Solo Performance
Old 11-25-2009, 03:54 PM   #1
twintailf14
twintailf14's Avatar
Drives: 2010 Camaro Red 2SS/RS blk stripes
Brake fluid leak
Hi all, just was wondering if anybody has experienced brake fluid leaking from the reservoir. My dealer has replaced the cap twice and now I'm going to bring it back for a third time. Thye are going to have to replace the resevoir now I presume. My Camaro is 2SS/RS package
Thanks
twintailf14 is offline   Reply With Quote
Old 11-25-2009, 04:00 PM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Do you have a M6 if so it will not be aball to fix it that way, It because the brake and Clutch are in one reservoir, You need to split the 2 and get a reservoir that can be closed.
Old 11-26-2009, 09:13 AM   #3
Augie1978
Augie1978's Avatar
Drives: 2011 2SS RS Vert
Yeh mine leaks too.
2SS RS, Triple Black Vert, Manual, Hurst Shifter. American Racing Headers, Roto-Fab CAI
Augie1978 is offline   Reply With Quote
Old 07-22-2010, 06:21 PM   #4
bakon's camaro SS
bakon's camaro SS's Avatar
Drives: 2010 Camaro 2SS/RS
mines been leaking also i bought it that way i didnt noticed till i got home and oppend the hood. i cant find anything wrong with it but could someone give me any suggestions.... :/
I like to go fast Super Sport fast
bakon's camaro SS is offline   Reply With Quote
Old 07-22-2010, 06:42 PM   #5
Fast1
Fast1's Avatar
Drives: 2010 Summit White SS
I have a slight leak. Service mgr said it was overfilled so he took some fluid out. Looks ok-so far.
Fast1 is offline   Reply With Quote
Old 07-22-2010, 06:47 PM   #6
2SSRS@Gen5diy
If you have a M6 car its the fact that the top is not air tight it will always leak.
Old 07-22-2010, 07:24 PM   #7
busaboy
busaboy's Avatar
Drives: Black RS/SS M6
Umm a master cylinder that leaks is not acceptable. There is a problem somewhere.
busaboy is offline   Reply With Quote
Old 07-22-2010, 07:32 PM   #8
spyderbuddy
spyderbuddy's Avatar
Yea I have a v6 rs and the cap is leaking.
Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, Vararam Cold Air Intake, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
Old 07-23-2010, 10:30 PM   #9
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Can you guys please clarify leaking?
I ask because a vented cap will have a trace of fluid around it. That is not leaking. It is breathing. If you have a wet reservoir that would not be breathing. It would be leaking
Who has breathing residue?
Who has a wet bottle?
Can you post pictures so we can all compare wet bottles?
Old 07-23-2010, 10:42 PM   #10
spyderbuddy
I have brake fluid around the edge of the reservoir below the cap so why have any residue awaywhere wether it's just breathing or not.
Old 07-23-2010, 10:51 PM   #11
JusticePete
VIR Specialist
The brake fluid comes out of the vent more as a vapor than fluid. The vapor gets on the cap and leaves what I would refer to as a film. If you looked at my reservoir it would look like the top third had a bit of Armour All on it with a trace in the molding / tank seam. It isn't leaking. It is breathing.
The reason for the vent is expansion from cold to hot and contraction from hot to cold. That is why the system is not sealed.
Old 07-23-2010, 10:58 PM   #12
2SSRS@Gen5diy
Like this Pete.
That to me is a leak, But don't have vary much after i put a remote clutch reservoir.
Old 07-23-2010, 11:05 PM   #13
JusticePete
VIR Specialist
Originally Posted by 2SSRS View Post
Like this Pete.
Yes sir except I wash mine more often becuase of the shows I attend or we would be twins.
Old 07-23-2010, 11:37 PM   #14
2SSRS@Gen5diy
That was after 2 weeks of DD only
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 34 05-04-2016 12:11 PM
Brake/Clutch Fluid leak 2SSRS@Gen5diy Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 29 04-03-2012 08:13 PM
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! AJ@ECSMotorsports Suspension / Chassis / Brakes 49 11-13-2010 04:57 PM
Brake Fluid tyler20c Suspension / Brakes / Chassis 1 10-26-2009 02:21 PM
How many Quarts of Brake Fluid? SSOOCH Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 15 07-30-2009 10:13 AM
