SDTW Custom Wheels & Tires
Old 11-20-2009, 10:10 PM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
Is the factory exhaust good enough to use?
I have a local muffler shop that says he will do a muffler delete, use my factory tips, and install a Magnaflow X-Pipe for $350. For the first few years I only plan on doing an exhaust, CAI, and maybe a tune for my performance mods. I already have plans for another handful of non-performance mods (shifter, tint, AAC lights, springs, stripes, etc) so I have plenty of other places to be putting extra $$$.
The question is….how bad is the rest of the factory exhaust system? I hear some say the factory exhaust is actually very good and flows well. It’s just not very loud. Then I hear other people try to talk up their aftermarket cat-back systems (ex: Magnaflow Comp or SOLO Mach X) by saying the factory exhaust has several crimps in it and their mandrel bent systems will be much better. Otherwise, IMO, those systems are basically the same…..a muffler delete with an X-Pipe.
If I go with the local muffler shop’s exhaust do you think the remaining factory system will be bad enough to justify spending the extra $400 - $500? After all, that will cover the cost of my shifter or AAC lights.
My gut feeling is…Yes….the aftermarket cat-backs would be better but until I start doing things like adding LT headers or maybe a Cam I won’t really notice a difference. Go with the local shop and use the extra money on my other mods. I should still get a small increase in HP (guessing 15 rwhp) but maybe not as much as the 3rd party cat-back systems (roughly 20 rwhp).
What is your take?
BTW: This will be my daily driver (although I work from home and only put about 7k a year on my cars). I will have more fun goosing it from stop light to stop light or maybe catching the occasional Mustang/Challenger on the street. I’ll probably go to the track a couple times a year just for fun but not to be super serious.
Build Journal
Old 11-21-2009, 01:32 AM   #2
alssiri
alssiri's Avatar
Drives: 2012 ZL1 A6
I think it is good enough but it is :
1- Heavy.
2- Quite.
3- Bulky.
I dont think there is big difference in power.
Ahmad
2012 ZL1 A6
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Corsa Sport Catback, ADM 102mm Snout, CAI, NW 102mm TB, ID850, AGP Dual Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
2015 Rear Fascia Conversion, Z/28 Side Skirts, Flares, Spoiler & Diffuser , ACS Quarter Ports, ShowStopper's Side Marker's, LightWurkz Halo's.
Sosche With KenWood, SLP pod with PLX guage, DashLogic .
alssiri is offline   Reply With Quote
Old 11-21-2009, 04:44 AM   #3
wullger
Supercharged
wullger's Avatar
Drives: 2010 Camaro 2SS/RS
If you're not sure, or are wanting to wait till down the road a little bit before modding, look into how much the muffler delete minus the X-pipe would be. Everything gets better once those huge trash cans are off the car Modified exhaust, in most any form you can get is a gift that keeps on giving Been enjoying my Flowmaster setup since the day I got it. Magnaflow's cat-back system sounds AWESOME, I just didn't care for the large exhaust tips.
2SS/RS IBM A6, White Rallies
Ordered: 4/30/09 Delivered: 8/18/09
Appearance Mods:
Heritage Grille, ZL1 Replica Wheels
Performance Mods:
Flowmaster ARH Cat-Back Exhaust, ADM CAI, ADM L99-LS3 Conversion, ADM LSA Supercharger Kit, Lingenfelter GT9 Cam, Stainless Power Headers, Detroit Speed Sway Bars, ZL1 Fuel Pump
581 rwhp/535 lb/ft tq
wullger is offline   Reply With Quote
Old 11-21-2009, 06:58 AM   #4
chevyss
SS/RS
chevyss's Avatar
Drives: 2010 SS/RS IOM w/blk stripes A6
I replaced my exhaust right after I got the car. American Racing LT w/3" back to axle, used stock t/pipes and mufflers. It really sounds nice. Quite while cruising around town, but when you get on it it is great.
chevyss is offline   Reply With Quote
Old 11-21-2009, 08:56 AM   #5
caverman
caverman's Avatar
1- Heavy.
2- Quite.
3- Bulky.
Ahmad
1. Yes...but I think that once the mufflers and H-Pipe are removed it will significantly reduce the weight.
2. Agreed....but not once the mufflers are removed.
3. Not sure I understand that one. Once the mufflers are gone and X-Pipe put into place the only reason it should be coming out would be to completely replace it.
I guess my biggest concern is with the so called crimps in the exhaust. Is that really going to cause any kind of a noticeable difference in performance? I doubt it would have anything to do with sound.
Build Journal
Old 11-21-2009, 09:02 AM   #6
BlownSS
BlownSS's Avatar
Drives: 2010 Camaro SS/RS
NO!
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
BlownSS is offline   Reply With Quote
Old 11-21-2009, 09:06 AM   #7
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
When I got my Zoomer's catback exhaust the biggest difference I noticed other than the sound was how much smoother the acceleration was. The throttle response is smoother and it accelerates more evenly and doesn't feel like it's pushing against something. I also love the growling roar it makes when I start the car.
