Solo Performance
Old 11-25-2009, 04:11 PM   #1
twintailf14
twintailf14's Avatar
Drives: 2010 Camaro Red 2SS/RS blk stripes
Smile LEAKING BRAKE FLUID
Wow, this seems pretty minor compared to some of what I read. Has anyone experienced brake fluid leaking from the reservoir, I presume when braking pushing the fluid forward. My dealer has replaced the cap twice, and now I'll be bringing it in a third time.
I have 7500 miles on my Red 2SS now and no other issues other than a spoiler fastner that broke, and just last weekend, has the chance to run it down the runway of the airfield I work at I got to 134mph with the sheriffs watching. What a ride, smooth, I mean real smooth except for the window whistling at 115+.
twintailf14 is offline   Reply With Quote
Old 11-25-2009, 06:01 PM   #2
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
Does your invoice from the previous repairs have a part number listed?? If it does is it 20819283? Thats the part number from a PI that has to do with the cap leaking.
thiggin2 is offline   Reply With Quote
Old 11-25-2009, 06:02 PM   #3
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
I too have the same problem. Others on here have as well. What I was told is that with the clutch and brakes in the same reservoir there is to much pressure and fluid is pushed out the cap. GM has been made aware of this several times as well to no aval. I wish they would just put the clutch in its on resv. and solve the issue.
lawdogg149 is offline   Reply With Quote
Old 11-25-2009, 11:15 PM   #4
LS 1st gen
Kept the Faith.
LS 1st gen's Avatar
Drives: 2010 VR 2SS
Send a message via AIM to LS 1st gen
Dealer replaced my master cylinder about 2 months ago. The leak has not resurfeced.
GORDON 2010 Camaro # 13694 Victory Red 2SS manual | White rally Stripes | Polished Wheels | Rotofab CAI| MGW Shifter| Kooks LT's| Magnaflow X-pipe|FM 40 Delta Flows | Elite Tunnel Brace | "Ginger"
LS 1st gen is offline   Reply With Quote
Old 11-29-2009, 01:38 AM   #5
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
The reservoir is too full from the factory. Lower the level to around where the seam is, which is between the high and low marks and no more problems.
Check out this thread for info on separating the clutch and brake reservoirs:
http://www.camaro5.com/forums/showthread.php?t=34085
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 34 05-04-2016 12:11 PM
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! AJ@ECSMotorsports Suspension / Chassis / Brakes 49 11-13-2010 04:57 PM
Brake fluid leak twintailf14 Suspension / Brakes / Chassis 14 07-23-2010 11:50 PM
Brake Fluid tyler20c Suspension / Brakes / Chassis 1 10-26-2009 02:21 PM
How many Quarts of Brake Fluid? SSOOCH Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 15 07-30-2009 10:13 AM
