ADM PERFORMANCE
Old 11-24-2009, 11:43 AM   #1
Rod10269
Hot Rod
Rod10269's Avatar
Drives: 69 Z28,69 SS 396,67 Chevelle
Shift light pattern 1st to 4th
I have the 2ss rs 6 speed manual and for the last couple of times driving the car this shift pattern will come up in the display showing me to shift from 1st to 4th...read in the manual and it stated to not try and force it into 2nd that thiss would cause trans damage and after you shift to 4th you can then downshift..something about fuel mileage? Just trying to understand what is going on with this and if anybody else has experienced this and how are the handling it.
Rod10269 is offline   Reply With Quote
Old 11-24-2009, 11:48 AM   #2
103FrazzL
103FrazzL's Avatar
Drives: 2010 Camaro 2SS RS M6
It is the skip shift it and yes it is supposed to help with gas mileage. Slp does sell a skip shift eliminator it's like 30$ and easy to install. If you give it more throttle out of 1st it will not make you do it, that's the cheap fix.
2010 Camaro 2 SS RS CGM
ADM Street Cold air intake, SLP Loud Mouth II, ARH 1 7/8 Long Tube Headers w/high flow cats, Hurst Short Throw shifter, Skip shift eliminator, LED licence plate Lights
103FrazzL is offline   Reply With Quote
Old 11-24-2009, 11:59 AM   #3
Steve@Vectormotorsports
Drives: Firehawk
We can tune out the skip shift for you
Steve@Vectormotorsports is offline   Reply With Quote
Old 11-24-2009, 12:27 PM   #4
ZED SLED
ZED SLED's Avatar
Drives: 2017 MOS_BLK ZL1 M6, 2015 Terrain
The only time mine ever comes on is when some granola eater in a Subaru is at a stop sign/light in front of me, trying to get that extra teaspoon out of a gallon of gas so as not to hurt the feelings of the earth. A quick downshift and a rear tire-melting pass quickly negates their efforts. Other than that, I tend to drive it like I stole it so it doesn't have a chance to activate.
Old 11-24-2009, 06:52 PM   #5
HaveBlue
HaveBlue's Avatar
Drives: CTS/CAMARO
The DiabloSport and the Superchips Flashpaq will turn it off for you.
"everyone wants to go to heaven. but nobody wants to die" "you gotta pay to play"
SEMA PICTURES-PARTS & CARS
http://www.pbase.com/haveblue/sema_2009
HaveBlue is offline   Reply With Quote
Old 11-24-2009, 10:20 PM   #6
SPANKT U
Drives: 2010 2SSRS Inferno Orange LS3
I wished I could get my Superchips Flashpaq to work. It has been 2 weeks since the programmer said they would put my car's VIN in their database and it is still just a paperweight....
2010 2SSRS Inferno Orange Metallic
It's stock, I swear!
SPANKT U is offline   Reply With Quote
Old 11-24-2009, 10:27 PM   #7
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
I have only had it happen a few times, just go to 4th then right back to 3rd for smoother acceleration.
Old 11-25-2009, 05:52 AM   #8
BUMBLE-B-TUNA
BUMBLE-B-TUNA's Avatar
Drives: 2010 SS
I have read on another thread that this skip shift eliminator does the trick, its just an inline plug http://www.bmcspeedshop.com/product_p/21008.htm Haven't tried it yet but plan on installing it.
BUMBLE-B-TUNA is offline   Reply With Quote
Old 11-25-2009, 10:51 AM   #9
amphi
Drives: 2SS Imperial Blue
I can't seem to wrap my head around the skip shift. Why does it make you bog down the engine when shifting so early. Doesn't this waste more fuel? Can anyone explain?
amphi is offline   Reply With Quote
Old 11-25-2009, 02:17 PM   #10
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
no it doesn't, otherwise it wouldn't be used. It boosts the city mileage rating of the car and has been around for 20 years. It was created so that the Corvette didn't have to pay a gas guzzler tax yet doesn't impede on performance. If you don't want to do anything which might void the warranty, accelerate a little harder and it won't come into effect
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 11-26-2009, 04:58 AM   #11
jdebrock
jdebrock's Avatar
Drives: 2009 Dodge Challenger R/T
I have the skip shift in my Challenger. I absolutely hate the thing! It always seems to come on at the worst time ie: turning in an intersection. What a wonderful feeling to be entering an intersection, only to find out that you're locked out of 2nd or 3rd. I just bought the plug in eliminator, but until I install it I have been starting off in 2nd gear.
jdebrock is offline   Reply With Quote
Old 11-27-2009, 12:13 PM   #12
2SSjack
2SSjack's Avatar
Drives: 2010 2SS Camaro;
Just installed a Skip Shift Eliminator. I got it on EBAY from a company called Speed Inc. out of Schaumburg, Illinois. $18.95 + shipping! Went in with no trouble! It is a little easier if you loosen the 4 bolts that hold the trans crossmember to the body; about 1/2-3/4" will do. Do not take them all the way out. DON'T forget to tighten them when you are done.
2SSjack is offline   Reply With Quote
Old 01-14-2010, 03:27 PM   #13
gltrakas
gltrakas's Avatar
Drives: Imperial Blue Met 1SS 6-sp Manual
i have to say, i hate this. let me worry about my gas mileage. for one thing, i didn't buy an 8 cyl. to worry about gas....i got it to burn some up! when it did come on, it seemed like 4th was to high of a gear, like it wanted to bog down on me. this was during my break-in whgen i was a little easier with it though.
gltrakas is offline   Reply With Quote
Old 02-07-2011, 12:11 AM   #14
Milidin
Drives: Black 2011 Camaro 2SS Coupe
Low RPM?
Just bought my Camaro SS and learning to drive it with this skip shift system as well. When the suggestion to shift from 1st to 4th comes up I'm only at about 2k rpm and when I shift to 4th it drops all the way down to about 800 and bogs down the engine. Feels like it's bad for it and I noticed a burning smell as well. I'm used to driving a 2.0 liter WRX that I just traded up from and I would never have dreamed of driving that below 2k rpm. I'm guessing with the larger engine the Camaro can go lower. Is accelerating below 1000rpm bad for the engine or trans? What the lowest Rpm I should cruise at with this car? Thanks
Milidin is offline   Reply With Quote
Manual shift - 1-4 ? calflan V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 27 01-19-2015 10:39 PM
Pic request: fog light pattern from 98-02 camaro radioflyer 4th Generation Camaros 1 01-24-2010 09:54 PM
Condensation in late 4th gen headlights? MAC 4th Generation Camaros 27 06-30-2008 01:53 PM