I'm very glad I got mine and couldn't be happier with it.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 11-21-2009, 09:22 AM   #8
MoranoRacing
Drives: 2005 GTO, 1973 Camaro
The factory mufflers are heavy. If you do a muffler delete your car may be a bit too loud for daily driving so I would atleast try to get nice sounding mufflers that flow good. I would recommend the SLP Loud Mouth 2 exhaust because it is just an axle back exhaust. It comes with mufflers, piping and tips, all for 539. It costs alot less than a full cat back exhaust and looks great.
MoranoRacing is offline   Reply With Quote
Old 11-21-2009, 09:39 AM   #9
Iron Lung Jimmy
Drives: Iron Lung, Jimmy
This made me decide to scratch the cat back idea and live with a quieter car for now...
Originally Posted by JANNETTYRACING View Post
These Cars DO NOT Respond to Cat back exhaust changes, we test every one we install on a new model like this so we know for sure.
Ted.
Iron Lung Jimmy is offline   Reply With Quote
Old 11-21-2009, 10:15 AM   #10
Doc
Doc's Avatar
They may not respond as far as showing more horsepower on a dyno but it DOES make a difference in the type of performance you get when you press the gas pedal. Stock the car feels like it's pushing against something when you accelerate; it's not quite linear or smooth. You don't appreciate or realize this until that is changed by a smooth flowing catback system.
With the new system you can feel the difference; the throttle response is smoother and makes the car feel stronger. The power getting to the rear wheels may be the same but how smoothly it gets there is improved.
1SS/RS LS3 M6 IBM
Old 11-21-2009, 10:29 AM   #11
FwyFlyer
FwyFlyer's Avatar
Drives: 2010 SS/RS
If sound is what you're after......
You might address the "crimps" if you're going to squeeze out every ounce of HP/TQ she's got. Get the X pipe, get rid of the resonators, and add some quality mufflers. Ask around, there are tuners on this forum pushing 500hp with the stock 2.5" pipes. The muffler delete sounds "raw" to me, but may suit your needs right now. Oh ya one other thing, avoid using clamps except for maybe just after the cats. If your muffler shop knows their stuff they will agree that welds will eliminate that annoying popping by preventing air from being sucked in and igniting your exhaust on decel.
Those of you with clamps don't believe me? When your car is cold, start it up and run it for a few minutes but don't drive it. Shut it down then take a look under the car later and see where the moisture has puddled up under your clamps.
That civilized rumble of a quality muffler is worth every penny in permagrins.
FwyFlyer is offline   Reply With Quote
Old 11-21-2009, 11:14 AM   #12
caverman
caverman's Avatar
I like the sound to the LM II but you pay $540 + $100 (X-Pipe) and then maybe $150 to have it all welded in I might as well pay about $100 more and get the 3" MBRP system.
Where is the thread this came from. I can't believe that the Camaro wouldn't respond to a better flowing exhaust. Even if that was the case I would have to at least do the LM II for better sound.
So Doc.....do you think I would have to go with an aftermarket cat-back in order to get a better throddle response? Wouldn't putting on a X-Pipe help do that as well? Is the Zoomer system a 2.5" or 3" system? About how much do they cost?
This sounds logical. I will definately have him weld up everything if I go with a local guy. I'm not really trying to squeeze every little HP out of it. I don't think I'll really notice a 5-10 HP difference. I might try the muffler delete and x-pipe. If it's to loud I can get some LM II mufflers. Only thing is that they are about $200 plus my guess of $60-$100 to install. By then I'm getting only about $200 away from MBRP system? Thats where I can't decide if it would just be better to step up and buy a complete system.
Another question: when you refer to the resonators, aren't you just talking about the H-Pipe? Doesn't the X-Pipe replace that?
DAMN.....this is hard to decide!
Build Journal
Old 11-21-2009, 11:28 AM   #13
towmoe
towmoe's Avatar
Drives: IBM 2010 Camaro
I did the muffler delete with an added X-Pipe in place of the H-Pipe last week. It cost me $160. The X-Pipe looks just like the Magnaflow X but is not stainless and is an off brand. The setup sounds great! I thought it would be too loud but it's not even close to being too loud. Also, the X-Pipe has definitely helped the throttle response. I can feel the difference.
So yes, I think the factory exhaust is good enough. My take would be do the muffler delete with an X-Pipe. Much cheaper than going with a full after market exhaust. Sounds great and is no where near too loud. The X-Pipe helps the exhaust flow which helps the throttle response. Also, the X-Pipe does not replace the resonators just the H-Pipe. I still have my resonators in place.
2SS/M6 | Imperial Blue Metallic | White Stripes | Black Int
towmoe is offline   Reply With Quote
Old 11-21-2009, 11:51 AM   #14
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
I have the magnaflow street system... And if I were to do it again, would go with your route. . x piple and magnaflows on the back... done.
franknbeans is offline   Reply With Quote
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 547 03-07-2017 05:26 PM
Custom Magnaflow Exhaust buddylok Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 49 05-16-2016 11:02 AM
Dynatech Long Tube Package With Corsa Exhaust tbyrne V8 Bolt-Ons & Tunes 2 09-19-2009 08:44 AM
Opinions on Challenger Vs. Camaro exhaust only OUTATIME Chevy Camaro vs... 16 06-23-2009 04:31 PM
Factory Exhaust Option SPECULATION!!!! jmliptak Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 07-21-2008 10:13 AM
