Solo Performance
Old 04-20-2011, 04:38 AM   #393
bee sting
bee sting's Avatar
Drives: 1997 30th Ann. Z28 & 2010 2LT RS
Originally Posted by Toasty View Post
Thanks to Ofer (2SSRS) I have my footwell lighting installed, WITH A PLUG AND PLAY SOLUTION, no T-Taps needed!!! (yes it's a bit more expensive this way, but I like it better)
the harness plugs inline with the roof harness - behind the right kick panel. I can post up pics if there is some interest
I'd be interested in see this done . Thanks
bee sting is offline   Reply With Quote
Old 04-20-2011, 06:28 AM   #394
skysharker1
Airborne Paratroopers!!!
skysharker1's Avatar
Drives: 2016 Camaro SS Convertible
Location: Mid-NJ.....13 Year Army Paratrooper. Death from Above!!!
Send a message via AIM to skysharker1 Send a message via Yahoo to skysharker1
I just tapped my rear light power and ground to the front light wiring. Goes on and off with the front footwells. Removed the rear seat and glued the light strips to the front underneath edge of the seat, and used a little stiching to keep on there a little bit more secure. See pics.
skysharker1 is offline   Reply With Quote
Old 04-20-2011, 11:39 AM   #395
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
How did u wire the rear lights to the front lights?
Old 04-20-2011, 11:52 AM   #396
skysharker1
As you can see in the pic, I ran the wiring unerneath the rug, underneath the middle console, and spliced into my front footwell wires which are connected to a toggle switch just in front of the stickshift. See pic.
Old 04-22-2011, 02:16 AM   #397
ihaveacamaro
I like teeth.
Drives: #198
do you have any suggestions on how I should do it?
I don't have nor want to make a toggle switch for the footwells. But I already have the AAC front footwells in place in the front spliced to the dome light wire.
any ideas? I would want the rears to come on with the front...
Thanks,
Roshan
Old 04-22-2011, 02:55 AM   #398
SummoneR
Paul
SummoneR's Avatar
Thanks,
Roshan
Just connect the positive wire from each of the rear lights, then run a wire to the front and connect it to the same positive the fronts are connected to. Do the same with the ground. Run the wires under the carpet into the center console area up to where you connect it to the front lights.
Like shown in this picture.
Old 04-22-2011, 06:07 AM   #399
skysharker1
Exactamundo!!
Old 04-23-2011, 11:49 AM   #400
Funkymaddox
Funkymaddox's Avatar
Drives: 2011 Camaro 2LT/RS
i got my AAC package today and i have some questions for installing them on the dome light and with an extra switch to turn them on manually!
1. do I t-tap both, driver and passenger side, lights onto the grey cable or do i connect both lights and only one t-tap to the grey cable? in sequence would be easier i think, or?
2. do i get a good cable at the same spot where the grey cable is for a constant power source for the switch to turn the light on while i'm driving? which one would be a good cable for that?
Funkymaddox is offline   Reply With Quote
Old 04-23-2011, 11:57 AM   #401
skysharker1
Connect both light wires together...red to red and black to black...that way you have only the two wires to connect instead of four. I connected my fronts to a single pole-double throw (SPDT) switch which allows me to switch from dome light power to constant power (lights always on). My constant power is coming from the lighter in the center console above the stickshift; of course the power will cut off as soon as you open the driver door.
I installed the switch as seen below. It's a mini toggle switch.
Old 04-23-2011, 11:59 AM   #402
SummoneR
Paul
SummoneR's Avatar
I have a question for you. Did you install Diodes to keep the power from the constant back feeding the dome circuit, and vice versa?
Edit: Nevermind, I see you used a SPDT... duh. ah ahaha
Old 04-23-2011, 12:03 PM   #403
skysharker1
No diodes. When the switch is set to one source, it cuts off power from the other source, so there's no backfeed.
Old 04-23-2011, 12:11 PM   #404
SummoneR
Paul
SummoneR's Avatar
Yeah I caught that with the SPDT, I did not see that the first time I read your response sorry LOL
Old 04-23-2011, 12:26 PM   #405
skysharker1
NP
Old 04-23-2011, 12:39 PM   #406
Funkymaddox
ok thanks a lot. do i need extra wires or is the lenght enough on the AAC light?
and i am right to buy the red t-taps right?
i got this switch with my order from AAC, can you explain how to connect the wires on that?
Ambient Footwell Lighting: ORACLE CCFL Tubes ($35/Pair) AACstyle Interior Parts & Accessories 278 03-20-2017 09:37 AM
Where to wire in ambient footwell lighting? cybercoaster Cosmetics and Lighting Modification Discussions 32 01-11-2016 11:08 AM
Anyone have the Footwell Lighting Kit Installed? wildthing001967 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 12 07-03-2011 05:00 PM
AACStyle footwell lighting problem TRSS2 Camaro DIY & HOW-TO instructions & discussions 8 01-23-2010 06:41 PM
footwell neon lighting. How to wire to have it come on the other ambient lighting? Jakefeb3 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 11-22-2009 09:32 PM
