Gen5DIY
Old 07-22-2008, 12:52 AM   #1
tsg1391
Drives: 79 formula 'bird, 5th gen soon
can we turn afm on/off? or delete it??
like the title says, i want the ss with auto, but i dont want afm...
everyone on the g8 forums say it sounds funny when the cylinders de-activate when you have a loud exhaust. and if i am buying a v8 camaro, i want a loud exhaust!! gah, i wish i could get an auto with ls3
does anyone know if the afm only kicks in past a certain speed? or after a certain time of going the same speed?
tsg1391 is offline   Reply With Quote
Old 07-22-2008, 12:58 AM   #2
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
It only kicks in when you hit the gas. You won't notice any lag. It's a very impressive feature.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:154 ban
Old 07-22-2008, 01:08 AM   #3
tsg1391
i am talking about afm, active fuel management. im not trying to sound rude, but i dont see the point of it cutting cylinders when you accellerate?
Old 07-22-2008, 01:20 AM   #4
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
That's good, because niether does the system.
That's not how it works...when you're cruising at highway speeds or decelerating, the engine will shut half of itself down; saving fuel. When you idle or when you accelerate; AFM is inactive, and you can barely feel it switching on/off.
Old 07-22-2008, 01:21 AM   #5
pinkcamaro10
2G1FC1EV1A9110079
pinkcamaro10's Avatar
Drives: 2010 2LT/RS, 2013 2SS/RS 1LE
Send a message via MSN to pinkcamaro10
hmm maybe you are confused or i am.
it doesnt cut cylinders when you accelerate.
when you are just doing normal daily driving it just uses 4 instead of 8, and then when you accelerate it will use all 8..
arghhh dragon you beat me.
pinkcamaro10 is offline   Reply With Quote
Old 07-22-2008, 01:22 AM   #6
The_Blur
Jayhawk USN
The_Blur's Avatar
If you really wanted a 4-banger, you'd be looking at a Cobalt. AFM does just what Dragoneye said. It activates when you're on the gas. If you hit cruise or idle at a speed, it will maintain speed with less cylinders active. This saves a considerable amount of fuel.
TO: Camaro5//
warn 145:154 ban
Old 07-22-2008, 03:28 AM   #7
tsg1391
dragon, i meant to quote the blur when he said it only kicks in when i hit the gas... i know what afm does/is, i am just concerned about exhaust note. maybe im just freaking out
Old 07-22-2008, 03:37 AM   #8
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Go test drive a G8. I believe they have AFM on one or more of the models
Old 07-22-2008, 05:10 AM   #9
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
and don't let afm make up your mind about buying a car. AFM is an excellent thing that YOU will get on your auto. I can't get it since I'm getting the LS3 M6. If it really does sound that bad after you test drive it, then just change out the exhaust later on.
Old 07-22-2008, 08:59 AM   #10
Jak
Jak's Avatar
Drives: 03 Dodge Dakota
I test drove a G8 GT and with the AFM you don't even feel or hear any difference. Then like Dragon says soon as you hit the gas it deactivates and your running on all 8 cylinders, let off the gas and coast or idle it activates an your on four. Personally I'm a little disappointed at the gap in horses but it's not anything that'll change my mind.
Jak is offline   Reply With Quote
Old 07-22-2008, 10:17 AM   #11
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
I have been assured that you can delete the AFM from the program and change the exhaust to make it as loud or quiet as you'd like... so fear not, auto lovers of the world, your car can still be setup like you want it... its just going to have to be done in the aftermarket
got tequila?
SilverTurtle is offline   Reply With Quote
Old 07-22-2008, 10:38 AM   #12
EllwynX
EllwynX's Avatar
Drives: 2010 Camaro SS
I wasn't aware that AFM deactivated the cylinders when you idle'd or let off the gas.
I thought it just activated when you were at highway speeds.
If it also works as you've described, that makes me want it even more.
EllwynX is offline   Reply With Quote
Old 07-22-2008, 11:36 AM   #13
the_saint
Member
the_saint's Avatar
Drives: rusty
with a hand held programmer you should be able to deactivate it just as they do on the hemi's.
the_saint is offline   Reply With Quote
Old 07-22-2008, 12:01 PM   #14
Jak
Jak's Avatar
It just kicks in when the cars on a light load, crusing speeds like on the highway or crusing up and down main street, anywhere that your not pushing down on the gas. Soon as you step on the gas then all eight kick in. 'least that's my understanding on how it works after speaking with mechanics and reading up on it.
AFM v8 Engine The80sman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 06-13-2008 11:19 AM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
