Old 11-27-2009, 10:49 AM   #1
kutch720
kutch720's Avatar
Drives: Camaro 1LT RS
Dead Battery?
OK so I put the Camaro into storage about 3 or 4 weeks ago and I went to go do my final storage preps putting rags in the intake and exhaust put plastic underneath the car. Take the battery out!!!! Anyways I was wondering if anyone else had a problem with short battery life. I remember being gone for 4 months with an older car and the battery didn't die on me.
kutch720 is offline   Reply With Quote
Old 11-27-2009, 12:05 PM   #2
71cam
71cam's Avatar
Drives: 71cam
Lots of electronics in cars these days compared to years ago. And these electronics run 24/7 with power from the battery. (ie security, door locks by fob, settings etc.). The cars today are only designed to sit for 3-4 weeks without having to boost the battery to start. You may luck out longer or shorter. But that's just the way it is. If you have unsuspecting draw from a mod or whatever, the life of the battery obviously decreases.
Why not just put a battery tender on it for the storage period.....works for me
71cam is offline   Reply With Quote
Old 11-27-2009, 01:49 PM   #3
kutch720
kutch720's Avatar
I want to put a trickle charge to it but the storage unit does not have a outlet. I guess I am just going to have to deal with it. Now i just am wondering if it is worth taking the battery out if it just going to die on me.
Old 11-27-2009, 07:37 PM   #4
71cam
71cam's Avatar
Drives: 71cam
trickle charger is a couple of amps charge that stays on 24/7 If left unattended for too long, it can overcharge or even boil dry the battery
a battery tender with float mode, is the best way to maintain your battery. A 200 to 300 milliamp float charge prevents sulfation by keeping it charged, and it switches to normal charging mode and turns on and off automatically
Do NOT get a trickle charger
Only use a battery tender
Old 11-27-2009, 07:45 PM   #5
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Great Advice!! Just take out the battery, put it in your garage and use the battery tender on it.
Old 11-28-2009, 10:00 AM   #6
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
+1
HeavyD is offline   Reply With Quote
Old 11-29-2009, 05:51 PM   #7
TooCool5
Resident Gearhead
TooCool5's Avatar
Going to try the battery float charger but not 24/7. Just maybe one day every two weeks.
Old 12-06-2009, 07:09 PM   #8
SQUALO
SQUALO's Avatar
Drives: LT/RS Hyper Blue white rally stripe
My first sports car was a '80 vette (didn't buy new) it had a 2yr old battery in it when I bought the car. During the duration I had the car, all I ever did was disconnect the negative terminal. Once spring came around I connected the terminal, turned the key, and she started without any issues.
Yes todays cars have a lot more electionics, but the batteries are much stronger too. Each person has a preference for winter storage, just try different ways, and see which works best for you.
(Drive Safely & Responsibly)
Battery Questions UA488Fitter 5th Gen Camaro SS LS LT General Discussions 31 02-26-2012 09:26 PM
Rob Zombie Living Dead Girl lyrics broncosman Off-topic Discussions 6 11-02-2009 08:26 PM
Positive Battery Cable issue (not near starter) shiftz33 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 08-12-2009 04:20 PM
Bumleb's Camaro battery cable issue is almost Fixed, Issue Solved Bumleb 5th Gen Camaro SS LS LT General Discussions 118 05-14-2009 11:04 PM
GM To Build Battery Plant Mr. Wyndham General Automotive + Other Cars Discussion 5 01-13-2009 01:03 PM
