Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Mid-Atlantic
Old 11-29-2009, 09:57 AM   #1
getarz4u15ster
getarz4u15ster's Avatar
Drives: Camaro RJT 2SS/RS
Thunder Racing In car Valve Spring Removal Tool
Hey Guy's I'm getting ready to change out the cam in my Camaro (LS3) this winter. I was wondering if anyone here has used, or knows if the "Thunder Racing In car Valve spring removal tool" will work on the LS3. I know it's made for the LS1, but i'm hoping it'll work. I don't want to spend $129 for nothing.
2010 RJT SS
Port and Polished, Milled .005 Heads
Patriot Valve Springs, Titanium Retainers&locks
Manley Race Valves
Comp Chromoly push-rods
Ported T/B
DT Headers, JBA H/F Catted mid pipes
Magna Flow Comp series exhaust w/ Xpipe
Comp Custom grind Cam
Tune and Machine work done by MPC
CAI Intake
getarz4u15ster is offline   Reply With Quote
Old 11-29-2009, 12:57 PM   #2
Raven02TA
Raven02TA's Avatar
Drives: 2002 Pontiac Transam. 2004 Tahoe,
Send a message via AIM to Raven02TA
it does look like the valves on the LS3/LS1 are in the same position from each other. althought he LS3 has an offset rocker arm which to me implies either the valves are further apart or the rockers are closer to each other. but if you call TR and ask they should know when you go to make your order.
Raven 2002 Trans Am, 585rwhp/578rwtq
Raven02TA is offline   Reply With Quote
Old 11-29-2009, 07:00 PM   #3
getarz4u15ster
That's my second approach. Just wanted to ask here to see if any of the techie's here knew anything first. Thanks for the info.
2010 RJT SS
Manley Race Valves
Ported T/B
CAI Intake
Pedders Camaro was the fastest Camaro at the Optima Challenge! Info@PeddersUSA.com Suspension / Brakes / Chassis 118 12-03-2009 12:06 AM
Sports Car???? Eduk8r 5th Gen Camaro SS LS LT General Discussions 50 09-21-2009 03:31 AM
1st Car Show and meeting Al Oppenheiser! scrming 5th Gen Camaro SS LS LT General Discussions 44 08-17-2009 05:46 PM
"The car of the future may turn out to be no car at all." Scotsman General Automotive + Other Cars Discussion 2 11-03-2007 01:22 AM
