JUICEDMOTORSPORTS
Old 11-24-2009, 04:33 AM   #1
BabyHauler
Drives: CGM 2SS/RS 6M
HVAC problem?
My AC or heater continues to come out of my vents even when the blower is set to off. I mean it comes out pretty good too, when I have the temperature blender to heat and the vent controller to the upper vents my hands get hot on the steering wheel. Has anyone else experianced this?
Z06+Baby= 2010 2SS/RS 6M
BabyHauler is offline   Reply With Quote
Old 11-24-2009, 10:30 AM   #2
TooCool5
Resident Gearhead
TooCool5's Avatar
I experienced this in the Hot summer months after the car has been parked.
It should go away after you drive it a little and the vents cool off.
Old 11-24-2009, 07:51 PM   #3
Lineman
Drives: 04 Tahoe and 2010 2SS M6
Well, I’ll tell ya – every Tahoe I’ve owned has had hot forced air blowing out the vents when the outside air temp was above about 70 degrees with the temp set at cold. So even with the outside temp at 75, say, I have had to use A/C. Now I notice the same thing with the Camaro but the temp is lower – say 60 degrees. Above about 60 degrees I have to use A/C or roll the windows down – which I do a lot. I think that the cold forced air – that is air pushed in by the movement of the car – and not conditioned by the A/C is routed through ducts that are in or near the engine compartment, and the ducts get hot. If this is true, then I guess that it means that we shouldn’t worry about it – it’s normal.
Lineman is offline   Reply With Quote
HUGE problem with warped rear bumper fascia!!! camero Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 33 04-05-2012 12:20 PM
GM bulletin: HVAC system reprogram / rear spoiler repair / engine harness inspection Bonemaro Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 65 06-13-2010 06:41 AM
GM Bulletin HVAC system reprogram caused window problem VegasSS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 10-09-2009 10:05 AM
first problem with Camaro RobH Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 10-05-2009 10:17 PM
GM Bulletin HVAC system reprogram caused window problem VegasSS 5th Gen Camaro SS LS LT General Discussions 16 10-02-2009 03:10 PM
