Old 07-22-2008, 09:05 PM   #15
fastball
White 'n Nerdy
Drives: 2017 Camaro 2SS 6MT
Originally Posted by XanthosV6 View Post
Dremel. Cut cut cut cut, add honeycomb/mesh of some kind, and you're done. I plan on setting up a short ram a lot like the ram jet fuel injection system (pic can be found here) and I think opening up the hood scoop will help make the overall temperature of the air coming through the intake a little bit cooler (instead of all that hot air from over the radiator).
- Xanthos
You can bet I'll have the dremel ready the day I pick her up from the dealer.
fastball is offline
Old 07-22-2008, 09:09 PM   #16
baileyrx
baileyrx's Avatar
Drives: 2003 g35
the upper radiator support looks to be in the way also,
but i love doing work on my cars, so hopefully there will be some wiggle room...
baileyrx is offline
Old 07-22-2008, 09:17 PM   #17
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Well, I'm not planning on making a true ram setup or anything - as long as it allows air to flow into the upper section of the engine compartment, or at least into the stream of air flowing from the upper grill, without passing over the radiator for too long, it will lower the temperature of the air flowing over the cone filter by at least a little bit. And at that point, its doing its job.
- Xanthos
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline
Old 07-22-2008, 09:21 PM   #18
MotorCityAgent
The Collector Protector
MotorCityAgent's Avatar
Drives: 2012 Chevy Camaro ZL1
Originally Posted by Hylton View Post
In this day and age, it's absolutely dumbass on a 400-420 hp car. I am getting mine professionally removed. Friggin embarrassing to be driving around with something so lame. If it worked, I could probably live with it but I hate the look anyways. Makes the front too busy. I would have rather them keep that area clean and add an SS specific hood.
Well said.
MotorCityAgent - Dream Car Insurance Agent
"If its worth collecting, its worth protecting!"
:5thgenvert:
Contact me for a FREE Do-Not-Touch Sign
MotorCityAgent is offline
Old 07-22-2008, 09:49 PM   #19
kevin2323
Drives: challenger
Yep the challenger ones don't function either. So you must go aftermarket.
kevin2323 is offline
Old 07-22-2008, 10:00 PM   #20
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
Yes they do, and so does the charger, well.......my charger
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline
Old 07-22-2008, 10:03 PM   #21
Nickdago
Drives: 01 Z06 08 CTS 07 Avy LTZ
Originally Posted by The_Blur View Post
I'm sure we'll be able to make it functional with very little work. The aftermarket is designed to improve cars.
That seems to be the standard respone to something that is not quite up to expectations. The response from everyone is "Don't Worry" you can take care of it with after market parts".
Would it not be great if it came with the wider backend and the functional front scoop and rear scoop in front of the rear tires. I do not know about you but I would be one happy camper.
Nickdago is offline
Old 07-22-2008, 10:42 PM   #22
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
Question--Is the RS's hood bulge the same as the SS's? It appears that way to me and if so, that's pretty lame that a V-6 would get the same hood treatment. It's unlike the 4th gens, with the different hoods for the V-6/Z-28 and then the SS hood, which I put on my '95 Z-28.
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline
Old 07-22-2008, 10:46 PM   #23
Xanthos
PWA Relapse
Xanthos's Avatar
Well, I suppose they're using the scoop and lower fascia to differentiate between the two.
- Xanthos
Xanthos is offline
Old 07-22-2008, 10:54 PM   #24
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
So far, we've only seen the RS package. For all we know, LS and LT trims have no bulge at all.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:155 ban
The_Blur is offline
Old 07-22-2008, 10:57 PM   #25
Xanthos
PWA Relapse
Xanthos's Avatar
This is possible, but "Alternate, more aggressive hood" was not listed as part of the RS package, so it doesn't seem likely.
- Xanthos
Xanthos is offline
Old 07-22-2008, 11:16 PM   #26
Blizzard
Searching for the truth
Blizzard's Avatar
Drives: 85 K-10, 13 1LE
How many times have people told you it is the same width as the concept. The rear of the cab is wider to fit to grown people.
2013 1LE 1SS RS TPW 4/29
Blizzard is offline
Old 07-23-2008, 07:26 AM   #27
Camaroman_99
Camaroman_99's Avatar
Drives: 2009 Jeep Wrangler Unlimited
I was really hopeful the hood "slit" would be functional. Maybe they will have an SS only hood optional.
Camaroman_99 is offline
Old 07-23-2008, 07:45 AM   #28
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
no hoods. Too expensive to manufacture. The slit isn't even on the hood anyways.
Mindz is offline
2010, intake, mail slot, scoop
Music for the Maiden Voyage? LSxcellent 5th Gen Camaro SS LS LT General Discussions 1088 05-28-2012 12:43 AM
Hood Scoop.... Casull Camaro Photos | Spyshots | Video | Media Gallery 18 03-14-2010 08:56 AM
What Do You Guys Think? Different look for different models? CoolestCamaro873 5th Gen Camaro SS LS LT General Discussions 8 03-30-2008 02:46 PM
