HURST
Old 11-23-2009, 03:52 PM   #1
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Drives: 2SS/RS Oct 2009
DIY - Footwell LED lighting In tune with Dome Light
I have successfully hooked up footwell lighting to the Interior dome light so that it goes on/off with door open/close and manually turning on.
I have a bunch a photo's to post up here - but - and I apologize in advance... i want to separate each picture with text to explain what's going on -- and I can't figure out how to do that?? Is there a 'Dummies' guide anywhere???
This is the finished product --- looks pretty cool me thinks, But I would like to share......
Parts list all from Advanced Automotive Concepts
1 x Dome light LED http://automotivelightstore.com/2009...ersionkit.aspx - Blue $31
1x LED Light tubes (PAIR) http://automotivelightstore.com/orac...htingpair.aspx - 15" Blue $40
Heat shrink
Electrical tape
18 gauge or better wire (to extend to inverter cables)
Tie wraps
Cheers
markmass is offline   Reply With Quote
Old 11-23-2009, 03:58 PM   #2
Edrock
Edrock's Avatar
Drives: '10 Camaro 2SS LS3
Cheers
Wow. Too cool. How difficult was the installation?
DT Shorties, Solo hi-flow Cats, X-pipe, resonator delete, Flowmaster Super-44s, VMAX TB, Stronger MAF, C.A.I. Intake with race scoop, and JRE Tune!
WOT is my happy place!!
Edrock is offline   Reply With Quote
Old 11-23-2009, 04:08 PM   #3
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Probably near 2 hours with finding the right wire to tap into and threading the wires to the passenger side - but overall pretty straightforward, You do have to hook a wire to the dome light and run that across and down the post. I changed the existing 5w dome bulb to LED also, that way Im pretty sure I don't need a relay (will lose the dimming if I used a relay)
I used the 15" LED tubes from Advanced Automotive Concepts - just looked and cant see them now - weird..Anyway, I will post the instructions when i figure out how to separate the piccies
Old 11-23-2009, 04:13 PM   #4
Edrock
Edrock's Avatar
Cool. Might have to look into this if it does not entail dismantling the dash and it's not too expensive. What would one expect to drop ($) on a setup like this?
Old 11-23-2009, 04:14 PM   #5
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Very cool!
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 11-23-2009, 04:15 PM   #6
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
LED lights - Dome - $30 (5 LED, 3 Chip) 2x15" tubes $35, bits and pieces..wire, heat shrink, tie wraps - $5 So all told around $70....Gotta luv DIY
Old 11-23-2009, 04:22 PM   #7
Edrock
Edrock's Avatar
To post pics with text in between, I think you just type your text, click the paperclip button at the top of the editor which will open the file upload window, then on that screen browse to photo, click upload. When you are ready to insert it above or below text, just click in the body of your message where you want the pic to go (cursor will then blink there), then click the down arrow beside the paperclip button in the editor and select the pic file you want to attach. Then you should see an "[ATTACH] picture file [/ATTACH]" entry show up in your post where the pic is going to be. Just repeat these steps to create multiple. I bet you probably could upload all your pics in one step then select as you go from the drop down menu on the paperclip button but have not tried this. Something like that. Hope this helps.
Old 11-23-2009, 04:28 PM   #8
Michael_Js
Michael_Js's Avatar
Make sure you hit GO ADVANCED first. Then, he's got it - type text, attach a photo. Type more text, attach another photo. Preview post and go!
Thanks!
Old 11-23-2009, 05:08 PM   #9
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Thanks Edrock....
I used the 15" Blue LED from Advanced Automotive Concepts - I had 2 inverters
I also took the opportunity to wire in the Escort Radar detector - alas its on permanent power from a spare in the fuse box, can't find any that operates on the ignition... anyway
First remove the Door Pillar post cover - I found removing the seal gives you easy access. Once removed you can grab the door pillar cover and it actually comes away pretty easily
Name:  remove door seal and cover.JPG
Next is to remove the dome light assy. There are other threads on this, but gently - take a flat head screwdriver and remove the lens cover and the silver reflector. they basically just need easing out all round. The main 'white' piece is a little tricky. Two spring clips hold it in place and they toward the front of the car
Name:  removing dome light assy.JPG
I used a long nail to push clip up while using a screwdriver behind to leverage it out, bit awkward to explain but I think you'll see what I mean - Don't let go---it will spring back - It does come down easily when they are released.
