Old 11-21-2009, 01:36 PM   #1
Camarorss350
camaro blogger
Camarorss350's Avatar
Drives: 2010 Black on Black SS/RS
Send a message via AIM to Camarorss350
tire rotation...
Easy question for all...
Whats the best way to know that you need to rotate your tires? My car is all stock with the expensive p-zero's and id like to make them last as long as possible. Is there a schedule to follow? What is the pattern for rotation?
Thanks again for the help guys!
Camarorss350 is offline   Reply With Quote
Old 11-21-2009, 01:41 PM   #2
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
The 20" and the 21" tires on the Camaro can NOT be rotated. They are unidirectional tires and the are rims are staggered meaning the rims in the back are bigger then the fronts.
Old 11-21-2009, 01:54 PM   #3
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
The 20's are NOT directional.
But they are staggered so all you can do is find 2 more and decide what size you want to run... 245 or 275 all around.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 11-21-2009, 02:08 PM   #4
5thGenCamaroChick
Hey y'all :)
5thGenCamaroChick's Avatar
Drives: Rosalee
So you can't even rotate them side-to-side?
"Are you picking up what I'm laying down? Can you dig what I'm growing?"
5thGenCamaroChick is offline   Reply With Quote
Old 11-21-2009, 02:33 PM   #5
OUR72GTO
OUR72GTO's Avatar
Radials have always been front to back .... back to front.
Old 11-21-2009, 02:49 PM   #6
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
according to Tirerack...you can rotate them side to side, as long as they are not directional tires...don't really know how much that's gonna help though.
http://www.tirerack.com/tires/tirete....jsp?techid=43
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 11-21-2009, 03:21 PM   #7
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
There isn't any benefit going side to side unless your car is pulling causing more wear on one side then the other in which case you have bigger issues then just your tires.
Old 11-21-2009, 03:40 PM   #8
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Best way to rotate your tires? Floor it!
Old 11-22-2009, 01:28 AM   #9
OBSSEST
Drives: 2010 Camaro 2SS RS, Black
Although my 20" P-Zeroes aren't "directional", they do have an "inside" which is marked on the sidewall.
So, you could switch from side to side, but the tire would just be running backwards from what it was before, with the same edge on the outside.
OBSSEST is offline   Reply With Quote
Old 11-22-2009, 03:41 PM   #10
canadian ss
Psycho on day pass
canadian ss's Avatar
Drives: 2010 yellow 1ss m6 -GM tech
Going side to side WILL cup the hell out of your tires. Every tire I rotated side to side because the customer is always right came back a few months later with cupping or belt seperation causing a nasty bump in the tire. Side to side was fine for bias ply.
IMO, rotating wears down all 4 tires so you need to purchase 4 at a time instead of 2. On my cars its usually the 2 rear.
canadian ss is offline   Reply With Quote
Old 11-22-2009, 04:41 PM   #11
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
I never replace tires without replacing all four anyway. If a couple have a bit of tread left, I just sell them to a used tire dealer.
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 11-22-2009, 04:44 PM   #12
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
That is why I opted for the 19" tires instead of the 20".
I thought having different size tires in the back than the front was ridiculous.
Also I bought the lifetime warranty from Discount Tire for $150.00 which covers repair, replacement, rotation, and balance of all 4 of my tires.
tradosaurus is offline   Reply With Quote
Old 11-24-2009, 04:16 PM   #13
5thGenOwner
5thGenOwner's Avatar
Drives: '10 SS & '15 FRS
It might sound rediculous... but it looks beefy! I don't mind replacing 2 tires at a time, when they are gonna run me $500+ each.
5thGenOwner is offline   Reply With Quote
Old 11-24-2009, 04:32 PM   #14
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Looks beefy yes, but I'd prefer longer wear I put the same rear tires/wheels on all 4 corners so I will be rotating them. Suggested in the Owner's Manual is:
"Tire rotation is recommended if the vehicle has the same size tires on all four wheel positions.
These tires should be rotated every 5,000 to 8,000 miles (8 000 to 13 000 km). See
Scheduled Maintenance on page 10-2."
It shows side to side and front to back so I would think cris-crossing them is ok. If people say it cups them, then I'll just do back to front
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Tire Sealant Kit - Warranty Issues jbreed Wheels and Tires Talk Sponsored by The Tire Rack 38 09-14-2011 03:18 PM
500.00 per perelli tire not a myth! AVman Wheels and Tires Talk Sponsored by The Tire Rack 51 10-20-2009 04:45 PM
WHAT A NIGHTMARE!!! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 110 09-27-2009 12:25 PM
20 inch tire rotation? wstuarttn Wheels and Tires Talk Sponsored by The Tire Rack 2 07-19-2009 09:15 PM
