinkcamaro10
my tips get coated really quickly too. Never really thought much about it though, although i don't remember the stock ones getting quite so coated as fast.
pinkcamaro10 is offline   Reply With Quote
Old 11-19-2009, 01:50 PM   #3
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
GM has the V-6 and V-8's running super rich. I guess it is to save the cats but isn't polluting more running to rich?
Scott@Bjorn3D is offline   Reply With Quote
Old 11-19-2009, 01:53 PM   #4
mfr1950
mfr1950's Avatar
Drives: 2011 challengerR/T , 2010 Ram R/T
The tips on mine get soot on them when I use 89 or 90 octaine gas, this dosen't happen nearly as much with 87 fuel, dealer checked computer and indicated normal..
mfr1950 is offline   Reply With Quote
Old 11-19-2009, 01:54 PM   #5
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
mine does it to but i have the v8 but im pretty sure all cars r doin it and is pretty normal
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 11-19-2009, 01:58 PM   #6
rolnslo
Rolling along...
rolnslo's Avatar
I've only run Chevron 87 octane in mine. Wonder if it might have anything to do with why my car dyno's at 240rwhp rather than the 250-260hp range.
My '97 C1500 (sold) and my wife's '04 Expedition are both V8s and they had a little bit of soot but nowhere near as much as my V6 Camaro does.
Old 11-19-2009, 04:35 PM   #7
CiscoBee
Drives: 2010 Camaro Rally Yellow 2LT
Yep, I have lots of soot in the tailpipes. More noticeable after the exhaust was installed. Without a good tune we probably are running rich and not noticing the max performance that these cars can put out.
CiscoBee is offline   Reply With Quote
Old 11-19-2009, 05:35 PM   #8
Badger
Badger's Avatar
Drives: 2010 ABM SS #14 of 2,027
I have run nothing but 93 in my SS and have the same black soot on the tips..I am assuming that it is running rich. hopefully my new Vararam will lean it out just enough to maybe make a bit of a difference. We shall see.
"One of the ordinary modes, by which tyrants accomplish their purposes without resistance, is, by disarming the people, and making it an offense to keep arms."
-- Constitutional scholar and Supreme Court Justice Joseph Story, 1840
Badger is offline   Reply With Quote
Old 11-19-2009, 07:33 PM   #9
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Yes, the V6 runs very, very rich stock. I can't remember the exact number but I think it was something like 11.5:1 afr.
Theres a dyno sheet around here somewhere (from a long time ago) that shows the exact number...
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 11-19-2009, 10:08 PM   #10
efpardo
Deep6
efpardo's Avatar
Drives: 2016 Camaro #182300 | 2SS | HBM
Send a message via Skype™ to efpardo
soot - Yes - lots of soot
My Journals:
Erick's Mistress - Violet 2016 2SS
#182300 | 2SS | HBM |
Erick’s Mistress - 2010 2LT
#8212 | 2LT | RS | CGM | Litho #165 |
efpardo is offline   Reply With Quote
Old 11-20-2009, 04:48 AM   #11
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Yeap was told my car was running really rich when asking other members about my car feeling weak. It seams to be a bad thing but is it normal for our cars, are Rey tuned purposely to run rich? It annoys me like hell, none of our other cars do this, not even close o the camaros extent
Old 11-20-2009, 06:20 AM   #12
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Couple of things.... My dyno guy who also tunes a lot of GM cars said he has found that GM motors like to run a bit on the rich said... that when he tries to lean them out a bit they really don't see much of performance gain and they start to ping...
The other thing to remember is the LLT is running a very high compression ratio especially when you consider it is running on 87 octane! So basically you douse things with gas to prevent pinging... IIRC...
Also... wife's Acadia has the same LLT motor.. tips are always black..
scrming is offline   Reply With Quote
Old 11-20-2009, 07:26 AM   #13
Vinz68
Vinz68's Avatar
Drives: 68,69,72&10 Camaro's 12 CTS-V
Mine is the same way. I know on my car after I installed full exhaust and cai the tips looked clean. A few days later I got a tune and now they are black.
Vinz68 is offline   Reply With Quote
Old 11-20-2009, 08:30 AM   #14
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Interesting, thanks for the good info!
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 4242 02-17-2014 09:57 PM
Heard exhaust of L99 tonight - OMG!!! Hylton 5th Gen Camaro SS LS LT General Discussions 60 03-06-2010 06:03 PM
November Month Special on 2010 Camaro Corsa Exhaust GmPartsDirect.com V8 Bolt-Ons & Tunes 0 11-01-2009 12:46 PM
V6 Camaro STRAIT PIPES VIDEO will be Posted Tomorrow!!!! derin11 5th Gen Camaro SS LS LT General Discussions 2 06-07-2009 05:04 PM
