Emblempros
Old 11-26-2009, 09:52 PM   #1
N2008T
Drives: 2SS RS Auto
clunking in suspension
Anyone notice that it sounds like shocks topping out on mild ripples in road getting clunking noise in suspension I have a 2SS RS Auto
N2008T is offline   Reply With Quote
Old 11-27-2009, 03:14 PM   #2
Gunmetal
Gunmetal's Avatar
Drives: Cyber Grey 1SS/RS w/Body Kit
Mine doesnt do that? 1SS/RS Manual. I would take it back and have your dealer inspect. How hard are you pushing it on the Neg Camber turns?
Gunmetal is offline   Reply With Quote
Old 11-29-2009, 12:26 PM   #3
75rusty
awesome!
Drives: 07 Jetta WB, '92 GTI 16vT, '76 LUV
My LS does the same thing, a subtle pop/thunk like the shocks are topping out, or the upper mount is bad.
Is you car still stock, or have you upgraded the suspension? I'm 100% stock still.
75rusty is offline   Reply With Quote
Old 11-29-2009, 03:42 PM   #4
Terrellford12
Drives: 2010 SS/RS
driveshaft rubbing
Terrellford12 is offline   Reply With Quote
Old 11-29-2009, 03:46 PM   #5
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
I ran road atlanta road course yesterday. Never had the issue there. But on the street when cold have had that strange noise. Cheap shocks for sure.
Nationwide Turf
"artificial turf factory"
lawdogg149 is offline   Reply With Quote
Old 11-29-2009, 04:47 PM   #6
75rusty
awesome!
I think it's the shocks also, can't wait for Bilstein to come out with the Sport's and HD's.
Old 11-29-2009, 08:27 PM   #7
ZAP 1401
Drives: 2SS/RS/Blk-Blk/L99,
I think struts or strut mounts, I have 2ss/rs auto, less than 400 miles, rolled off the truck clunking on both sides.
ZAP 1401 is offline   Reply With Quote
Old 11-29-2009, 09:09 PM   #8
N2008T
Drives: 2SS RS Auto
My car is stock 2SS 2k miles now been like that since new. After being blown off on tire problems at dealer I have no confindence that they will even care to address problem I paid to have tires changed twice car is ok now but dealer said there never was a problem. So I wanted a little info before going back to the hell of a Chevy dealer with a problem
Old 11-30-2009, 12:42 AM   #9
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
We are seeing issues with the upper rear strut and washer contacting the sheet metal inside the strut bucket. This issue appears to be significant variations in height of the sheet metal. We are seeing as much as a 3/8 of an inch variation with them.
Simple fix is to take a drift and push up on the sheet metal.
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 11-30-2009, 08:50 PM   #10
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
If the noise is what we suspect it might be, you can feel it in the trunk floor just above the are where the strut mounts.
Old 11-30-2009, 09:48 PM   #11
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
mike
dms
Hi mike do you or any one that works with pedders have a pic of the variations in height of the sheet metal so we can find the place to look at it.
Old 11-30-2009, 09:49 PM   #12
camarorick
camarorick's Avatar
Drives: .
mike
dms
Are you guys saying the noise most people are hearing actually originates in the rear suspension ?
Is the height difference in the rear strut bucket visible, how can one check this?
Can you elaborate on this ? " Simple fix is to take a drift and push up on the sheet metal. "
Thanks in advance !
camarorick is offline   Reply With Quote
Old 11-30-2009, 10:47 PM   #13
Info@PeddersUSA.com
Thanks in advance !
First of all, the noise we are seeing is a tinny rattle noise that sounds like it is coming from the trunk. This would not be the cause of a noise in the front.
This concern seems to occur more when there is more deflection or load in the upper rear strut bushing. Therefore, is more dominant with upgraded rear coils and things like a performance coil over.
When you look at the bucket on the inside, you will see there is a body seam spot welded. The contact is at the spot weld area. I will see if I can dig up some pictures.
mike
dms
Old 12-01-2009, 11:52 AM   #14
JusticePete
VIR Specialist
REBOOT
Is the noise in the front or the rear of your Camaro?
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H AJ@ECSMotorsports Suspension / Chassis / Brakes 80 11-17-2010 03:28 PM
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! Circuit Motorsports Suspension / Chassis / Brakes 99 05-24-2010 05:21 PM
Pedders suspension already for the Camaro Info@PeddersUSA.com Suspension / Brakes / Chassis 75 10-21-2009 08:25 PM
Discussion of suspension tuning methodologies Tankrust Wheels and Tires Talk Sponsored by The Tire Rack 10 08-04-2009 07:39 PM
Bose Suspension... I want CamaroSpike23 Wheels and Tires Talk Sponsored by The Tire Rack 15 03-04-2008 10:38 AM
