| 5th Gen Camaro SS LS LT General Discussions General 5th generation Camaro topics not covered by other subforums. |
Thread Tools |
The Collector Protector
Drives: 2012 Chevy Camaro ZL1 Join Date: Apr 2008
A FAKE SCOOP??!! ARE YOU KIDDING ME??!!
Please... Say it isn't so!
NOT FAUX SCOOPS ON THE LEGENDARY SS CAMARO!!!!!! NO!!!!!!!!!!
MotorCityAgent - Dream Car Insurance Agent ![]() "If its worth collecting, its worth protecting!" :5thgenvert: |
Moderator, USN
I'm sure we'll be able to make it functional with very little work. The aftermarket is designed to improve cars.
E.B.A.H.
Drives: you wild... Join Date: Mar 2007
what are you talking about? The hood slit, or the gills?
Gills weren't cut out in the 1st gen, and the hood slit has always bee known to be non-functional. The hood latch is right behind it, and the intake is off to the side. EDIT: Please turn down your caps? We don't want the other threads complaining... |
I'm talking about the slit. No secret it was fake on the concept. But, I hoped they move it to the hood and make it functional.
E.B.A.H.
what would it's function be? running air over the engine to help cool it? It's not really that big, so not a lot of air would make it through anyways? I think it's cool to have it be functional, but I don't really see how much of difference it could make.
#6 |
Off the top of my head other non-functional things on Camaros...
Hood stacks on the first gen SS Fender slits on the '69 Iroc hood louvers 91-92 Z hood buldges |
#7 | |
Moderator, USN
#8 |
Almost-Original Postwhore
Dremel. Cut cut cut cut, add honeycomb/mesh of some kind, and you're done. I plan on setting up a short ram a lot like the ram jet fuel injection system (pic can be found here) and I think opening up the hood scoop will help make the overall temperature of the air coming through the intake a little bit cooler (instead of all that hot air from over the radiator).
- Xanthos
#9 |
![]() ![]() ![]() ![]() Drives: Muscle Join Date: Apr 2008
Personally i agree. i think its stupid that scoop isnt functional.
does it at least open up all the way through to let air in?? or is it like the Stang's scoop??? |
#10 |
You guys planning on cutting it out are probably going to be disappointing. It doesn't sound like it will be that easy. From the GM chat:
gss9909: why was the slit on the ss not made fuctional? I was really hoping for forced are. MikeAndJeff: It's a visual design feature. The reason it's not functional is it requires a large structural element behind it. |
#11 |
Yes - I have a feeling said large structural element is the hood latch.
- Xanthos
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: fanboys and ass kissers crazy. Join Date: May 2008
In this day and age, it's absolutely dumbass on a 400-420 hp car. I am getting mine professionally removed. Friggin embarrassing to be driving around with something so lame. If it worked, I could probably live with it but I hate the look anyways. Makes the front too busy. I would have rather them keep that area clean and add an SS specific hood.
#13 |
Well, everybody is entitled to their own opinion. I personally like it.
- Xanthos
#14 |
#15 | |
White 'n Nerdy
Drives: 2010 Camaro Join Date: Aug 2006
#16 |
the upper radiator support looks to be in the way also,
but i love doing work on my cars, so hopefully there will be some wiggle room... |
#17 |
Well, I'm not planning on making a true ram setup or anything - as long as it allows air to flow into the upper section of the engine compartment, or at least into the stream of air flowing from the upper grill, without passing over the radiator for too long, it will lower the temperature of the air flowing over the cone filter by at least a little bit. And at that point, its doing its job.
- Xanthos
#18 | |
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: challenger Join Date: Jul 2008
Yep the challenger ones don't function either. So you must go aftermarket.
#20 | |
SS Lightning
Drives: An SRT8 Join Date: Feb 2008
Yes they do, and so does the charger, well.......my charger
![]() Quote:
#21 | |
![]() Drives: 01 Z06 08 CTS 07 Avy LTZ Join Date: Apr 2008
Would it not be great if it came with the wider backend and the functional front scoop and rear scoop in front of the rear tires. I do not know about you but I would be one happy camper. |
#22 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 10 SIM 2SS/RS LS3 Join Date: May 2008
Question--Is the RS's hood bulge the same as the SS's? It appears that way to me and if so, that's pretty lame that a V-6 would get the same hood treatment. It's unlike the 4th gens, with the different hoods for the V-6/Z-28 and then the SS hood, which I put on my '95 Z-28.
5th Gen Camaros of the Carolinas
SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears.... |
#23 |
Well, I suppose they're using the scoop and lower fascia to differentiate between the two.
- Xanthos
#24 | |
Moderator, USN
#25 | |
- Xanthos
| Tags |
| 2010, intake, mail slot, scoop |
| Thread Tools | |
| Music for the Maiden Voyage? | LSxcellent | 5th Gen Camaro SS LS LT General Discussions | 1088 | 05-27-2012 11:43 PM |
| Hood Scoop.... | Casull | Camaro Photos | Spyshots | Video | Media Gallery | 18 | 03-14-2010 07:56 AM |
| What Do You Guys Think? Different look for different models? | CoolestCamaro873 | 5th Gen Camaro SS LS LT General Discussions | 8 | 03-30-2008 01:46 PM |
