Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires
Old 11-30-2009, 07:54 PM   #1
Jakefeb3
Drives: 2010 camaro 1ss
18" inch wheels fit on ss?
I have 20" wheels on the ss now (stock wheels). Will 18" wheels fit on the ss? or is 20 pretty much as low as I can go?
Jakefeb3 is offline   Reply With Quote
Old 11-30-2009, 08:06 PM   #2
Jakefeb3
I stopped at a local tire shop and they were telling me i couldnt fit 18s on there. But I thought you guys might know better
Old 11-30-2009, 08:41 PM   #3
Jakefeb3
Ive seen some 2ss with 18" wheels I think. Anyone know?
Old 11-30-2009, 08:50 PM   #4
jrpxxii
jrpxxii's Avatar
Yes 18 will fit. You need to look for 18x9.5 with offset at 50mm or so but they definitely do fit as alot of us on here are running 18 to have drag radials to run at track.
Old 11-30-2009, 08:51 PM   #5
ccdan
Drives: Real Nice
we have made 18x10 front and 18x11 rears in the c10/c14/c140 series for the ss
john
ccdan is offline   Reply With Quote
Old 11-30-2009, 09:00 PM   #6
Jakefeb3
http://www.tirerack.com/wheels/Wheel...ed&showRear=no will these fit?
Old 11-30-2009, 09:01 PM   #7
Jakefeb3
they are for winter
Old 11-30-2009, 09:11 PM   #8
tom692010
Drives: 4 wheels
I put 18" on mine for winter snow tires. They fit fine. they are F9 sport edition
tom692010 is offline   Reply With Quote
Old 11-30-2009, 09:12 PM   #9
Xanthos
Almost-Original Postwhore
Xanthos's Avatar
Drives: Stick
Probably won't clear the brakes. You'd do better to look into some Z06 wheels.
- X
Xanthos is offline   Reply With Quote
Old 11-30-2009, 09:16 PM   #10
jrpxxii
jrpxxii's Avatar
No those wont work as they are a 32mm offset
Old 11-30-2009, 09:16 PM   #11
AdamCzap
AdamCzap's Avatar
Drives: '10 TT SS / '07 Escalade
Look, I don't know why everybody keeps suggesting that 18's don't fit. I have them on my 2SS right now. I bought them from tirerack and have the same size rim and tire on all four wheels.
AdamCzap is offline   Reply With Quote
Old 11-30-2009, 09:18 PM   #12
jrpxxii
jrpxxii's Avatar
Hey ccdan, where can I look at your wheels and what size drag radial could I fit on a 18x11 rear wheel? An 18x11 clears everything and doesn't stick out the sides?
Old 11-30-2009, 09:27 PM   #13
Jakefeb3
Look at this thread. Look at the car with the black tires at the bottom.
http://www.camaro5.com/forums/showth...t=winter+tires
Aren't these wheels the exact same wheels as these:
Old 11-30-2009, 09:28 PM   #14
Jakefeb3
Why would they not work? It seems that tirerack says they would work? Please fill me in. Im trying to make a big decision here
Old 11-30-2009, 09:30 PM   #15
Jakefeb3
Doesn't this prove they will work?
Old 11-30-2009, 09:33 PM   #16
jrpxxii
jrpxxii's Avatar
If tirerack tells you they fit, I can't go against them as I was searching for 18 to put drag radials on and the offset is what I wasnt sure of but I would talk to someone at tireracka nd make sure no spacers are required.
Old 11-30-2009, 09:37 PM   #17
jrpxxii
jrpxxii's Avatar
I went to tirerack and looked but I can't get it to pull up any 18" for the 2010 camaro as it only shows 20". How did you filter it to show you which 18" will fit?
Old 11-30-2009, 10:14 PM   #18
srider
Drives: 78 z28, 67 nova, 07 mustang gt
An 18" will fit with ease if it has the correct geometry. Not a problem.
Here's a question for you guys.... Would any of you be interested in fitting a 17" on your cars if it were available?
If you are asking yourself "Why would anyone want to do that?", the answer is mostly for the drag radial guy that knows a 17" hooks better than an 18" and especially better than the stock 20" on the SS.
Let me know your thoughts...
Thanks.
srider is offline   Reply With Quote
Old 11-30-2009, 11:14 PM   #19
AdamCzap
AdamCzap's Avatar
jrpxxii: run a search under 'winter' for the camaro and see if you can find them that way, that's how i did it.
Old 11-30-2009, 11:57 PM   #20
Jakefeb3
Yes, I searched "winter" and it recommends down sizing to 18". But mostly its waaaay cheaper to go with 18". I want to get those EXACT wheels in the picture above. If anyone has more info, that would be great
Old 12-01-2009, 12:43 AM   #21
jrpxxii
jrpxxii's Avatar
Srider, 17 would be awesome if you have a way to produce them. I want 17 for the exact reason of drag radials but as far as I know there is only 1 company offering them and they are $750 each. I guarantee if someone comes out with a 17 that is affordable for us weekend track guys to put drag radials on, you couldnt make them fast enough.
Old 12-01-2009, 01:16 AM   #22
Jakefeb3
I just ordered a set of these:
http://www.tirerack.com/tires/tires....e1=yes&wTire=1
http://www.tirerack.com/wheels/Wheel...25&qty_front=4
I think these are the exact same stuff in that pic. Tirerack says it will be here around the 8th of DEC
Old 10-16-2012, 09:28 AM   #23
fab410
Aka "ShockWave"
fab410's Avatar
Drives: 2012 Camaro 2SS Convertible L99
Will the stock Camaro 18 inch wheels fit over the Camaro SS brembo's?
My friend is selling the 18 inch wheels off of an LT and I wanted to use them for the winter.
Thanks
360 Forged Straight 5 Wheels, ZL1 SideSkirts, T3 BlackOut, Roto Fab CAI, Trifecta Tune, PFADT Stage 2 Performance Handling Package, SS Brembo Conversion, Hurst Comp Plate & Stick Kit, Street Scene Splitter, Heritage Grille, AAC Afterburners
fab410 is offline   Reply With Quote
Old 10-16-2012, 10:55 AM   #24
Micawber
Drives: '92 Chev K1500 + 2011 VR 2SS/RS LS3
You people running the 18" wheels: What brakes are you using?
I've read that very few 19" wheels will fit over the stock SS rollerskates, though some do. So have you changed out your brake pads for an aftermarket pad? Which ones, and are you happy with them? Is there some other solution that I've missed?
Edit: I just noticed the dates on the original posts. Doh!
Micawber is offline   Reply With Quote
Old 10-16-2012, 05:22 PM   #25
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Pic - My car with my 18" wheel setup.
I didn't have to do any changes to fit the wheels. I have an early build without the roller skate brake pads. Most SS's need to change the brake pads or cut off the roller skate part of the brakes.
265/50/18 front tires, 305/45/18 rear tires (drag radials). Rides great and has excellent grip off the line.
SS wheels on the RS package? 103FrazzL Camaro Price | Ordering | Tracking | Dealers Discussions 25 11-21-2009 03:39 PM
RS SS 20'' Wheels and Tires FS jsharp Wheels / Tires 4 11-15-2009 07:31 PM
Anyone??? 0-60, 1/4 time, & speed on stock SS 20" VS. 19" or 20" light weight wheels? 2cnd chance Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions 2 09-19-2009 05:57 PM
2010 CAMARO SS 20 ALLOY WHEELS & TIRES 1,550 or Best offer comptect Wheels / Tires 23 07-25-2009 02:28 PM
