HURST
Old 11-29-2009, 03:28 PM   #1
jimpfromwv
jimpfromwv's Avatar
Drives: 1968 camaro ss, 2010 camaro1ss
the best way to bleed air from the cooling system?
I'm going to do the heater hose relocation but I'm not really sure how to bleed air from the system when I'm done.
jimpfromwv is offline   Reply With Quote
Old 11-29-2009, 04:16 PM   #2
BlownSS
BlownSS's Avatar
Drives: 2010 Camaro SS/RS
pull off the radiator cap and let it run for a bit!
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
BlownSS is offline   Reply With Quote
Old 11-24-2010, 02:05 AM   #3
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Why is everyone doing a heater hose relocation? What's to gain with this mod?
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
calbert1999 is offline   Reply With Quote
Old 02-18-2011, 09:17 PM   #4
blackknight
Camaro Lover
Drives: 2014 GMC Sierra 5.3L
the stock hoses run over the intake. by relocating the heater hoses it removes the "heat bleed" from the heater hoses into the intake.
it helps reduce intake temps resulting in better performance. im doing the heater hose relocation this weekend actually.
No Camaro right now. But I'll be back in one in a few years.
blackknight is offline   Reply With Quote
Old 08-30-2017, 07:03 PM   #5
JOURDAN
Drives: 2010 Camaro SS 2SS
Well my coolant bottle is bone dry and looks to have been for sometime.
The coolant is just above the cooling fin when looking into radiator through cap.
JOURDAN is offline   Reply With Quote
Old 08-30-2017, 07:05 PM   #6
JOURDAN
How can a heater core go bad in 7 years? I thought I might have smelled coolant when I turned the heater on for the first time in forever.
Old 10-03-2017, 09:49 AM   #7
WoodBoss
"Old School"
WoodBoss's Avatar
Drives: 2010 2SS L99
If you remove the end of top hose going to the radiator and fill it there you will have a much easier time getting the air out. You can squeeze the lower hose after it runs for a while to push air from there as well. Also make sure the coolant reservoir is at the proper level, it holds quite a bit.
Back In The Saddle - Earley 2010 2SS IBM A6 #10244 Built - Roto-Fab CAI, Muffler/CAT Delete, Mickey Thompson ET DRs, RDP Tune,
BW Stage II Ported TB, Speed Engineering 1-7/8" Longtubes, ZEX Nitrous 125HP Shot, Lingenfelter 160* Stat, NGK TR6IX Spark Plugs & Elite Catch Can.
TCI Line Lock, JRE Trans Dipstick, BMR Trailing Arms & Toe Rods, Amsoil Signature Series 5W-30 - 11.76 sec @ 117.3 - 1.61 sec 60' - 1/4 mile pass
Check Out My Youtube Channel For 5th Gen Camaro Drag Racing & How To Mods https://www.youtube.com/channel/UCyG...GR9gDm6PO-27rg
WoodBoss is offline   Reply With Quote
Old 10-03-2017, 10:15 AM   #8
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Jack the front end of the car up and use that. Let it run for 10-15 minutes.
EXHAUST Milk 1027 Wiki 2 03-07-2010 10:20 PM
Breathless Performance Rammer Induction System - Group Buy MoranoRacing V8 Bolt-Ons & Tunes 0 10-14-2009 06:39 PM
How to get an LS9 for under $7000! 2010 CAMARO SS RS Forced Induction - V8 33 08-06-2009 03:59 PM
