BeckyD@RodgersChevrolet
Old 07-22-2008, 12:06 AM   #1
shadowed_Stranger
WAITING!
Drives: 97 V6 5spd
Transmission gear ratios
I am not pro here, but I downloaded the camaro specs .pdf and the SS with the manual trans had a much longer first gear than any of the other ones, it was 3.0 while the automatic SS had a first gear ratio of 4.0
I thought this was weird considering the v6 auto was 4.0 as well and the v6 manual was 4.5
I was wondering if they purposefully did this to cripple the manual since it has more HP than the auto, and then when I read the 0-60 and 1/4 times it matched up with waht I was thinking and it scared me.
Opinions/correcting my dumb ass?
Originally Posted by Nine Ball View Post
Telling Camaro owners to do the speed limit is a lot like telling a room full of straight men to kiss boys.
Originally Posted by C P View Post
I'll go ahead and say it... how could GM let this happen? They have 5 years to develop the new Camaro and no force field to protect from uninsured drivers???? I'm buying a Honda.
shadowed_Stranger is offline   Reply With Quote
Old 07-22-2008, 12:08 AM   #2
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Well, the 4.0 seems to be standard fare for both the autos. So there is no outlier there. The V8 manual has a normal first gear ratio. The V6 manual comes straight from the Caddy, so the explanation there is easy - granny gear. Which, I don't like, but its life. As for the auto vs. manual difference on the SS - I don't honestly know. Is it normal for an auto to be geared steeper to get going better? Not sure.
- Xanthos
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 07-22-2008, 12:11 AM   #3
shadowed_Stranger
WAITING!
Drives: 97 V6 5spd
- Xanthos
On most vehicles, autos usually have less gears than manuals. Same with v6.
But here every tranny has 6 gears... I wish I klnew more about cars I am so confused..
Old 07-22-2008, 12:18 AM   #4
Xanthos
PWA Relapse
Xanthos's Avatar
No - I wasn't talking about number of gears. Think of it as an auto-tranny version of a granny gear. Which, if you don't know what a granny gear is (not trying to call you stupid, just providing all information because I don't know what you do and don't know), its a very steep first gear to aid inexperienced or generally bad drivers in getting a manual car moving. Steeper gearing means that the car can take off with less throttle and/or more clutch slippage, thus allowing the car to be more forgiving in its launches.
- Xanthos
Old 07-22-2008, 12:25 AM   #5
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
well, in the past autos have had fewer gears than the manual for the same vehicle. which means that the manual can have steeper gears cus you have more to row thru to get to your top gear.
however, the real question is why do neither of the autos have a 1:1 ratio?
dyno tuning should be fun now....
I piss excellence
and fart awesomeness
Old 07-22-2008, 12:46 AM   #6
Xanthos
PWA Relapse
Xanthos's Avatar
Well, thats where my knowledge ends - I have no clue why the autos are geared the way they are. Plus, I've never had a car on a dyno (all the shops in my area charge ludicrous amounts), and I've certainly never had one dyno tuned.
- Xanthos
Old 07-22-2008, 02:26 AM   #7
CamaroSpike23
Truth Enforcer
- Xanthos
well for dyno tuning, you optimally want to be at a 1:1 ratio from the engine to the trans. that way your tranny is spinning at the same rate as the motor, so you can get a true reading of your engines power. tho i guess you could compensate by calculating for a certain gear, but who wants to do that.
autos are normally geared the way they are due to the fact that with the fluid mechanics of an auto, your torque is multiplied allowing you to run a different set of gear ratios as compared to a stick where it is direct connection.
I piss excellence
Old 07-22-2008, 02:29 AM   #8
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
well I remember back reading about the TR6060 that's in the new camaro and honestly I was kinda disappointed that they were going to it. but at the same time taller gears means higher top end. . .but could mean longer to get there.
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 07-22-2008, 03:08 AM   #9
shadowed_Stranger
WAITING!
Drives: 97 V6 5spd
whocares about that? how often will I get to the higher top end of 180 instead of 170?
I would rather 0-60 and 1/4 any day of the week because that Is how I make ricers feel my wrath.
Old 07-22-2008, 03:24 AM   #10
boxmonkeyracing
juggernaut
um someone that has a very good chance of moving to germany?
seriously there should be a compromise between acceleration and top end. and honestly I feel the T-56 didn't give much of a top end. only 165 on the speedo and felt slow getting there.
Toyota plant workers make case for unionization KILLER74Z28 General Automotive + Other Cars Discussion 46 03-20-2009 11:36 AM
Dual clutch transmission (DCT)? Bruno Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 03-08-2008 04:47 PM
big news for 4L60e/700r4 owners CamaroSpike23 General Automotive + Other Cars Discussion 0 02-02-2008 08:56 PM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 06:11 AM
