Cold Air Inductions
Old 11-21-2009, 09:23 PM   #1
bub
bub's Avatar
Drives: '17 1SS 1LE & '15 Corvette Z06
V6 Oil Filter Pics
2017 Camaro 1SS 1LE Black with PDR
SOLD 2015 Camaro 2SS RS 1LE Red Hot
SOLD 2013 Camaro:
2LT RS Auto
Color & Trim:
Blue Ray Metallic w/ Black Interior
SOLD 2010 Camaro:
1LT RS Manual (RPO R6P Early Order)
Color & Trim:
Black w/ Black Interior
Options:
RPO WRS RS Package
RPO UQA Boston Acoustic Premium Sound
Order # NDVK94
Built 6/10/09
Delivered 7/18/09
(Previous Early R6P from Bozarth in Topeka)
bub is offline   Reply With Quote
Old 11-21-2009, 09:28 PM   #2
CAM MAN
CAM MAN's Avatar
Drives: ALL 5 GEN CAMAROS
Good pics I never seen inside of the filter before How mant QTS. does it take for
fill up Thanks !! Nice Z06.
CAM MAN is offline   Reply With Quote
Old 11-21-2009, 09:34 PM   #3
bub
bub's Avatar
6 qt. of oil meeting GM spec. GM6094M (Mobil 1 does, & it meets GM spec. for the V8 also).
The P/N shown in the owner's manual for the filter did not agree with the P/N shown on the filter, nor the filter the GM parts guy gave me.
The correct filter P/N is PF2129
SOLD 2013 Camaro:
2LT RS Auto
Color & Trim:
SOLD 2010 Camaro:
Color & Trim:
Options:
RPO WRS RS Package
Order # NDVK94
Built 6/10/09
Delivered 7/18/09
Old 11-21-2009, 09:45 PM   #4
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
you didnt change your o-ring on the housing?
firestone_ss is offline   Reply With Quote
Old 11-21-2009, 09:46 PM   #5
CAM MAN
CAM MAN's Avatar
Thanks ,I Had my 1rst oil change at done the dealer I might do the next one myself.
THANKS FOR THE INFO.
Old 11-21-2009, 11:08 PM   #6
dwall
Drives: 1995 Camaro
Wow! I had no idea the oil filter was on top. This should life much easier at oil change time.
dwall is offline   Reply With Quote
Old 11-22-2009, 08:44 AM   #7
cschmidt1956
cschmidt1956's Avatar
Drives: Too Little time to drive....
I don't think these filters come with an O-Ring replacement. My Olds uses the same one, and it has TWO o-rings and I have not changed those in 90K miles.
Looks like this one uses a high quality Silicone seal so that should be fine for a long time.
to the OP, how many miles did your filter have on it?
Thanks for the PICS!
cschmidt1956 is offline   Reply With Quote
Old 11-22-2009, 09:04 AM   #8
bub
bub's Avatar
This is the first oil change on my 1LT LLT V6. It had 1,514 miles.
I agree about the "O-rings" being re-usable. There's really no need to replace servicable parts.
The cap has a blue silicon O-ring that forms the primary seal to the outside.
There are rubber "grommets" on each end of the filter element itself that seal the clean side from the dirty side oil passages.
There is a second rubber "seat" at the base of the filter housing. The top cap seat is machined aluminum to allow the element to rotate upon re-installation/tightening.
Note the threads on the cap...They are not full circumference. I can only assume that this was done this way is to allow some oil to flush/coat all the cap's threads to make subsequent removal easier.
SOLD 2013 Camaro:
2LT RS Auto
Color & Trim:
SOLD 2010 Camaro:
Color & Trim:
Options:
RPO WRS RS Package
Order # NDVK94
Built 6/10/09
Delivered 7/18/09
Old 11-22-2009, 01:24 PM   #9
firestone_ss
ive never seen a cartridge type filter not come with a new o-ring,almost not a day goes by where we see a car in the shop with the housing leaking,open it up and the o.e.green oring is still there after 50k,trust me replace those o-rings people
Old 03-11-2010, 03:49 PM   #10
cschmidt1956
On the Olds Engine they used two heavy silicone o-rings. I've never replaced them and they are not included even with a factory filter.
Now my Saturn Astra motor with a similar filter does come with one in both the factory filters and the Purolator ones.
Old 03-11-2010, 04:19 PM   #11
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
Can we use the same Oil Filter on the V6 if we change the oil to Mobile 1 Synthetic from Conventional oil?
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC /Solo Mach X-LLT J-Pipe / JBA Headers Shorty
CAI - Cold Air Inductions / VMAX TB / Trifecta Tune
Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can
ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit
ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports
ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller
Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels /
Oracle Afterburners / Oracle Concept SMD Side markers
Complete SS Brembo Brakes Set
RickRay is offline   Reply With Quote
Old 03-11-2010, 04:24 PM   #12
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
where's the oil drain plug?
Old 03-11-2010, 07:00 PM   #13
OKCwhiteKnight
OKCwhiteKnight's Avatar
Drives: 2010 2LT RS Camaro 2015 Colorado
Didn't realize filter was up top like my ecotec HHR, I just went over 500mi on mine.
I am also in overland park bub, well at least during the week, weekends in OKC
OKCwhiteKnight is offline   Reply With Quote
Old 04-06-2010, 10:36 PM   #14
bub
bub's Avatar
Hate to be a wise crack, but, uh, underneath on the pan...
SOLD 2013 Camaro:
2LT RS Auto
Color & Trim:
SOLD 2010 Camaro:
Color & Trim:
Options:
RPO WRS RS Package
Order # NDVK94
Built 6/10/09
Delivered 7/18/09
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
Oil Pressure Spike on V6 ? Maclain Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 33 02-01-2012 02:45 PM
Looking for step by step oil change process traip93 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 31 04-24-2010 10:31 PM
