Old 04-30-2010, 12:36 AM   #141
bigsquirrel
My car runs on acorns....
bigsquirrel's Avatar
Drives: 2010 SS RS Inferno Orange
Thanks for the write up, I used Oznium led panels, it was very simple.
bigsquirrel is offline   Reply With Quote
Old 05-07-2010, 11:41 AM   #142
SynerJersey110
SynerJersey110's Avatar
Drives: 2011 2SS BLK, 2010 Synergy Camaro
Thanks Tony,
I followed your wiring advice & hooked up my footwell lighting, and it works GREAT !!! I'll post pics in a few, working nights this week. Secured passenger seat light under glove box, fit right in. Driver's side lined up well, also. I even lucked out by using one inverter. AAC sent two dual lead inverters, so I used just one and it worked like a charm
SynerJersey110 is offline   Reply With Quote
Old 05-13-2010, 08:37 PM   #143
Greatness
Greatness
Greatness's Avatar
Drives: Camaro
i DID MINE!! looks swweettt ur directions helped tremendously tony heres the finished product
Black on Black 1LT GOT THE RIDE!!!
2G1FB1EV9A9153166 WWOOO!!!!
Greatness is offline   Reply With Quote
Old 05-14-2010, 12:05 AM   #144
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
All look great!
TonyNo is offline   Reply With Quote
Old 05-14-2010, 08:54 AM   #145
CAMARO_MOW
CAMARO_MOW's Avatar
Drives: 2011 White 2SS/RS
Very nice!
2SS/RS Summit White with IOM Stripes and IOM Interior, Hurst Shifter....
CAMARO_MOW is offline   Reply With Quote
Old 05-14-2010, 12:37 PM   #146
Pirate
ZOOMV8
Pirate's Avatar
Drives: Black on Black 2010 Camaro SS/RS
Send a message via Yahoo to Pirate
I have been contemplating this for the footwells. My thought is can using the LED (dome) style light with a 194 socket mounted in the footwell do the same thing? Tap both sockets into the dome light wiring to get the same effect as the dome light theater lighting. This lights should be bright enough to light the footwell if mounted for maximum effect. Thoughts?
:troll:
Pirate is offline   Reply With Quote
Old 05-14-2010, 07:18 PM   #147
SpeedFreak5
Detroit Muscle
SpeedFreak5's Avatar
Drives: 2010 Camaro 2LT/RS
Does anyone know where the fuse to the light in the trunk is. I think I blew it when I replaced the OEM bulb with Blue LED bulb. I nicked the metal when I was putting the cover back in while the light was on, because it is always on when the trunk is open. There was a big spark and then nothing. Any help would be greatly appreciated. Could it be the Trunk fuse in the Instrument Panel Fuse Block?
2LT/RS A6, Rally Yellow, CGM Stripes, Sun Roof, Injen CAI, Aero Turbine Exhaust, Trifecta Tune
SpeedFreak5 is offline   Reply With Quote
Old 05-15-2010, 12:06 AM   #148
TonyNo
TonyNo's Avatar
Trunk light is on a breaker.
Old 05-15-2010, 12:31 AM   #149
SummoneR
Paul
SummoneR's Avatar
Which means once you cycle the ignition it should work again.
Old 05-15-2010, 02:09 AM   #150
Greatness
Greatness
Greatness's Avatar
Drives: Camaro
Same exact thing happened to my friend who helped install mine lol i was like oh crap u just shot the bulb but then he took it out and blew on it and waied a second then put it back and it lit back up so try again i suppose.
Old 05-20-2010, 10:31 PM   #151
Camaro743
Camaro743's Avatar
Drives: 2010 2LT RJT Camaro
I'm sorry to bring this thread back from the dead everyone!! But I have a question!
Can some one who has installed the footwell lighting give me a list of all supplies needed for this to work? I know I need the footwell lighting, a t-tap, and what else?
"I took the two black (negative) wires, cut them to a good length, stripped them, crimped on a spade/ring terminal, and attached it to that bolt mentioned earlier. See the fifth pic.
I attached the t-tap mating terminal to a fuse holder, connected this to the red (positive) wires, and plugged it in. I then tucked the wires in behind the console and generally spiffed up the wiring before I snapped the console side covers back into place."
And could someone please clarify this? I don't know how to crimp a wire, or what a spade/ring terminal is. I don't know what a fuse holder is either lol. And is there any instructions on how to pull back the console so you can thread the wires through like the OP said?
I'm sorry for all the questions..any help would be appreciated!
use small words please..
Camaro743 is offline   Reply With Quote
Old 05-21-2010, 08:43 AM   #152
domano 68
domano 68's Avatar
Drives: 2014 1LE
Originally Posted by Jakefeb3 View Post
In this photo, it looks like a purple wire and another(?) wire
What does this connector do?
domano 68 is offline   Reply With Quote
Old 05-21-2010, 09:24 AM   #153
qbert48
qbert48's Avatar
Drives: 2SS SIM
dash ABL thats what i used mine for
2SS RS SIM gray leather stick shift ground FX
thank you gary richards @ classic chevy in sugarland
welcome home
1100 4-27-09
6000 6-27-09
yes i got to the dance late don't hate me
qbert48 is offline   Reply With Quote
Old 05-23-2010, 04:52 PM   #154
Buhmblbe
Growing Up=Optional
Buhmblbe's Avatar
Drives: 2010 Camaro Transformers 2LT RS
Thank you sooo much for this post. I took it one step further. I ran a constant 12V line to the interior and set up my own fuse box(thanks wizzer) then ran the power from that and the dome light tap to a common switch (I used double pole double throw-center off...I read post #54 but wanted the center off option as well and truthfully couldn't figure out how a SPDT would work) which I mounted under the driver's dash. End result=I now have three options with one switch
1-Always On
2-Always Off
3-Only on when the dome is on
Also, I used lights that can alternate between constant on or be switched to pulse to blink with the music.(Go Solid Gold Dancers...boy am I old)
I'll post pictures and a how to when I get my camera from my office tomorrow if anyone is interested.
(Yes I know...)
"Sleep is an inconvenience to living...Get up and start living."
Buhmblbe is offline   Reply With Quote
Ambient Footwell Lighting: ORACLE CCFL Tubes ($35/Pair) AACstyle Interior Parts & Accessories 278 03-20-2017 10:37 AM
Where to wire in ambient footwell lighting? cybercoaster Cosmetics and Lighting Modification Discussions 32 01-11-2016 12:08 PM
Anyone have the Footwell Lighting Kit Installed? wildthing001967 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 12 07-03-2011 06:00 PM
AACStyle footwell lighting problem TRSS2 Camaro DIY & HOW-TO instructions & discussions 8 01-23-2010 07:41 PM
footwell neon lighting. How to wire to have it come on the other ambient lighting? Jakefeb3 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 11-22-2009 10:32 PM
