Elite Engineering
Old 11-20-2009, 12:46 PM   #1
ffrcobra_65
Heads Up - Clutch Spring noise
Yesterday, I pressed the clutch pedal and heard a creaky/twangy sound for the 1st time. I pressed the pedal more times and no sound. Continued driving and the creaky sound occurred at maybe once in 5 -10 clutch press intervals.
So, I started thinking, ok, it is a hydraulic clutch so no cable and the noise is not coming from the center area so not the clutch or tranny itself.
So, when I got home, I kept pressing the pedal while I focused on the where it was coming from as I suspected it was the clutch pedal spring. Well, I looked up at the pedal assembly and saw one end of the spring goes into a tiny white plastic bushing that goes into a hole in a bracket. Well, the bushing had slipped off. I popped it back in and so far, no more creaky/twangy sound.
Just a heads up boys and girls.
check the two white bushings...one on each end of the spring.
Old 11-22-2009, 10:04 AM   #2
deadlyarcher72
deadlyarcher72's Avatar
Drives: 2SS RS BLACK WITH GFX GRAY INT
My car is doing the same thing. I planned on taking it the shop because im not a mechanic and wouldnt know what to look for. Do you have a pic?
deadlyarcher72 is offline   Reply With Quote
V8 manual question derin11 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 63 07-28-2016 11:55 AM
Clutch pedal squeaky noise buddylok Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 01-03-2012 06:34 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
why does it make such a clunky noise when putting the clutch in yellow1 5th Gen Camaro SS LS LT General Discussions 16 07-07-2009 07:19 PM
Clutch Noise? GLBL WMR V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 05-24-2009 01:04 AM
