HeadlightArmor
Old 12-27-2009, 08:59 PM   #43
Akagitsune
Akagitsune's Avatar
Drives: None currently...
To avoid metallic particles in oil:
Originally Posted by amphi View Post
I thought the LS3 is casted from aluminum. What parts are made of Iron that would be picked up by the magnets if found in the oil?
Fist off, GREAT article! Easy to follow explanation and some great tips.
Secondly, this article reminded me of this link:
http://www.camaro5.com/forums/showthread.php?t=38438
According to that article, there are lots of various metallic particles that will appear in the engine as a result of breaking it in. That drain plug is a monster!! I'll have to get one of those someday. The filtermag seems promising too, but I'm slightly more on the fence about that one: Isn't that what the screens in the filter are for anyways?
Akagitsune is offline   Reply With Quote
Old 12-27-2009, 09:02 PM   #44
Ames
Drives: 08 Vette, 09 Z06
I'm looking forward to the filtermag review.
Ames is offline   Reply With Quote
Old 12-28-2009, 09:51 AM   #45
gregus73
gregus73's Avatar
Drives: 2010 Blue Challenger R/T
Nice write up. Will be sure to save this.
thanks
gregus73 is offline   Reply With Quote
Old 12-28-2009, 11:34 AM   #46
FirstLSK
Dude, I love my car !!!!
FirstLSK's Avatar
Drives: 2010 Black 2SS/RS white rally
Originally Posted by Bumblebee10 View Post
I just buy the supplies I need from wal-mart with my 10% discount and then bring the car anywhere that changes oil and they do it for like $10-$15 when I give them the supplies. Total mobile 1 synthetic change costs me around $38-$46
Just FYI for all of those that pay a place to change your oil -- you are not getting a complete oil change.
I used to work at "quick lube" place. The rule of thumb was when the oil went from a solid stream, to a partial stream, put the plug back in and start filling with oil 1 quart lower than the manuf. spec. It takes longer than a few minutes for all of the oil to drain out.
Just one other FYI -- look at the oil pan when the car is on the ramps. I bet there is 1/2 quart of oil sitting in the pan behind the plug. I use 4 jack stands to keep it level.
FirstLSK is offline   Reply With Quote
Old 12-28-2009, 02:16 PM   #47
aldaran
aldaran's Avatar
Drives: 2016 Camaro 2SS/RS
Exactly. It could have been a fast change as mentioned above leaving a substantial amount in there. I do all my own oil changes. Going to try the hole punch in my Silverado oil filter, because that one gets pretty messy. My 2000 Camaro V6 is the easiest one to do since its horizontal.
aldaran is offline   Reply With Quote
Old 12-28-2009, 02:30 PM   #48
camarolt76
2SS/RS Black/CGM Stripes
camarolt76's Avatar
Drives: 88 Iroc, 76 Camaro, 2010 2SS/RS
This is a nice writeup on changing the oil. Thanks for sharing.
2SS/RS Black with CGM Rally Stripes (#8575) Built on 8th of May, Delivered 10 June 2009.
camarolt76 is offline   Reply With Quote
Old 12-28-2009, 04:05 PM   #49
Cyber_Gray_Autobot
Drives: Camaro 2LT RS
Has anyone did this for the v6 with a write-up? I know the filter is somewhere on top rather than on the bottom. Any other differences???
Cyber_Gray_Autobot is offline   Reply With Quote
Old 12-28-2009, 05:11 PM   #50
Tran
Administrator
Tran's Avatar
Originally Posted by adub4185 View Post
made the front page! YES!!
all the suggestions that have been made are in the write up at some point, but thanks for the suggestions guys.
at my next change, ill be doing the transmission and rear diff fluids, so ill do another DIY for those along with a follow up on my filtermag and magnetic plug findings.
PM me when you've put up these DIYs and we'll see about putting it on the front page. Thanks for sharing
Old 12-28-2009, 07:30 PM   #51
Kept-a-rollin
Kept-a-rollin's Avatar
Drives: 2010 Camaro 2LT RS ABM/Grey/A6/Sunr
Originally Posted by strobi View Post
I know the filter mag won't work for the V6 (oil filter located in engine compartment), but will the gold tip drain plug still work for the V6? Thanks Strobi
I don't understand the comment about the filter mag not working on the V6. The filter mag product appears to just slap onto the outside of your filter canister. Anyone know why it wouldn't work?
Order No. NQRF51 2LT RS ABM/ Gray Int/ A6/ Sunroof
1100 - preliminary order accepted 10-30-09 Best Chevrolet, Hingham, MA
XXXX- abandoned order; bought same car at Durand Chevrolet 11-10-09 Woohoo!!! 2G1FC1EVXA9159071
2500 - order preferenced 11-11-09
3000 - order accepted by production control 11-18-09 TPW 12-14-09
3300 - order scheduled for production 12-9-09
3400 - order broadcast 12-15-09
3800 - order produced 12-18-09 My orig order actually did get built! 2G1FC1EVXA9179031
Kept-a-rollin is offline   Reply With Quote
Old 12-28-2009, 08:40 PM   #52
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
there are particles that occur during break in as the rings seat them selves and scrape the inside of the cylinder walls. the one thing to keep in mind however, is that aluminum isnt magnetic. so just because you dont see anything stuck to the drain plug doesnt mean you dont have some shavings somewhere.
I dont recall if the filter canister on the v6 is metal or composite/plastic. if it is plastic, then the filter mag wont stick to it as its not magnetic.
I piss excellence
and fart awesomeness
Old 12-28-2009, 11:06 PM   #53
WhiteCrane
WhiteCrane's Avatar
Drives: 2010 Mustang GT
Send a message via AIM to WhiteCrane Send a message via Skype™ to WhiteCrane
How often does the camaro need an oil change?
Most new cars are not 3 months / 3,000 miles anymore.
EDIT:
Answered my own question. Owner Manula page: 9-13
Engine Oil Life System
"This is based
on engine revolutions and engine
temperature, and not on mileage."
WhiteCrane is offline   Reply With Quote
Old 12-28-2009, 11:24 PM   #54
CamaroSpike23
Truth Enforcer
most have been changing the oil the first time around 1500 miles then whenever the car tells you to.
I piss excellence
Old 12-29-2009, 01:53 PM   #55
WhiteCrane
WhiteCrane's Avatar
The manual says with conservative driving the oil may last a year! I'm so happy. Oil changes are a total inconvenience to me.
They were fun when I was 17.
Old 12-29-2009, 02:56 PM   #56
adub4185
Drives: 2010 Black 2SS RS, 1995 BMW M3
Send a message via AIM to adub4185
EDIT:
"This is based
my plan is to change again at 3000 miles (first one was done around 1400 miles) along with the rear diff and tranny. then after that i will change the oil every 3000 miles regardless of what the car's oil life monitor says. change it frequently and use quality parts, your car will love you for it.
adub4185 is offline   Reply With Quote
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Cosmetics and Lighting Modification Discussions 36 06-25-2017 10:57 AM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
