PFYC
Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions
Old 11-22-2009, 05:24 PM   #1
ClutchKargo
ClutchKargo's Avatar
Drives: 2010 Camaro 2SS/RS L99 RJT
DIY - Valentine V1 Radar Detector Installed to Rear View Mirror
I just finished installing my V-1 to my rear view mirror and it turned out great.
I used two products for the installation I got off eBay. First I used a "Stealth Mirror Cord" from Safe-N-Sound1 because it has smaller wires to push into the back of the connector than the inviscord which has to be filed down to fit. Then to attach my V-1 I used a mount from Blend Mounts. The mount was expensive, I also got the one that is hinged, but it gave the best mounting flexibility for adjustments on the install and I didn't mind spending a little more and doing it right the first time for my Camaro.
First using a #20 torx undo the mirror and slide it up the windshield bracket to remove it from the windshield. Then there is a two piece plastic cover over the connector and wire that goes to the mirror this will pull away from the windshield and down from the roof. To release the power connector take a small screw driver or pointed object and push in the release pin on the front of the connector and it will come right off.
You should now have the mirror completely removed.
Next you'll need to connect the Stealth cord. On the side of the connector closest to the metal winshield bracket is where you'll push in the Stealth cord wires. On one end you'll see a black and white striped wire, push the black stealth cord wire into the back of the connector where this striped wire goes in. On the opposite side of same row of wires there is a red wire which is one wire back from the end, there is a green wire on the end. Push the red stealth cord wire into the back of the connector where the red wire goes in. It's a little tight to get the red wire back in there, but use some thin needle nose pliers and take your time.
I then reconnected the connector to the car and fired up the V-1 to make sure the connections were good before I went on.
Next I used two cable ties to tighten the stealth cord to the existing wires to secure the connection.
I then installed the Blend Mount to the mirror and headed to the car to reinstall the mirror adjust and tighten it all up.
Everything went together fantastic and it looks great, for me this is much easier and cleaner than messing with running wires to the fuse box and/or cutting an soldering wires.
Now here are my pictures:
Red wire inserted into back of bracket into existing red wire slot next to Green wire, it's hard to see but there are two red wires in this slot.
Black wire into black and white striped wire slot
Cable tie the wires
Ready to reinstall
Plastic covers back over connector
Front View
Left Side
Right side
Second view Right Side
I hope this helps some of you with your radar detector installation.
Clutch
ClutchKargo is offline   Reply With Quote
Old 11-22-2009, 06:23 PM   #2
amanc96
amanc96's Avatar
Drives: 2011 SIM 2SS/RS
looks good! this looks like the route i want to go!!!
amanc96 is offline   Reply With Quote
Old 11-23-2009, 03:21 AM   #3
buddylok
buddylok's Avatar
Drives: 2010 Camaro 1LT (IOM)
Send a message via AIM to buddylok Send a message via Skype™ to buddylok
wow.. this is great.. I've ordered the stealth mirror cord last week, was wondering which wire to use from the mirror.
Thanks for the info.
__________________________________________________ ______
If you live in Canada, British Columbia with a 2010 Camaro.
Please join my facebook group:
http://www.facebook.com/group.php?gid=101509818230
buddylok is offline   Reply With Quote
Old 11-23-2009, 04:54 PM   #4
ClutchKargo
Glad I can help out............
The two wires I used are switched and work perfect.
Old 11-25-2009, 02:26 PM   #5
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
Nice write-up! Just ordered all the parts.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected
obe1 is offline   Reply With Quote
Old 12-05-2009, 02:46 PM   #6
obe1
obe1's Avatar
Just installed mine per your instructions; worked out great! I ended up notching one of the plastic covers where the new wire comes out. The fuse holder built into the wire ended up right at that junction so I snipped out a 1/4" notch with diagonal cutters and filed the edges smooth.
Old 12-05-2009, 02:53 PM   #7
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
nice write-up and install. But weird thing is that I used an invisacord and it fit perfectly.
2010 R6P-2SS/RS/LS3 - IBM w/ silver rally stripes / UNDER CONSTRUCTION.
NY5thgen.com
POWERFREAK is online now   Reply With Quote
Old 12-05-2009, 03:14 PM   #8
HaZe_X
HaZe_X's Avatar
Drives: Trailblazer SS & Camaro SS
Glad to see that the Camaro mirror mount is the same size as the one in my TBSS..great write up. Although I made my own wires for the back of the mirror to power the stealth display, so its totally PnP, instead of wire splicing.
HaZe_X is offline   Reply With Quote
Old 12-15-2009, 02:48 PM   #9
buddylok
buddylok's Avatar
I don't have the auto dimming mirrors with my 1LT and wires in the connector are different on the mirror side. So I have to tap into the top connector instead.
Black to Black, Red to Pink.
Old 01-31-2010, 12:47 PM   #10
SSTony
Drives: SS Camaro
Send a message via AIM to SSTony
where did you get the blend mount from?
SSTony is offline   Reply With Quote
Old 03-10-2010, 02:01 PM   #11
04Ram2500Hemi
Drives: 04 Ram 2500 & 2010 Camaro 2SS/RS
This is a great thread (I love the search function). I've been giving this a lot of thought since I ordered my Camaro. Great write up!
