BORLA
Old 01-24-2010, 04:17 PM   #57
SummoneR
Paul
SummoneR's Avatar
Originally Posted by bologdl View Post
Found this site and it offers a remote swirch option for operating your LEDS.
12V LED Dimmer and Strobe Remote Switch - Plug & Play!
http://www.oznium.com/12v-remote-dimmer-strobe-switch
OZNIUM is awesome! I buy all my LED's from them. (Other than the Dome light I got from AAC. If I do my own custome work i get them from OZNIUM.
These are from OZNIUM
Old 01-27-2010, 02:01 PM   #58
Garret_Buie
Drives: 2010 Imperial Blue LS
Instead of TTAP connecter, why not just use a wire tap... alot less work and no need for a fuse
Garret_Buie is offline   Reply With Quote
Old 01-27-2010, 02:14 PM   #59
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
T-tap is so that you can pull/change it, and the fuse is just to be safe.
TonyNo is offline   Reply With Quote
Old 01-29-2010, 03:48 PM   #60
Garret_Buie
I'm using a simple wire tap on my dodge dakota, works just fine that way
Old 02-07-2010, 12:39 AM   #61
Toasty
Custom User Title :D
Toasty's Avatar
Drives: 2011 Summit White 2LT/RS
Originally Posted by TWCompetition View Post
Not sure if this is pertinent but found it on the CTS-V forums.
http://www.cadillacforums.com/forums...footwells.html
kit uses p/n 19170639. google search results make them look exactly like the ones that were supposed to be made for the camaro, but not sure on wire length or color of LED.
Toasty is offline   Reply With Quote
Old 02-07-2010, 01:36 AM   #62
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
I just used the stock connectors.
http://www.camaro5.com/forums/showthread.php?t=63527
franknbeans is offline   Reply With Quote
Old 03-11-2010, 02:04 PM   #63
SNV
SNV's Avatar
Drives: 2014 RRM 2ls
Anybody using Cold Cathode Light kits?
2010 IBM 1LT out. 2013 BRM 1LS in. It's like having a blank canvas once again. Modding has started! Now on to a 2014......
SNV is offline   Reply With Quote
Old 03-12-2010, 09:48 PM   #64
SNV
SNV's Avatar
Ordered a set of 10" Piranha Bars from oznium.com. Should be here sometime next week . Will post up some pics when I install.
SummoneR - Thanks for the repies to my pm's.
Old 03-13-2010, 02:01 PM   #65
SummoneR
Paul
SummoneR's Avatar
Looking forward to the pictures SNV. No Problem! Glad I could help.
Old 03-19-2010, 10:08 PM   #66
pkauf
pkauf's Avatar
Drives: 2013 Crystal Red Convertible RS
How cool - got mine done tonight!!!
Thanks to TonyNo - Just got mine installed tonight - what great instructions!!!!! I could have never found the right wires without his help.
A great upgrade to the dark footwells!!! Also added the LED Bulbz (blue) for the dome light, trunk and license plate!!!
pkauf is offline   Reply With Quote
Old 03-19-2010, 10:28 PM   #67
Sgt. Fury
Drives: 2010 Camaro
Hey, Just wanted to give a shout out to you Tonyno, Just finished up this install and could not have been easier. Thanks for the info! Cheers!
Sgt. Fury is offline   Reply With Quote
Old 03-19-2010, 10:44 PM   #68
TonyNo
TonyNo's Avatar
No problem! Helping out where I can!
Old 03-23-2010, 09:11 PM   #69
Bone
2SS RJT OWNER/OPERATOR
Bone's Avatar
Drives: 2010 2SS LS3 RJT
I finally finished my footwell lighting install. Only took me a couple of months. No clear instructions. Other than how to shrink wrap the connections with a hair dryer. Doh! Anyway, after scoping out the situation. and all the back breaking position under the dash. I figured out a nice place to mount the tube lights and the inverters. After all, I done want them to be in a position to get kicked and break, I had to makeup a couple of brackets at work. But that was no problem either. I proceeded to install my footwell light kit. After all the back breaking position under the dash. Did I mention it was a real pain in the back. (at 52, I don't bend easily). Well, I got it done. Wired it off the dome light. I really just wanted the footwell lights to illuminate the footwell when entering the vehicle at night. (GM should have supplied!)
Thanks to all, with your insight. It Help me alot. So here are a couple of pics of my footwell lighting install.
The really cool thing is. Running it off the dome light wire. The footwell lighting also mimicks the theater lighting effect. That is, it comes on softly until bright, Then it slowly fades with the dome light when the lights go off. Its frik'in awesome. Exactly what I wanted...
Fly low and Avoid the radar!
Bone is offline   Reply With Quote
Old 03-23-2010, 10:06 PM   #70
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Real nice man, nice!
HeavyD is offline   Reply With Quote
Ambient Footwell Lighting: ORACLE CCFL Tubes ($35/Pair) AACstyle Interior Parts & Accessories 278 03-20-2017 10:37 AM
Where to wire in ambient footwell lighting? cybercoaster Cosmetics and Lighting Modification Discussions 32 01-11-2016 12:08 PM
Anyone have the Footwell Lighting Kit Installed? wildthing001967 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 12 07-03-2011 06:00 PM
AACStyle footwell lighting problem TRSS2 Camaro DIY & HOW-TO instructions & discussions 8 01-23-2010 07:41 PM
footwell neon lighting. How to wire to have it come on the other ambient lighting? Jakefeb3 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 11-22-2009 10:32 PM
