| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() ![]() Drives: 73 RALLYSPORT Join Date: Jun 2009
Cam Headers Intake Tune 446 RWHP 430 RWTQ
9PM just got off the dyno.
We just finished a Cam, Pushrod, Trunion, Valve spring, Retainer, Seal, cam gear, All Comp Cams except the gear. Also Dynatech Headers and cats in to existing Corsa cat back, topped off by a Rotofab intake. I tuned this one with HP Tuners on the Superflow, Spent a lot of time on Idle quality, Startup, throttle response, this is a pretty big cam, I will let Tim fill you guys in on the specs, if he wants to ![]() The Results Best Pull 446 RWHP, 430 RWTQ. Here is a dyno sheet with this car layed over another strong car with 377 RWHP 382 RWTQ for comparison.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs! Ted Jannetty Jannetty Racing Ent Inc. 2984 East Main St. Waterbury Ct. 06705 203-753-7223 tedj@jannettyracing.com www.jannettyracing.com www.turboaddictionparts.com Performance Parts |
NOICE!!! ™
Noice LS3 or L99?
Flippin sweet! I can't wait to bang some gears, and punish those back tires. I think I need to get a video camera so you y'all can here it. Hell, I can't wait to hear it!
#4 | |
![]() ![]() ![]() ![]() Drives: beated up old mini austin Join Date: Jun 2009
#5 | |
Second, I would be very sceptical of a Claim Like that, I have been building engines since 1979 If you can find 20 hp with one good cam over another already strong cam your doing great. As I stated above, I pulled a Sheet from a Very Strong Stocker I had on file, I don't know what the Baseline of this particular car is, but I would expect it to be in the 370s. Cam, headers and cold air kit does not Gain 115 RWHP Sorry I have to call ![]() What is most impressive is the Broad torque curve, I suppose If I Spun the Motor another 1000 RPM with an even Bigger Cam I could find More hp, BUT at what expense of torque where you drive most. I am confident that Tim will Be happy with this combo. Besides it Sounds cool.
#6 | |
![]() ![]() ![]() ![]() ![]() Drives: 2008 G8 gt / 2010 Camaro L99 Join Date: Oct 2008
Nice Job JANNETTY ... That car should move out nice , A good DD
TuneTime Performance
Toms River NJ 732-349-7800 Home of the Fastest Super Charged G8 2010 Camaro Super Chevy Feature Car Stage 2 with drag Pac 11.62 @ 121.33 Stage 2 + 12psi on 20's 10.92@ 129.95mph |
#7 | |
![]() Drives: 2010 ss Join Date: Aug 2009
#8 |
![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
On my LS2 GTO, I made 95 rwhp with a custom cam from flowtech http://www.flowtechinduction.com/, full exhaust, intake, tune.
This was also a pretty conservative cam and had excellent street manners. So you can make impressive gains with just a cam, exhaust, intake, and tune.
2SS/RS, L99 A6, Vararam, Kooks 1 7/8, Magnaflow street, Tune (12.55 @ 111.64 mph)
TSW Nurburgrings 20x9.0 and 20x10.0 ![]() |
#9 |
Heres another car that picked 64whp adding only g6x3 http://videos.streetfire.net/video/L...Cam_153920.htm it looks like its most probably the most widely used big cam in the vette world (and i think comp cam grind them too. )
#10 | |
See the big dip in the torque curve where it almost the same as stock. I don't like it.
#11 |
That dyno graph does look pretty nasty. Looks like it made good HP up top but that's about it. Down low, it didn't do much HP/TQ.
#12 | |
The Same goes for the GTO Headers exhaust, and Cold air intakes Bigger gains than from Camaro same mods. Typically Cams Alone are good for 20-40 RWHP if all supporting mods are already in place and require custom tuning to take advantage of the cam so probably less. No significant Cam Can be installed without a tune so Who Really knows. Again Don't Look At the Peak Gain Look at the Torque Curve that is what you feel from the drivers seat and gets you down the 1/4 mile the fastest. Ted.
#13 | |
![]() ![]() ![]() ![]() Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
The G6X3 has proven itself in Corvette's for close to 2 years now at our shops and others. The Camaro you see on here with that cam was all customer installed and tuned. It was not done here, we just supplied the parts. ![]()
#14 | |
#15 | |
I have been building engines and drag racing since 1979 and a smaller cam with stronger torque curve will always out accelerate a big cam with low torque. Especially for anything driven on the street Acceleration is what it is all about. Kind of like a Positive displacement VS Centrifugal, Torque is a Blast to drive. I am sure your line of cams are fine and I am sure you have something more Street oriented that does not give up much HP but makes a stronger torque curve. There are only so many lobes to choose from Ted.
#16 | |
![]() ![]() Drives: 2006 Duramax Join Date: Aug 2009
You do know you are only below 5k rpm the first 130ish feet of a 1320ft racetrack right? The car will never see below 5k rpm the other 1190 ft. That is where the peak power really shines and produces NA times a full half second faster than anyone else out there running NA "cam only".For that matter its faster than the heads cam cars. Only ONE NA car is close to the times this G6X3 with its sloppy TQ curve! It looks to me like you just need a reason why it makes 50 rwhp more. ![]() If it were to make 525rwhp with heads on it would you call BS also? Last edited by Sam88gta1; 11-21-2009 at 05:36 PM. |
#17 |
![]() ![]() ![]() ![]() Drives: 2010 2ss silver/cyb Join Date: Feb 2009
#18 |
I like Janetty style; and so far they have been more then helfull for everybody. They are well informed etc...BUT they cant put down the best cam of the vette world (no its not only big talk...go on the corvette forums to see what its about....NUMEROUS NA 10 seconds cars without anything more then a set of headers ,this cam and drag radials. Its recognized as the best road racing cam too. http://www.youtube.com/user/OrangeCh.../2/tPH_vWePCNk
-stock with a tune vs lontubes with a tune ![]() -longtubes, adm cai ,g6x3 and a tune...
#19 |
look at the upside graph JANETTY because 340 foot pounds at 2050rpm is hardly bad. In fact its BETTER THEN STOCK. And how is almost 100whp at 6500rpm????
#20 | |
How is that cam on the street? Or is it primarily a race cam? Can that cam be used as a good daily driver cam? Thanks
#21 | |
#22 |
Well, I am glad I got everyone to talk it was getting too quiet around here.
#23 |
#24 | |
Since you brought it up a 1.6 anything 60 ft. in 121 mph car is sad, should be going high 1.4s if it had enough torque. That would put the car in the 10s at 121. Races are won in the first 60 ft. Sorry If I seem a little partial to acceleration but my Sled goes 1.1s in 60 ft 4.9s at 140 in 660 ft. and my 73 Camaro goes 1.3s on the rear tires. ![]() You see when I was 19 I had a cam that made big power but it would not 60 ft. so I learned. All though it was good on the hard compound Pro Trac L-60-15s ![]() Guys Please don't take offense it is all in good fun and discussion only.
#25 |
| Thread Tools | |
| Official 1/4 Mile 2010 Camaro Fast List | SGOS252382 | Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions | 566 | 08-28-2010 08:11 AM |
| V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 51 | 08-21-2010 07:03 PM |
| ADM Stage 1 CAM - No tune required | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 61 | 06-09-2010 07:00 PM |
| Fastlane Stage II Camaro w/ LTs, CAI, Exhaust, Tune & Cam = 460rwhp / 428 rwtq | Dantheman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 124 | 10-17-2009 03:05 PM |
| LS3 CAM AND HEADERS DYNO | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 45 | 04-12-2009 01:05 AM |
