Old 11-22-2009, 07:57 PM   #1
KJS
KJS's Avatar
Drives: '10 RJT,'95&'14 Vette
Exclamation Winter Tires - Reminder about TPMS
When you switch your tires, such as putting on your winter/snow tires, remember you need to re-program your Tire Pressure Monitor.
If you don't, after several miles your DIC will flash a warning Tire Pressure Malfunction. The instructions for doing it are pretty straight forward (see pages 9-59 thru 9-61) in the owners manual.
(Also - remember when installing your winter tires or putting the regular tires back on in the spring, make sure they are put on the correct side. Most high performance tires can only go in one direction. Look for the "Rotation" arrow. It's a real pain in the ... when you've put the tires on to find out you've got to re-do it because they are on the wrong side!)
"As ye sow, so shall ye reap" - Me
Mine at sunset
KJS is offline   Reply With Quote
Old 11-22-2009, 08:05 PM   #2
MI2010Camaro
MI2010Camaro's Avatar
Drives: 2010 Camaro 1SS
Excellent advice being given here. I speak from experience. After swaping my summer tires/wheels for the Tire Rack winter replacements I immediately checked the DIC and saw that I had pressure readings in all four tires. What I didn't realize is that was old data stored from the summer tire readings. After about a 20 minute drive the message appeared in the DIC that all my tire pressures were zero! A quick read of the owners manual (as you have noted by page numbers) got me back on track. This same process will need to be repeated next spring when the summer tires go back on.
1SS/M6/CGM/Sunroof
#143575 Delivered 9/14/09
MI2010Camaro is offline   Reply With Quote
Old 11-22-2009, 08:33 PM   #3
mjlash22
mjlash22's Avatar
Drives: 2007 Ford Fusion SE
What about calibrating the system for the new tires if they are different sizes?
Ordered: 2LT/RS CGM, A6
1100 = Preliminary Order 10/1/09
2000 = Accepted By GM 12/31/09
3000 = Accepted By Production Control 1/7/10 (TPW: 2/1/10)
3400 = Broadcast 1/23/10
3800 = Produced 2/2/10 (2G1FC1EV6A9189068)
4150 = Invoiced 2/5/10
4200 = Shipped
5000 = Delivered To Dealer
6000 = Delivered To Customer
mjlash22 is offline   Reply With Quote
Old 11-22-2009, 08:39 PM   #4
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
I re-calibrated mine this weekend after onstar gave me a report that my tire pressure was low. Belle tire just mounted the Pirelli scorpions but I'm not sure if they reset the TPMS.
Anhow, I noticed that when you re-calibrate the tires, that the turn signal of the tire it wants to get a signal from will be illuminated. That part wasn't in the manual, and that helped.
Today, the tires are reading closer to what they should be instead of low.
skuttduck is offline   Reply With Quote
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 11:51 AM
Winter Tires Put On (Pics Included) YYZ Canada 38 12-11-2009 05:51 PM
Got my winter tires put on EarliestMemory USA - Great Lakes 19 10-14-2009 02:56 PM
Winter Tires Cyber_Gray_Autobot Canada 12 08-21-2009 01:35 AM
Swapping summer for winter tires ttazzijr700 Wheels and Tires Talk Sponsored by The Tire Rack 4 10-19-2008 08:53 PM