Next take out the wire harness, it has a clip so depress that first.
The dome light wire is the one on the left -
Name:  The dome light wire.JPG
Don't ask what color - im color blind....but it is the one with a space between it.
You should be able to see at the front of the headliner a small hole. I fed a wire through this from the windshield side -- i.e toward you
Name:  feedwire thor headliner.JPG
you can just about see the cutout in the picture. Once fed through the headliner, go ahead and run behind the headliner over to the post - you will feel a small gap between the headliner and wind shield. Once over to the post run it down to the fuse box. At this point I spliced it to the dome light - but you may want to do this last - just in case of a short
Name:  SPlicing into the dome light wire.jPG
Now secure the inverters:
Drivers side is perfect fit in the fuse box:
Name:  perfect place for drivers side LED.JPG
Next - the passenger side - you will need to extend the power wires to these - bit of solder and heat shrink...Placement of the inverter is not too bad either
Name:  placing passenger side inverter.JPG
Next secure the LED strips. Passenger side - drill 3 holes - its ok, they don't go through to he inside, use tie wraps to lightly secure the LED - plug in to the inverter
Name:  3 holes in passenger side glove box.JPG
Drivers side has existing holes that you can use to secure the LED tube:
Name:  Securing LED strip under drivers side.JPG
Next step is to secure the ground wire - There is a convenient black colored bolt just above the bank of fuses that i used a ring terminal for both inverters, - you can see this in the pictures below
Connect both +ve wires from the inverters to the wire you ran from the dome lights previously - i soldered and insulated them
At a later date i may add switch so i can have them on without the Dome light - pretty easy mod to do....
I think that sums it up - probably 90 minutes work.
JOB DONE
And I have no idea where these next pictures came from --- so please ignore!!
Old 11-23-2009, 05:19 PM   #10
Michael_Js
Michael_Js's Avatar
Great! Which wire is the dome light in the fuse box? I'm not asking for color, but is it labeled?
Also, what kind of inverters did you have - meaning what should we buy?
Thanks!
EDIT: Never mind on the inverter. It indicates it comes with the inverter: http://automotivelightstore.com/orac...htingpair.aspx
Old 11-23-2009, 05:21 PM   #11
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Thanks!
There isn't one --- you have to run one from the Dome light itself, across the headliner and down the post...Need to splice it to the wire in the headliner
Inverters came with the LED tubes as kit -- "Oracle CCFL Ambient lighting" pair 15" AAC Lighting
Old 11-23-2009, 05:53 PM   #12
Michael_Js
Michael_Js's Avatar
Ok, so is the wire from the dome light the one that is going INTO the inverter?
Thanks,
Michael J.
Old 11-23-2009, 05:59 PM   #13
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Thanks,
Michael J.
Yup - You need to connect the wire you just ran to the +VE wires on the both inverters. I'm sure one day someone will find the wire....but no-one has yet... so we're stuck with having to run the wire and splice into the existing Dome light wire, and run/hide the new wire.
Old 11-23-2009, 06:11 PM   #14
Michael_Js
Michael_Js's Avatar
Thanks!
I hope the blue will look good with my IOM interior since they don't have an orange option. Wonder if the red is close?
Red led halo light Cpiend4765 Cosmetics and Lighting Modification Discussions 81 04-17-2013 03:44 AM
ORACLE 5202 LED 18SMD Cool White Fog Light Bulbs for Camaro!> 20% OFF! AACstyle Exterior Parts & Accessories 137 04-01-2011 03:49 PM
Footwell Lighting Question BUMBLEBEE_SS 5th Gen Camaro SS LS LT General Discussions 19 02-09-2010 10:21 PM
LED Interior and Exterior Lighting. SummoneR Cosmetics and Lighting Modification Discussions 101 08-17-2009 10:01 PM
ambient lighting suppsedly a go MIDNIGHTANGEL 5th Gen Camaro SS LS LT General Discussions 43 02-15-2009 08:51 PM
