Old 12-30-2009, 11:50 AM   #57
robertway
robertway's Avatar
Drives: 2012 Challenger SRT8 Auto
Thanks for the write-up, just goes to show even the simplest things can use a good write-up and everyone can pick something up from it. I wasn't even aware of the FilterMag and Magnetic plug until this posting, thanks again...
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin
LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!!
robertway is offline   Reply With Quote
Old 12-30-2009, 05:14 PM   #58
The Black Stig
Drives: almost
there are particles that occur during break in as the rings seat them selves and scrape the inside of the cylinder walls. the one thing to keep in mind however, is that aluminum isnt magnetic. so just because you dont see anything stuck to the drain plug doesnt mean you dont have some shavings somewhere.
I dont recall if the filter canister on the v6 is metal or composite/plastic. if it is plastic, then the filter mag wont stick to it as its not magnetic.
But the most important part is, the factory selves/cylinder liners are iron.., if you do in fact see stuff stuck to the magnetic I would be very woried...
¿ʞuıɥʇ noʎ ʇ,uop 'ǝɹɹɐzıq
The Black Stig is offline   Reply With Quote
Old 01-02-2010, 04:37 PM   #59
htgeneral
Drives: 2LT
2LT oil change notes
Hey, thanks for the posting. It helped me get started on changing my oil. A few notes for V6 oil changes. (I have a 2LT RS)
M1-113 filters are only for V8s. The V6 uses full-flow oil cartridges. I bought both at the store. Looked all over the bottom of the engine before looking again under the hood. Its actually really easy to replace the cartridge. It is right next to where you fill the oil on the right side of the engine. Use a 15/16" socket with a 4" extension and your all set. The V6 also only takes 6 qts of oil. I had to use ramps the first time but next time I may try to just park on a curb since the V6 only needs access underneath to drain the oil. BTW use a 15MM wrench for the oil plug.
Now for the blunder.... I got excited the night before and bought Qty 3 Mobil 1 M1-113 filters on a web special with no shipping and for $9 each. (Normally 12.99) That was a good deal I thought...except I have a V6 that cannot use these. If anyone wants to buy these let me know. I will sell all 3 for $27 and include shipping. Just don't want to be stuck with them.
htgeneral is offline   Reply With Quote
Old 01-02-2010, 06:58 PM   #60
bub
bub's Avatar
Drives: '17 1SS 1LE & '15 Corvette Z06
2017 Camaro 1SS 1LE Black with PDR
SOLD 2015 Camaro 2SS RS 1LE Red Hot
SOLD 2013 Camaro:
2LT RS Auto
Color & Trim:
Blue Ray Metallic w/ Black Interior
SOLD 2010 Camaro:
1LT RS Manual (RPO R6P Early Order)
Color & Trim:
Black w/ Black Interior
Options:
RPO WRS RS Package
RPO UQA Boston Acoustic Premium Sound
Order # NDVK94
Built 6/10/09
Delivered 7/18/09
(Previous Early R6P from Bozarth in Topeka)
bub is offline   Reply With Quote
Old 01-02-2010, 11:35 PM   #61
Kept-a-rollin
Kept-a-rollin's Avatar
Drives: 2010 Camaro 2LT RS ABM/Grey/A6/Sunr
Thanks for the pics of the V6 oil change. Now I can see why the filter mag is not a product for the V6, due to the use of a drop-in cartridge rather than a metal canister-style filter.
Kept-a-rollin is offline   Reply With Quote
Old 01-02-2010, 11:52 PM   #62
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
Hey guys,
I'm a newb at changing my own oil and have a question. My car has GFX on it, can it still be jacked up and put on stands easily? I ask because at this tire place I was at last month some guy's civic's side skirts cracked when the car was jacked. Maybe it was bad practice, but I just want to be sure. I plan on doing this next weekend. Thanks for the write up too, I appreciate this!
Vince
Old 01-03-2010, 01:58 AM   #63
scythezo6
scythezo6's Avatar
Ok so some more nub questions (bear with me, I'm learning)!
I bought a (1) 4k lb trolly jack and (2) 3k lb jack stands, will these be enough to hold up the car for this? I'd use ramps, but I wanted the jacks for other stuff later on (painting calipers, cleaning wheel well and rims etc.).
I can find a lift point on the car for the jack, but where do I apply the jack stands?
Thanks in advance.
Vince
Old 01-04-2010, 03:43 PM   #64
scythezo6
scythezo6's Avatar
Originally Posted by scythezo6 View Post
Hey guys,
Vince
Thanks in advance.
Vince
Nothing? );
Old 01-04-2010, 04:35 PM   #65
bballr4567
Drives: 2016 Camaro 1LT M6
You will possibly have to build some 2X4 ramps. Just to get it high enough to get the jack under the GFX.
You can put the jack stands on the K Member and that should be good.
bballr4567 is offline   Reply With Quote
Old 01-04-2010, 06:57 PM   #66
scythezo6
scythezo6's Avatar
Thanks bballr,
BTW, whats the k member look like?
Old 01-04-2010, 07:29 PM   #67
bballr4567
Its what supports the engine. Shouldnt be too hard to spot honestly.
Old 01-05-2010, 09:24 AM   #68
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
Thanks bballr,
First see if you can get your floor jack on the front of the car. If you can then find the crossmember (K member) and put the jack point there.
Find a secure spot by each front wheel to put the jack stand.
Personally I use the 8,000 lb rhino ramps I bought at Autozone. I think with your GFX it will not clear so you would need to put the ramps on a piece of plywood so that the wheels touch the plywood before it gets to the ramp.
Good luck.
tradosaurus is offline   Reply With Quote
Old 01-05-2010, 11:10 AM   #69
scythezo6
scythezo6's Avatar
Cool. Thanks for the help guys.
Old 01-19-2010, 12:53 PM   #70
scythezo6
scythezo6's Avatar
I have a couple of nub questions again. Bear with me.
To drain the oil I would pop out the bolt in the picture below with the circle around it? And the oil filter would be the blue guy in the picture below with the circle around it? Is the blue thing a cover?
As for jackpoints, can I jack up the car using the points with arrows in the pic below? Or would these spot be better for jack stands?
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Cosmetics and Lighting Modification Discussions 36 06-25-2017 10:57 AM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
