SDTW Custom Wheels & Tires
Old 11-22-2009, 06:27 PM   #1
the rich dude
Drives: Getting 2010 Camaro
LS3 Block stout enough for 427 build?
Just thinking a little ahead into the future and may start collecting parts to build a 427 in motor. It will use the procharger I already have, plus I'll probably get some CNCed heads.
Is the LS3 block stout enough for a 427 build up. Probably looking to make 650-700RWHP on pump gas for a street car.
Do sleeves need to be installed or are stock liners good enough?
Thanks....
the rich dude is offline   Reply With Quote
Old 11-22-2009, 08:21 PM   #2
Slowhawk
Drives: 1999 Trans Am
We do the LS3 block to 418ci for forced induction.427ci should have the block resleeved.
Slowhawk is offline   Reply With Quote
Old 11-22-2009, 09:23 PM   #3
the rich dude
I could live with 418 if I could get away without resleeving the block. Thanks.
Old 11-22-2009, 10:46 PM   #4
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
FWIW, Texas Speed recommends the 418 over the 427 if you're planning more than 10 psi boost or more than a 150 shot of nitrous. The 418 is a shorter stroke which allows the use of a more substantial piston for higher boost applications...
Kilo-9 is offline   Reply With Quote
Old 11-22-2009, 11:41 PM   #5
the rich dude
exactly what I wanted to hear!! Thanks!!
Old 11-23-2009, 06:44 PM   #6
Jason 98 TA
Drives: Camaro
We stock the 418 boost setups. Honestly the 427 using a LS3 block is a bad idea for boost. Give us a call & we can discuss options! We have 427s for boost, but it wont use the 6.2l ls3 block. I've personally made over 1000rwhp with a 4" stroke setup like the 418! We can help you build a nice short-block that will make the power your looking to make.
Typically we keep around 40 short-blocks in stock at any one time. If we don't have exactly what your looking for we can build it in under 3 weeks!!
Jason 98 TA is offline   Reply With Quote
Old 11-23-2009, 06:58 PM   #7
freemaSSon
Pat @ ADM PERFORMANCE
freemaSSon's Avatar
Drives: CGM SS/RS M6
The 4.100" strokes are a not a good geometry for the short sleeved blocks. Resleeving corrects this but that is alot of expense for marginal if any improvement. The 4" stroker kits are more than enough.
I have personal experience with the 4.100" strokes and I am not a fan at all. I personally had a LS7 bored at 4.135" with the a Callies 4.100" and it was not as well of a performer had it been built with the 4" stroke. My block was not resleeved and it tended to consume oil. I had a friend with a 6.2L block with the 4.100" stroke the LS3 427 ci. It was also not resleeved and it consumed even more oil than mine. I caution eveyone that asks about the 4.100" strokes. My personal exerience is that the LS series engines do not respond very well to over stroking either. A square build is as far as I would recommend any LS engine be. The 4.125" bore and 4" stroke has proven to be very difficult to improve upon. Many wild combinations of engine builds out there and none clearly stand superior to the LS7 stroke and bore no matter the block selected.
"old age and treachery will always overcome youth and ambition"
author unknown
"There are two types of racers: cheaters...and losers."
Smokey Yunick
freemaSSon is offline   Reply With Quote
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
ZZ Motorsports / Vector Motorsports - LS3 Build ZZcamaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 06-22-2009 01:38 PM
Who wants to build their own LS3 09 camaro? CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 12-11-2007 08:05 PM
LS3 Specs, and Descriptions Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2007 02:04 PM