04Ram2500Hemi is offline   Reply With Quote
Old 03-10-2010, 11:44 PM   #12
Ivan @ Southwest Speed
Southwestspeed.net
Drives: '10 2SS/RS, '96 Z28
You guys really dig the V1? I have been wanting to invest in a detector...I've been SOTP'ing it for the last 20 years and sometimes it don't work out...lmao
Anything bad to say about em?? I've read great things.
Thanks,
Ivan
Ivan @ Southwest Speed is online now   Reply With Quote
Old 04-16-2010, 08:43 AM   #13
enigma
Drives: 2010 2SS/RS 6A RJT/BLK
Hay Clutch, thanks for the post, very good job. I have been looking at the Blend mount and wondering if the RD positioned below the mirror creates and even bigger blind spot there. After having it installed for some time now are you finding the RD blocking your vision, or have you learned to look around it?
enigma is offline   Reply With Quote
Old 04-17-2010, 12:29 PM   #14
obe1
obe1's Avatar
http://www.blendmount.com/
Old 04-17-2010, 12:30 PM   #15
obe1
obe1's Avatar
It does create a slightly bigger blind spot but hasn't been an issue.
Old 04-21-2010, 06:55 AM   #16
monstertodd
Allyourbasearebelongtous
monstertodd's Avatar
Wow, this is an awesome mod! This is my next one for sure!
*update: All parts ordered. Can't wait to do this one!
Old 04-22-2010, 11:28 AM   #17
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
This is a beautiful write-up. Thanks so much!
CamaroFTW is offline   Reply With Quote
Old 04-29-2010, 06:00 PM   #18
highmark
Burnin out!
highmark's Avatar
Drives: Sick SS
IMO the valentine 1 is the best detector I ever owned. That installation is clean. I mounted mine on the driver visor and ran it down the inside pillar to the fuse box.You can barely see any wire. I guess it was the cheapest and fast way. If it wasn't allready in I would do it your way. Nice job!
highmark is offline   Reply With Quote
Old 04-29-2010, 07:27 PM   #19
LittleRockCGM
LittleRockCGM's Avatar
Drives: 2010 Camaro CGM/IOM 2SS/RS
Used your write-up this weekend and installed my V1 - thanks! Really nice placement and function.
2SS/RS CGM/IOM stripes/IOM interior Manual
1100 11/3/09 - Order Submitted (NQTRTW)
2500 11/4/09 - Order Preferenced
3300 11/11/09 - Order Scheduled for Production (TPW 11/23/09)
3400 11/17/09 - Order Broadcast
3800 11/23/09 - Build Complete (VIN: 2G1FT1EWXA9170886)
4000 11/26/09 - Ready to Ship
4200 11/30/09 - Shipped (ETTX854262)
5000 12/11/09 - Delivered to Dealer
6000 12/12/09 - Delivered to Customer (It's Mine!)
LittleRockCGM is offline   Reply With Quote
Old 05-03-2010, 03:43 PM   #20
Ukd73
Drives: 2010 1ss/rs Ls3
black to black pink to red?
Ukd73 is offline   Reply With Quote
Old 05-03-2010, 07:10 PM   #21
SiNFuLL
SS Chick
SiNFuLL's Avatar
Send a message via AIM to SiNFuLL
Thanks for a great write-up! Installed my V1 Saturday and it looks great!
~*~ Manda ~*~
'10 Camaro SS/RS
SiNFuLL is offline   Reply With Quote
Old 05-18-2010, 02:04 PM   #22
Tati
I ♥ my Camaro
Tati's Avatar
Drives: Black 2LT, RS w/ Sunroof. SRY0FZR
Send a message via Yahoo to Tati
Oh wow, Nice!
I wish it wasn't illegal to have radar detectors here in Virginia , I could so use one of those!!..
You are what you drive!
Tati is offline   Reply With Quote
Old 05-18-2010, 02:15 PM   #23
Kwik
Drives: car
That's a great looking installation. Do you need to disconnect battery? BTW, the Valentine is absolutely the best detector available. I had one in my 2004 SVT Cobra. Saved my bacon many times. LOL!!
Upgrades to suspension, brakes, motor and appearance. 482.7 RWHP- 434.2 RWT - All motor.
Kwik is offline   Reply With Quote
Old 05-18-2010, 02:35 PM   #24
obe1
obe1's Avatar
No need to disconnect the battery.
Old 05-18-2010, 02:37 PM   #25
obe1
obe1's Avatar
Clutch's instruction are pretty clear:
Black wire into black and white striped wire slot.
CAMARO WIKI Tran Wiki 42 05-18-2013 09:32 AM
Rear View Camera VenomZ302 5th Gen Camaro SS LS LT General Discussions 65 05-29-2011 01:55 PM
Rear View Mirror Rattling After Sub Install Camar0wn3d Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 9 05-15-2011 05:50 PM
DIY rear floor mats buddylok Camaro DIY & HOW-TO instructions & discussions 12 09-03-2009 08:55 PM
New Member concerned about rear seat view speedtrip 5th Gen Camaro SS LS LT General Discussions 4 03-20-2009 10:39 AM
